I'm struggling to get the example file for "Adafruit_Python_MCP9808" to work on my beaglebone black.
I followed the steps in the tutorial to install the library, but when I went to run the example file I get the following error:
File "simpletest.py", line 50, in <module>
sensor.begin()
File "build/bdist.linux-armv7l/egg/Adafruit_MCP9808/MCP9808.py", line 72, in begin
File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 190, in readU16BE
File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 164, in readU16
File "build/bdist.linux-armv7l/egg/Adafruit_PureIO/smbus.py", line 173, in read_word_data
IOError: [Errno 110] Connection timed out
Any help in figuring out what I did wrong would be appreciated, I'm still pretty new to this.
Thanks.
MCP9808 Example not working
- drewfustini
Re: MCP9808 Example not working
Please post a photo of the wiring.
I'd like to know more about the system software on your beaglebone. Please paste the output of these commands:
uname -a
cat /etc/dogtag
cat /etc/debian_version
cat /sys/devices/platform/bone_capemgr/slots
cat /proc/cmdline
cat /boot/uEnv.txt
uname -a
cat /etc/dogtag
cat /proc/cmdline
cat /boot/uEnv.txt
- bsnider
Here are the results of the commands you asked me to run, I've also included a picture of the wiring.
uname -a
Linux beaglebone 4.4.54-ti-r93 #1 SMP Fri Mar 17 13:08:22 UTC 2017 armv7l GNU/Linux
cat /etc/dogtag
BeagleBoard.org Debian Image 2017-03-19
8.8
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,cape-universaln
cat /proc/cmdline
console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable
cat /boot/uEnv.txt
#Docs: http://elinux.org/Beagleboard:U-boot_pa ... layout_2.0
uname_r=4.4.54-ti-r93
#uuid=
#dtb=
##BeagleBone Black/Green dtb's for v4.1.x (BeagleBone White just works..)
##BeagleBone Black: HDMI (Audio/Video) disabled:
#dtb=am335x-boneblack-emmc-overlay.dtb
##BeagleBone Black: eMMC disabled:
#dtb=am335x-boneblack-hdmi-overlay.dtb
##BeagleBone Black: HDMI Audio/eMMC disabled:
#dtb=am335x-boneblack-nhdmi-overlay.dtb
##BeagleBone Black: HDMI (Audio/Video)/eMMC disabled:
#dtb=am335x-boneblack-overlay.dtb
##BeagleBone Black: wl1835
#dtb=am335x-boneblack-wl1835mod.dtb
##BeagleBone Green: eMMC disabled
#dtb=am335x-bonegreen-overlay.dtb
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBon ... t_Overlays
###Master Enable
#enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/<file0>.dtbo
#uboot_overlay_addr1=/lib/firmware/<file1>.dtbo
#uboot_overlay_addr2=/lib/firmware/<file2>.dtbo
#uboot_overlay_addr3=/lib/firmware/<file3>.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/<file4>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless)
#disable_uboot_overlay_emmc=1
#disable_uboot_overlay_video=1
#disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
###Cape Universal Enable
#enable_uboot_cape_universal=1
###U-Boot fdt tweaks...
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable video=HDMI-A-1:1024x768@60e
##Example v3.8.x
#cape_disable=capemgr.disable_partno=
#cape_enable=capemgr.enable_partno=
##Example v4.1.x
#cape_disable=bone_capemgr.disable_partno=
capemgr.enable_partno=BB-UART1
capemgr.enable_partno=BB-UART2
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
uname -a
cat /etc/dogtag
8.8
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
cat /proc/cmdline
cat /boot/uEnv.txt
#uuid=
#dtb=
###Master Enable
###Custom Cape
##Example v3.8.x
##Example v4.1.x
- Attachments
- 20170807_062900.jpg (820.45 KiB) Viewed 1485 times
- drewfustini
Thanks. The wiring does look correct according to the tutorial.
It looks like you are using I2C2_SCL (P9_19) and I2C2_SDA (P9_20):
Please verify that these pins are configured for i2c with the config-pin command:
config-pin -q p9.19
config-pin -q p9.20
Then use the i2cdetect utility to see if your device appears on the i2c bus:
sudo i2cdetect -y -r 1
The default address is 0x18 for the MCP9808.
You can also check the i2c adapters that are available with:
sudo i2cdetect -l
config-pin -q p9.19
config-pin -q p9.20
sudo i2cdetect -l
- drewfustini
If 0x18 does appear in i2cdetect output, then wiring is ok.
In that case, please run strace to see what i2c device the python library is opening. I seem to recall a past issue where there library is trying to open a path similar to /dev/i2c that doesn't exist.
If strace doesn't exist, this should install it:
sudo apt-get install strace
Then please run this command:
strace -o /tmp/strace-python-log.txt -f python simpletest.py
And this command:
strace -o /tmp/strace-i2cdetect-log.txt -f i2cdetect -y -r 1
Then attach /tmp/strace-python-log.txt and /tmp/strace-i2cdetect-log.txt here or upload to github gist. This should allow me to check if the python library is using the same i2c device path as i2cdetect.
And this command:
- bsnider
Running the pin config commands indicated that they were properly configured for i2c usage.
sudo i2cdetect -y -r 1 didn't find any devices, I then tried changing 1 to 2 and that did find the MCP9808 chip.
sudo i2cdetect -l showed 3 different devices, i2c-0, -1 and -2.
I ran the strace commands and have the txt files included with this post.
Thanks for the help so far.
- Attachments
- stract-i2cdetect-log.txt
- (23.33 KiB) Downloaded 91 times
- strace-python-log.txt
- (189.03 KiB) Downloaded 91 times
- bsnider
I found this commented section in the example and changed the bus number and was able to get everything working.
After seeing that I feel a bit silly for not noticing it sooner, but am happy everything is working now.
# Optionally you can override the address and/or bus number:
sensor = MCP9808.MCP9808(address=0x18, busnum=2)
- drewfustini
Good to hear it worked and thanks for following up.
Don't feel silly :) I've made this mistake myself. These libraries are written to support both Pi and BeagleBone which can get a bit confusing.
The issue is that the i2c bus used can vary between single board computers depending on both hardware configuration and how Linux kernel enumerates the i2c devices.
