Error when installing Adafruit BNO055
by ebachs10 on Sat Feb 03, 2018 2:46 pm
Hi there
I'm new to ubunto, but I'm trying to work me through on the BBB. I am following the tutorial given for the BNO055:
https://learn.adafruit.com/bno055-absol ... k/software
When Im trying to run the command: sudo python setup.py install i get an error:
can someone give me a hint, what to do?
Thanks in advance!
- Esben
2018-02-03 19_46_39-root's X desktop (MyFirstBeagle_1) - TightVNC Viewer.png
2018-02-03 19_46_39-root's X desktop (MyFirstBeagle_1) - TightVNC Viewer.png (139.5 KiB) Viewed 821 times
ebachs10
Re: Error when installing Adafruit BNO055
by franklin97355 on Sat Feb 03, 2018 3:06 pm
Can you post the error so we can help?
franklin97355
by drewfustini on Sat Feb 03, 2018 3:10 pm
Hi, sorry to hear you encountered an error. I do not see the text of an error message in your post.
Please either paste the full text of the error or attach a screenshot of the error message.
In addition, I would like to know more about the software installed on your BeagleBone. Please paste the output of these commands:
sudo /opt/scripts/tools/version.sh
cat /boot/uEnv.txt
Finally, I would recommend trying the current official BeagleBoard.org Debian image for the BeagleBone:
Stretch IoT (without graphical desktop) for BeagleBone and PocketBeagle via microSD card
drewfustini
by ebachs10 on Sat Feb 03, 2018 3:43 pm
Hi all
Thanks for the quick answer. I thought, that I had attached a sceenshot, but it should be attached now :)
Maybe, I'll have to clean up with a new image!
ebachs10
by drewfustini on Sat Feb 03, 2018 10:04 pm
Thanks for posting. It looks like the Debian installation is from 2014 which is quite old at this point and likely the issue.
Please try the current official BeagleBoard.org Debian image for the BeagleBone:
drewfustini
by ebachs10 on Sat Feb 10, 2018 12:18 pm
Hi drewfustini
Thank you for the reply - it was an old version! Finally, ive got a new version and everything installs correctly now (y). I've got a new problem now, and it is a IO error. Any suggestions?
2018-02-10 17_16_45-Adafruit customer service forums • Post a reply – Google Chrome.png
2018-02-10 17_16_45-Adafruit customer service forums • Post a reply – Google Chrome.png (70.47 KiB) Viewed 725 times
ebachs10
by drewfustini on Mon Feb 12, 2018 3:31 pm
Did you change the example to use the correct settings for your BeagleBone?
debian@beaglebone:~/tmp/Adafruit_Python_BNO055/examples$ git diff
diff --git a/examples/simpletest.py b/examples/simpletest.py
index 229267c..c17839d 100644
--- a/examples/simpletest.py
+++ b/examples/simpletest.py
@@ -31,10 +31,10 @@ from Adafruit_BNO055 import BNO055
 # Create and configure the BNO sensor connection.  Make sure only ONE of the
 # below 'bno = ...' lines is uncommented:
 # Raspberry Pi configuration with serial UART and RST connected to GPIO 18:
-bno = BNO055.BNO055(serial_port='/dev/ttyAMA0', rst=18)
+#bno = BNO055.BNO055(serial_port='/dev/ttyAMA0', rst=18)
 # BeagleBone Black configuration with default I2C connection (SCL=P9_19, SDA=P9_20),
 # and RST connected to pin P9_12:
-#bno = BNO055.BNO055(rst='P9_12')
+bno = BNO055.BNO055(rst='P9_12')
It would be helpful if you could run strace so that I can better understand what is happening.
Install strace (if it doesn't already exist):
sudo apt-get install strace
Then run strace, replace test.py with the name of your test program:
sudo strace -f -o strace.log python ./simpletest.py
Paste the contents of strace.log into a GitHub Gist or attach the file to your reply.
drewfustini
by ebachs10 on Sat Feb 17, 2018 4:10 am
Hi again
Finally weekend again!
1) I've changed simpletest.py so it look like, the attached screen dump:
2) I've executed the progrom with strace. See attached file.
Thanks in advance - it is appriciated! :)
ebachs10
by drewfustini on Sun Feb 18, 2018 1:59 am
I think that error may be caused by the pin mode not being set to i2c for those pins.
Please try running these commands to set i2c mode on all these pins:
config-pin p9.17 i2c
config-pin p9.18 i2c
config-pin p9.19 i2c
config-pin p9.20 i2c
config-pin p9.21 i2c
config-pin p9.22 i2c
Also, for the strace log, please attach the file to your reply.
Alternatively, this grep command should produce the output I'm interested:
sudo strace -o /tmp/strace.log python ./examples/simpletest.py
grep -A5 /dev/i2c /tmp/strace.log
drewfustini
