Adafruit_BBIO ImportError: cannot import name ADC
by jhalpin on Fri Mar 03, 2017 1:26 pm
I've installed the newest version (1.0.3) with 'pip install Adafruit_BBIO', but it can't find the ADC module. In fact there is no ADC.py installed.
bbb4g# locate ADC
/lib/firmware/PyBBIO-ADC-00A0.dtbo
/usr/local/lib/python2.7/dist-packages/Adafruit_BBIO/ADC.so
This is on Beaglebone Black, debian 7.8. I've seen some posts about needing a newer kernel to initialize ADC, but that's not what this is. Python can simply not find the ADC module:
#!/usr/bin/python
import sys
sys.path.append('/usr/local/lib/python2.7/dist-packages/Adafruit_BBIO')
from Adafruit_BBIO import ADC as adc
Gives this result:
bbb4g$ test.py
File "/home/jhalpin/bin/test.py", line 6, in <module>
ImportError: No module named Adafruit_BBIO
I'm guessing this isn't unique to me. Has anyone here figured this out yet?
Joe
jhalpin
Re: Adafruit_BBIO ImportError: cannot import name ADC
by drewfustini on Sat Mar 04, 2017 3:09 pm
Thanks for reporting this issue. I've not seen it before.
pip install Adafruit_BBIO is the preferred way to install Adafruit_BBIO. The expectation is that it should work on both the Debian 7.x (Wheezy) and Debian 8.x (Jessie) images.
I don't have Debian 7.8 image on hand to replicate your steps, but I will download it and repeat your steps.
In the meantime, please try installing Adafruit_BBIO from the GitHub repo:
git clone git://github.com/adafruit/adafruit-beag ... python.git
cd adafruit-beaglebone-io-python
sudo python setup.py install
drewfustini
by jhalpin on Sun Mar 05, 2017 12:14 pm
Last night I re-loaded my Beaglebone with debian 7.11. Everything seems ok with this version.
Joe
jhalpin
by drewfustini on Mon Mar 06, 2017 4:43 am
Good to hear. Thanks for the update.
drewfustini
