xfer2 SPI AdafruitBBIO and 16 bpw functionality
by cachro2 on Fri Jan 12, 2018 3:45 pm
My question is regarding SPI for the Adafruit's BBIO library: https://github.com/adafruit/adafruit-be ... fruit_BBIO
We upgraded to Adafruits BBIO since we upgraded to Debian 9.X where we cannot use PyBBIO. Overall, the library is fantastic, there is just one point of confusion regarding the xfer2 function for SPI and setting bpw to 16. Our PyBBIO read/write/multi-read/multi-write functions were based on 16bits per word instructions to the device. Examples of a read and write to register below:
def read_adxl_register(reg_number):
    spi_read_data = bbio.SPI0.transfer(0, [(((reg_number << 1) | 0x01) << 8)])
    return spi_read_data[0] & 0x00FF
def write_adxl_register(reg_number, reg_value):
    spi_read_data = bbio.SPI0.transfer(0, [(reg_number << 9) | reg_value])
The equivalent of this piece of code using 8bits/word using the Adafruit BBIO library (verified the functionality) was:
    spi_read_data = spi.xfer2([((reg_number << 1) | 0x01), 0x00]) #R/W set to 1 for read
    return spi_read_data[1]
    spi_read_data = spi.xfer2([(reg_number << 1), reg_value]) #R/W set to 0 for write
However, we'd like to back to using 16 bits per word since we have an extensive FIFO multi-byte driver written in this format, which is easy enough to set using the library spi.bpw = 16. However we cannot get a simple read to function using 16bpw as it does using 8bpw.
    spi_read_data = spi.xfer2(0, [(((reg_number << 1) | 0x01) << 8)])
Can someone please provide an explanation of how to use the 16bpw setting and xfer2 function? I would assume setting bpw to 16 would then cause xfer2 to accept 16 bit hex values as well as return 16bit results in a list, if I am not mistaken..
As an example, with bpw set to 8, reading register 0x01 as shown below
print(spi.xfer2([ ((0x01 << 1) | 0x01), 0x00]))
Yields, [0,0x1D] as response. I cannot get the same simple example to work with 16 bpw.
The other SPI settings are set as follows:
spi = SPI(1,0)
spi.mode = 1
spi.msh = 5000000 # default is 16000000 (16Mhz)
Thanks,
Robert
cachro2
Re: xfer2 SPI AdafruitBBIO and 16 bpw functionality
by cachro2 on Fri Jan 19, 2018 3:37 pm
For those interested, this is a known issue highlighted here:
https://groups.google.com/forum/#!topic/beagleboard/f-PUIARH8Pk
Reviewed the code and it seems it is indeed casting output list object of the xfer2 function incorrectly.
I have decided to go ahead and pull 8 byte values and manually reconstruct the 16 bit words to maintain compatibility with our current sensor driver.
Regards,
Robert
cachro2
by drewfustini on Sat Jan 20, 2018 1:12 am
Thanks for following up. I maintain the Adafruit_BBIO library. Would you be able to raise a pull request with your fix? I'd like to make sure that other people are able to avoid this problem.
Thanks,
Drew
drewfustini
