Python doesn't find Adafruit library or the modules.
by robcj07 on Fri Jul 14, 2017 6:54 pm
Hello
I want to start programming with Python on my BeagleBone Black but seem to fail due to the next error
~# python
Python 2.7.9 (default, Aug 13 2016, 17:56:53)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import Adafruit_BBIO.GPIO as GPIO
File "<stdin>", line 1, in <module>
ImportError: No module named Adafruit_BBIO.GPIO
I followed a guide for installing the Adafruit_BBIO library here: https://learn.adafruit.com/setting-up-io-python-library-on-beaglebone-black/installation-on-ubuntu
However I got outputs stating it was already installed. At the end of the guide it is possible to test the installation by running:
sudo python -c "import Adafruit_BBIO.GPIO as GPIO; print GPIO"
#you should see this or similar:
<module 'Adafruit_BBIO.GPIO' from '/usr/local/lib/python2.7/dist-packages/Adafruit_BBIO/GPIO.so'>
but the installation says this:
Requirement already satisfied: Adafruit_BBIO in /usr/local/lib/python2.7/dist-packages/Adafruit_BBIO-1.0.0-py2.7-linux-armv71.egg
It is confusing so I would like some help.I have Debian 8 on the BBB
robcj07
Re: Python doesn't find Adafruit library or the modules.
by drewfustini on Sat Jul 15, 2017 1:21 am
I'd like to know more about the system software on your beaglebone. Please paste the output of these commands:
uname -a
cat /etc/dogtag
cat /etc/debian_version
cat /sys/devices/platform/bone_capemgr/slots
cat /proc/cmdline
cat /boot/uEnv.txt
drewfustini
by drewfustini on Sat Jul 15, 2017 1:25 am
Also please install Adafruit_BBIO from the GitHub repo and see if the problem persists:
git clone https://github.com/adafruit/adafruit-be ... -io-python
cd adafruit-beaglebone-io-python/
sudo make install
drewfustini
by robcj07 on Sat Jul 15, 2017 2:46 pm
Here are the outputs Drew:
~# uname -a
Linux beaglebone 4.4.30-ti-r64 #1 SMP Fri Nov 4 21:23:33 UTC 2016 arm71 GNU/Linux
~# cat /etc/dogtag
Beagleboard.org Debian Image 2016-11-06
~# cat /etc/debian_version
8.6
~# cat /sys/devices/platform/bone_capemgr/slots
 0: PF----  -1
 1: PF----  -1
 2: PF----  -1
 3: PF----  -1
 4: P-O-L-  0 Override Board Name,00A0, Override Manuf, cape-universaln
~# cat /proc/cmdline
console=tty0 console=tty00,115200n8 capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4, BB-UART5 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait coherent_pool=1M quiet cape_inoversal=enable
~# cat /boot/uEnv.txt
#Docs: http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
uname_r=4.4.30-ti-r64
#uuid=
#dtb=
##BeagleBone Black/Green dtb's for v4.1.x (BeagleBone White just works..)
##BegaleBone Black: HDMI (Audio/Video) disabled:
#dtb=am335x-boneblack-emmc-overlay.dtb
##BegaleBone Black: eMMC disabled:
#dtb=am335x-boneblack-hdmi-overlay.dtb
##BegaleBone Black: HDMI Audio/eMMC disabled:
#dtb=am335x-boneblack-nhdmi-overlay.dtb
##BegaleBone Black: HDMI (Audio/Video)/eMMC disabled:
#dtb=am335x-boneblack-overlay.dtb
##BegaleBone Black: wl1835
#dtb=am335x-boneblack-wl1835mod.dtb
##BegaleBone Green: eMMC disabled
#dtb=am335x-bonegreen-overlay.dtb
cmdline=coherent_pool_1M quiet cape_universal=enable
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M quiet cape_universal=enable video=HDMI-A-1:1024x768@60e
##Example v3.8.x
#cape_diasable=capemgr.disable_partno=
cape_enable=capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4, BB-UART5
##Example v4.1.x
#cape_diasable=bone_capemgr.disable_partno=
#cape_enable=bone_capemgr.enable_partno=
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
robcj07
by robcj07 on Sat Jul 15, 2017 4:23 pm
drewfustini wrote:Also please install Adafruit_BBIO from the GitHub repo and see if the problem persists:
sudo make install
I did the manual installation on Ubuntu/Debian and python seems to be running just fine. Thanks a lot!
robcj07
