Beaglebone Black Rev C PWR Issue (Dead)
by aborrego1 on Sun Jul 09, 2017 10:53 pm
Dear Forum Admin,
I have contacted Adafruit support about the issue and was told I would need to post the issue before a replacement can be made. I purchased a Beaglebone Black Rev C along with the 5V adapter. After minor use the Beaglebone suddenly died, when I tired to re-power it either through USB or 5V the PWR LED flashes once and no power is given. I have tested using different USB cables/Adapters and even tried different USB port and the same result occurs, is it possible I can send it in for an exchange?
My Order Number: 1471164
I have not attached any pictures of the Beaglebone because like noted above it is hard to capture the PWR LED flashing once when connected to power.
aborrego1
Re: Beaglebone Black Rev C PWR Issue (Dead)
by drewfustini on Mon Jul 10, 2017 10:11 pm
The Power LED blinking once and no other activity is symptom of hardware failure, most likely the power management IC. It can not be repaired.
Please email support@adafruit.com with a link to this post for a replacement BBB
Drew
drewfustini
