Still issue with PWM on Ubuntu 16.04.2 TLS
by henkwitte59 on Fri Jul 07, 2017 8:36 am
I am still receiving the "Problem with the cape manager" error when using the BBIO library on the beaglebone black.
OS is ubuntu 16.04.2
Python 3.4, I run python as root in this case (next step will be to run PWM as normal user)
I followed the instructions I found on the github BBIO site, issue 136 where the issue was that the cape overlays were not loaded, specifically I ran:
git clone https://github.com/beagleboard/bb.org-overlays
cd ./bb.org-overlays
sudo ./install.sh
and then I updated am335x_evm.sh by running git pull in /opt/scripts
I also checked the forum, viewtopic.php?f=49&t=111888&p=563344&hilit=PWM#p563344
and followed the instructions:
git clone https://github.com/cdsteinkuehler/beagl ... iversal-io
cd beaglebone-universal-io
sudo make install
After rebooting (which I did during each step) I still get the "problem with cape manager" error.
Any suggestions on what more I can check?
Henk
henkwitte59
Re: Still issue with PWM on Ubuntu 16.04.2 TLS
by drewfustini on Fri Jul 07, 2017 9:53 pm
Please run strace so that we can see what file i/o occurs before that error:
strace -f -o strace.log python test.py
Change test.py to the name of your program.
Then either attach strace.log to your post or upload it to GitHub Gist
drewfustini
by henkwitte59 on Sat Jul 08, 2017 5:00 am
Thanks for your reply,
I have created a gist at: https://gist.github.com/henkwitte/8b0f4 ... _pwm_error
The command I run is (I need to run pwm with root permissions, but root does not know where my python lives):
sudo strace -f -o strace.log /home/groenhol/miniconda3/bin/python3.4 test.py
The test program is just the adafruit example:
import Adafruit_BBIO.PWM as PWM
#PWM.start(channel, duty, freq=2000, polarity=0)
PWM.start("P9_14", 50)
(PS: GPIO runs well and I have managed to get that to run under the normal user account with assigning the group gpio and creating an udev config file, not yet succesfully for PWM).
henkwitte59
by drewfustini on Sat Jul 08, 2017 1:34 pm
Thanks. Please also paste the output of these commands:
cat /boot/uEnv.txt
cat /proc/cmdline
cat /sys/devices/platform/bone_capemgr/slots
drewfustini
by henkwitte59 on Sat Jul 08, 2017 5:05 pm
The results of cat /boot/uEnv.txt are included in the attached file
cat /proc/cmdline are:
console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable
and cat /proc/cmdline:
groenhol@arm:~$ cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
uenv.txt
(2.19 KiB) Downloaded 181 times
henkwitte59
by drewfustini on Sun Jul 09, 2017 5:13 am
I can't seem to replicate this issue in the Debian Jessie image. I'll have to try with Ubuntu.
What link did you use for the Ubuntu 16.04.2 image?
drewfustini
by henkwitte59 on Sun Jul 09, 2017 11:30 am
Hi, I used the ubuntu-16.04.2-console-armhf-2017-06-12-2gb.img.xz image
https://rcn-ee.com/rootfs/2017-06-12/mi ... 2gb.img.xz
With debian unfortunatly I have problems with bacnet-ip which is why i switched to ubuntu. The controller we are developing needs both the hardware io and bacnet ip to function
Henk
henkwitte59
by drewfustini on Mon Jul 10, 2017 1:14 am
Thanks for the link.
Is bacnet ip an ubuntu package?
drewfustini
by henkwitte59 on Mon Jul 10, 2017 4:41 am
No, it is a python package:
https://github.com/ChristianTremblay/BAC0
based on:
http://bacpypes.sourceforge.net/
However, I could not get that package to run under debian, but I could run it on ubuntu
In the mean time I have also tested with the debian jessie image, to see if I made a mistake in the installation. But the PWM code works on debian.
henkwitte59
by henkwitte59 on Mon Jul 10, 2017 5:00 am
So this is weird: having tried with debian I shut down the beaglebone and restarted with the SD containing the ubuntu image. Now the /sys/class/pwm directory is emtpy!
cat: /sys/devices/platform/bone_capemgr/slot: No such file or directory
henkwitte59
by henkwitte59 on Mon Jul 10, 2017 5:07 am
I found a site describing how to use pwm with ubuntu:
https://www.teachmemicro.com/beaglebone ... vice-tree/
perhaps it is worthwhile trying that however when I try to
git clone https://github.com/beagleboard/bb.org-o ... er/src/arm
i get an error: the repository cannot be found
henkwitte59
by drewfustini on Mon Jul 10, 2017 10:06 pm
drewfustini
by henkwitte59 on Tue Jul 11, 2017 5:37 am
I have been following the instructions on https://www.teachmemicro.com/beaglebone ... vice-tree/ with the following results:
cd bb.org-overlays/src/arm
compile the overlay:
dtc -O dtb -o BB-PWM1-00A0.dtbo -b 0 -@ BB-PWM1-00A0.dts
I then tried to move it to the /lib/firmware folder:
sudo mv -i BB-PWM1-00A0.dtbo /lib/firmware
but the system informed me the file already existed, so I decided to keep it (not replace it).
Then
echo BB-PWM1 > /sys/devices/platform/bone_capemgr/slots
cat /sys/devices/platform/bone_capemgr/slots now shows:
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-PWM1
In the /sys/class/pwm folder I now again have a folder pwmchip0
I can go into this folder and echo 0 > export, which created a pwm0 folder.
with
root@arm:/sys/class/pwm/pwmchip0/pwm0# echo 1000000000 > period
root@arm:/sys/class/pwm/pwmchip0/pwm0# echo 800000000 > duty_cycle
root@arm:/sys/class/pwm/pwmchip0/pwm0# echo 1 > enable
I can blink a LED connected to P9_14
So essentially it is functional.
Still, if I run the adafruit example it comes up with "problem with cape manager"
henkwitte59
by henkwitte59 on Tue Jul 11, 2017 5:52 am
On thing I found, in /lib/firmware there are only 3 PWM dtbo files, but there should be six? Could that be an issue?
root@arm:/home/groenhol# ls /lib/firmware/BB-PWM*
/lib/firmware/BB-PWM0-00A0.dtbo /lib/firmware/BB-PWM2-00A0.dtbo
/lib/firmware/BB-PWM1-00A0.dtbo
henkwitte59
by henkwitte59 on Tue Jul 11, 2017 6:38 am
Now I also have issues with ADC:
>>> import Adafruit_BBIO.ADC as ADC
>>> ADC.setup()
File "<stdin>", line 1, in <module>
RuntimeError: Unable to setup ADC system. Possible causes are:
- A cape with a conflicting pin mapping is loaded
- A device tree object is loaded that uses the same name for a fragment: helper
henkwitte59
