RE: sudo pip install --upgrade Adafruit_BBIO
silver2row
Re: RE: sudo pip install --upgrade Adafruit_BBIO
Post by silver2row »
Hello Again,
Sir...MBC.py is my software that was started from a Seeed Studio tutorial and I just kept adding to it. I think I posted the software from MBC.py earlier in our discussion.
Seth
P.S. Please reply or give me any additional instructions if needed.
silver2row
silver2row wrote:
So...the bottom software is the MBC.py. I typed it up but got help from a Wiki from Seeed Studio.
Seth
P.S. Let me know if this helps.
# FileName : MotorBridge.py
# by Jiankai.li
from Adafruit_I2C import Adafruit_I2C
import Adafruit_BBIO.GPIO as GPIO
import time
Reset = "P9_23"
MotorBridge = Adafruit_I2C(0x4b)
GPIO.setup(Reset, GPIO.OUT)
ReadMode  = 0
WriteMode = 1
DeAddr    = 0X4B
ConfigValid =  0x3a6fb67c
DelayTime = 0.005
# TB_WORKMODE
TB_SHORT_BREAK  = 0
TB_CW           = 1
TB_CCW          = 2
TB_STOP         = 3
TB_WORKMODE_NUM = 4
# TB_PORTMODE
TB_DCM          = 0
TB_SPM          = 1
TB_PORTMODE_NUM = 2
# SVM_PORT
SVM1            = 0
SVM2            = 1
SVM3            = 2
SVM4            = 3
SVM5            = 4
SVM6            = 5
SVM_PORT_NUM    = 6
# SVM_STATE
SVM_DISABLE     = 0
SVM_ENABLE      = 1
SVM_STATE_NUM   = 2
# IO_MODE
IO_IN           = 0
IO_OUT          = 1
IO_MODE_NUM     = 2
# IO_PUPD
IO_PU           = 0
IO_PD           = 1
IO_NP           = 2
IO_PUPD_NUM     = 3
# IO_PPOD
IO_PP           = 0
IO_OD           = 1
IO_PPOD_NUM     = 2
# IO_STATE
IO_LOW          = 0
IO_HIGH         = 1
IO_STATE_NUM    = 2
# IO_PORT
IO1             = 0
IO2             = 1
IO3             = 2
IO4             = 3
IO5             = 4
IO6             = 5
IO_NUM          = 6
# PARAM_REG
CONFIG_VALID        = 0
CONFIG_TB_PWM_FREQ  = CONFIG_VALID + 4
I2C_ADDRESS         = CONFIG_TB_PWM_FREQ + 4
TB_1A_MODE          = I2C_ADDRESS + 1
TB_1A_DIR           = TB_1A_MODE + 1
TB_1A_DUTY          = TB_1A_DIR + 1
TB_1A_SPM_SPEED     = TB_1A_DUTY + 2
TB_1A_SPM_STEP      = TB_1A_SPM_SPEED + 4
TB_1B_MODE          = TB_1A_SPM_STEP + 4
TB_1B_DIR           = TB_1B_MODE + 1
TB_1B_DUTY          = TB_1B_DIR + 1
TB_1B_SPM_SPEED     = TB_1B_DUTY + 2
TB_1B_SPM_STEP      = TB_1B_SPM_SPEED + 4
TB_2A_MODE          = TB_1B_SPM_STEP + 4
TB_2A_DIR           = TB_2A_MODE + 1
TB_2A_DUTY          = TB_2A_DIR + 1
TB_2A_SPM_SPEED     = TB_2A_DUTY + 2
TB_2A_SPM_STEP      = TB_2A_SPM_SPEED + 4
TB_2B_MODE          = TB_2A_SPM_STEP + 4
TB_2B_DIR           = TB_2B_MODE + 1
TB_2B_DUTY          = TB_2B_DIR + 1
TB_2B_SPM_SPEED     = TB_2B_DUTY + 2
TB_2B_SPM_STEP      = TB_2B_SPM_SPEED + 4
SVM1_STATE          = TB_2B_SPM_STEP + 4
SVM1_FREQ           = SVM1_STATE + 1
SVM1_ANGLE          = SVM1_FREQ + 2
SVM2_STATE          = SVM1_ANGLE + 2
SVM2_FREQ           = SVM2_STATE + 1
SVM2_ANGLE          = SVM2_FREQ + 2
SVM3_STATE          = SVM2_ANGLE + 2
SVM3_FREQ           = SVM3_STATE + 1
SVM3_ANGLE          = SVM3_FREQ + 2
SVM4_STATE          = SVM3_ANGLE + 2
SVM4_FREQ           = SVM4_STATE + 1
SVM4_ANGLE          = SVM4_FREQ + 2
SVM5_STATE          = SVM4_ANGLE + 2
SVM5_FREQ           = SVM5_STATE + 1
SVM5_ANGLE          = SVM5_FREQ + 2
SVM6_STATE          = SVM5_ANGLE + 2
SVM6_FREQ           = SVM6_STATE + 1
SVM6_ANGLE          = SVM6_FREQ + 2
IO1_STATE           = SVM6_ANGLE + 2
IO1_MODE            = IO1_STATE + 1
IO1_PUPD            = IO1_MODE + 1
IO1_PPOD            = IO1_PUPD + 1
IO2_STATE           = IO1_PPOD + 1
IO2_MODE            = IO2_STATE + 1
IO2_PUPD            = IO2_MODE + 1
IO2_PPOD            = IO2_PUPD + 1
IO3_STATE           = IO2_PPOD + 1
IO3_MODE            = IO3_STATE + 1
IO3_PUPD            = IO3_MODE + 1
IO3_PPOD            = IO3_PUPD + 1
IO4_STATE           = IO3_PPOD + 1
IO4_MODE            = IO4_STATE + 1
IO4_PUPD            = IO4_MODE + 1
IO4_PPOD            = IO4_PUPD + 1
IO5_STATE           = IO4_PPOD + 1
IO5_MODE            = IO5_STATE + 1
IO5_PUPD            = IO5_MODE + 1
IO5_PPOD            = IO5_PUPD + 1
IO6_STATE           = IO5_PPOD + 1
IO6_MODE            = IO6_STATE + 1
IO6_PUPD            = IO6_MODE + 1
IO6_PPOD            = IO6_PUPD + 1
PARAM_REG_NUM = IO6_PPOD + 1
def WriteByte(Reg,Value):
    data = [0 for i in range(2)]
    data[0] = Reg
    data[1] = Value
    MotorBridge.writeList(WriteMode,data)
def WriteHalfWord(Reg,Value):
    data = [0 for i in range(3)]
    data[0] = Reg
    data[1] = Value & 0xff
    data[2] = (Value>>8) & 0xff
def WriteOneWord(Reg,Value):
    data = [0 for i in range(5)]
    data[0] = Reg
    data[3] = (Value>>16) & 0xff
    data[4] = (Value>>24) & 0xff
def SetDefault():
    WriteOneWord(CONFIG_VALID,0x00000000)
class MotorBridgeCape:
    def __init__(self):
        GPIO.output(Reset, GPIO.HIGH)
        time.sleep(1)
    # init stepper motor A
    def StepperMotorAInit(self):
        WriteByte(TB_1A_MODE,TB_SPM) #Stepper
        time.sleep(DelayTime)
        WriteHalfWord(TB_1A_DUTY,1000)    # voltage
    # MoveSteps > 0 CW
    # MoveSteps < 0 CCW
    # StepDelayTime : delay time for every step. uint us
    def StepperMotorAMove(self,MoveSteps,StepDelayTime):
        if MoveSteps > 0:
            WriteByte(TB_1A_DIR,TB_CW)   #CW
        else:
            WriteByte(TB_1A_DIR,TB_CCW)   #CW
            MoveSteps = -MoveSteps
        WriteOneWord(TB_1A_SPM_SPEED,StepDelayTime)  # unit us
        WriteOneWord(TB_1A_SPM_STEP,MoveSteps)
    # init stepper motor B
    def StepperMotorBInit(self):
        WriteByte(TB_2A_MODE,TB_SPM) #Stepper
        WriteHalfWord(TB_2A_DUTY,1000)    # voltage
    # MoveSteps > 0 CW
    # MoveSteps < 0 CCW
    def StepperMotorBMove(self,MoveSteps,StepDelayTime):
        if MoveSteps > 0:
            WriteByte(TB_2A_DIR,TB_CW)   #CW
        else:
            WriteByte(TB_2A_DIR,TB_CCW)   #CW
        WriteOneWord(TB_2A_SPM_SPEED,StepDelayTime)  # unit us
        WriteOneWord(TB_2A_SPM_STEP,MoveSteps)
    # Init DC Motor
    def DCMotorInit(self,MotorName,Frequency):
    # Init the DC Frequency
        WriteOneWord(CONFIG_TB_PWM_FREQ,Frequency)
    # Set the port as DC Motor
        if MotorName == 1 or MotorName == 2:
            WriteByte(TB_1A_MODE,TB_DCM)
            WriteByte(TB_1A_DIR,TB_STOP)
            WriteByte(TB_1B_MODE,TB_DCM)
            WriteByte(TB_1B_DIR,TB_STOP)
        if MotorName == 3 or MotorName == 4:
            WriteByte(TB_2A_MODE,TB_DCM)
            WriteByte(TB_2A_DIR,TB_STOP)
            WriteByte(TB_2B_MODE,TB_DCM)
            WriteByte(TB_2B_DIR,TB_STOP)
    # Drive the DC Motor
    # Direction 1 CW | 2 CCW
    # PWNDuty  0 ~ 100
    def DCMotorMove(self, MotorName,Direction,PWMDuty):
        if MotorName == 1:
            WriteByte(TB_1B_DIR,Direction)
            WriteOneWord(TB_1B_DUTY,PWMDuty*10)
        if MotorName == 2:
            WriteByte(TB_1A_DIR,Direction)
            WriteOneWord(TB_1A_DUTY,PWMDuty*10)
        if MotorName == 3:
            WriteByte(TB_2B_DIR,Direction)
            WriteOneWord(TB_2B_DUTY,PWMDuty*10)
        if MotorName == 4:
            WriteByte(TB_2A_DIR,Direction)
            WriteOneWord(TB_2A_DUTY,PWMDuty*10)
    # Stop the DC motor
    def DCMotorStop(self, MotorName):
        if MotorName == 1:
        if MotorName == 2:
        if MotorName == 3:
        if MotorName == 4:
    # init the Servo
    def ServoInit(self,ServoName,Frequency):
        if ServoName == 1:
            WriteHalfWord(SVM1_FREQ,Frequency)
            WriteByte(SVM1_STATE,SVM_ENABLE)
        if ServoName == 2:
            WriteHalfWord(SVM2_FREQ,Frequency)
            WriteByte(SVM2_STATE,SVM_ENABLE)
        if ServoName == 3:
            WriteHalfWord(SVM3_FREQ,Frequency)
            WriteByte(SVM3_STATE,SVM_ENABLE)
        if ServoName == 4:
            WriteHalfWord(SVM4_FREQ,Frequency)
            WriteByte(SVM4_STATE,SVM_ENABLE)
        if ServoName == 5:
            WriteHalfWord(SVM5_FREQ,Frequency)
            WriteByte(SVM5_STATE,SVM_ENABLE)
        if ServoName == 6:
            WriteHalfWord(SVM6_FREQ,Frequency)
            WriteByte(SVM6_STATE,SVM_ENABLE)
    def ServoMoveAngle(self,ServoName,Angle):
        if ServoName == 1:
            WriteHalfWord(SVM1_ANGLE,Angle)
        if ServoName == 2:
            WriteHalfWord(SVM2_ANGLE,Angle)
        if ServoName == 3:
            WriteHalfWord(SVM3_ANGLE,Angle)
        if ServoName == 4:
            WriteHalfWord(SVM4_ANGLE,Angle)
        if ServoName == 5:
            WriteHalfWord(SVM5_ANGLE,Angle)
        if ServoName == 6:
            WriteHalfWord(SVM6_ANGLE,Angle)
def myloop():
    print 'Hello From MotorBridge'
    time.sleep(1)
    motor.StepperMotorBMove(-1000,1000) # 20 steppers  1000us every step
    time.sleep(1)
    motor.StepperMotorBMove(1000,1000)  # 20 steppers  1000us every step
    myloop()
if __name__=="__main__":
    motor = MotorBridgeCape()
    motor.StepperMotorBInit()
    myloop()
and...here is my idea of software.
import MotorBridge
import time
MotorName        = 1
MotorName        = 3
ClockWise        = 1
CounterClockWise = 2
PwmDuty          = 90
Frequency        = 1000
    motor = MotorBridge.MotorBridgeCape()
    motor.DCMotorInit(1, 1000)
    motor.DCMotorInit(3, 1000)
    for i in range(1, 51):
        motor.DCMotorMove(1, 1, 90)
        motor.DCMotorMove(3, 1, 90)
        print "I got your biscuit, now!"
#Making a U-Shape in the lawn
#Left motor on chassis goes while the right motor ccw
    for i in range(1, 3):
        motor.DCMotorMove(3, 2, 90)
        print "I love Jim's TURN!"
#All Flanks...Straight Ahead!
        print "Give in to temptation!"
#Make another U-Turn but this time, motors go in the opposite direction!
        motor.DCMotorMove(1, 2, 90)
#Straight Ahead
        print "Tacos are not all around here!"
This is the MBC.py software that I wrote but Seeed Studio had a Wiki. That Wiki helped me start out.
silver2row
Hello Sir,
I thought of one more thing. Usually w/ my MotorBridge.py software from Seeed Studio, I have to install python-smbus. I looked at my command dpkg -l and realized that python-smbus is not installed on my system.
I tried to install it and the system failed me. Is python-smbus not available w/ kernel 4.9.x. I am using python 2.7 instead of python 3.
Seth
P.S. If this matters, please let me know.
Not able to find python-smbus on my system...
silver2row
Hello Sir,
I realized too late that python-smbus does not exist anymore and it is needed w/ ,"I thought," python 2.7-Adafruit_BBIO stuff for I2C.
Seth
P.S. I have always had to get python-smbus for the MotorBridgeCape use.
silver2row
Hello Sir,
I know I am giving you a bunch of stuff to read and look over that may not have anything to do w/ what you normally work on. Please forgive me. See here: https://www.linuxcircle.com/2015/05/03/ ... -python-3/.
I installed python3-smbus, libi2c-dev and received the same errors from when running MBC.py, this my software to make my machinery work, on Python 3 on the BBG. That is just an update.
That is all, sir.
Seth
drewfustini
Post by drewfustini »
python-smbus does exist in Debian 9.3 (Stretch):
debian@beaglebone:~$ apt-cache search python-smbus
python-smbus - Python bindings for Linux SMBus access through i2c-dev
debian@beaglebone:~$ dpkg -l |grep smbus
ii  python-smbus:armhf                    3.1.2-3                                       armhf        Python bindings for Linux SMBus access through i2c-dev
debian@beaglebone:~$ dpkg -L python-smbus
/usr
/usr/lib
/usr/lib/python2.7
/usr/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages/smbus.arm-linux-gnueabihf.so
/usr/share
/usr/share/doc
/usr/share/doc/python-smbus
/usr/share/doc/python-smbus/changelog.Debian.gz
/usr/share/doc/python-smbus/changelog.gz
/usr/share/doc/python-smbus/copyright
Please try running:
sudo apt-get update && sudo apt-get install python-smbus
silver2row
That is so odd. I tried it earlier. It would not apt-get me a python-smbus.
Seth
P.S. Weird days, man. Thank you. I will get back to you.
silver2row
This is my output on the terminal screen when I run my software, mbcUse.py:
debian@beaglebone:~/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape$ sudo nano MotorBridge.py
debian@beaglebone:~/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape$ sudo python mbcUse.py
WARNING: THIS MODULE IS DEPRECATED. Use Adafruit_GPIO.I2C instead.
  File "mbcUse.py", line 13, in <module>
  File "/home/debian/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape/MotorBridge.py", line 279, in DCMotorInit
  File "/home/debian/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape/MotorBridge.py", line 221, in WriteOneWord
AttributeError: Adafruit_I2C instance has no attribute 'writeList'
Seth
P.S. If this helps, okay. If not, dang it!
drewfustini
Is mbcUse.py different than MBC.py?
If so, then post the code in a reply.
Here are my results running your MBC.py script with no modifcations to the Seeed's MotorBridge.py file:
debian@beaglebone:~/tmp/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape$ sudo python MBC.py
Error accessing 0x4B: Check your I2C address
^CTraceback (most recent call last):
  File "MBC.py", line 22, in <module>
  File "/home/debian/tmp/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape/MotorBridge.py", line 229, in __init__
    time.sleep(1)
KeyboardInterrupt
debian@beaglebone:~/tmp/MotorBridgeCapeforBBG_BBB/BBG_MotorBridgeCape$ cat MBC.py
import MotorBridge
import time
MotorName        = 1
MotorName        = 3
ClockWise        = 1
PwmDuty          = 90
Frequency        = 1000
#Straight Ahead
silver2row
Hello Sir,
mbcUse.py and MBC.py are the exact same software examples. I am doing something wrong. I will attempt to go back to the page and update my system. I will then add all required packages and then run the MBC.py/mbcUse.py software.
Seth
P.S. I think I may have figured out u-boot overlays. I took some time off of the BBB and got left in the dust. I was unaware of u-boot overlays. I see on my current image, my u-boot overlay has all the UART connections enabled. The i2c issues you are coming across only needs a "2" added to MotorBridge.py at MotorBridge = Adafruit_I2C(0x4b). So it would read MotorBridge = Adafruit_I2C(0x4b, 2) instead.
silver2row
Sir,
Here is the software you requested. This is the mbcUse.py/MBC.py software example.
import MotorBridge
import time
MotorName        = 1
MotorName        = 3
ClockWise        = 1
PwmDuty          = 90
Frequency        = 1000
#Straight Ahead
Seth
P.S. That should do it after you make the addition to the MotorBridge.py software.
silver2row
Hello Again,
Sir...what version of Adafruit_BBIO are you running on your system. I am running 1.0.10.
Seth
drewfustini
silver2row wrote:Hello Again,
Seth
I am running that version as well. It is the most recent version.
drewfustini
I would suggest that you fork the Seeed Studio MotorBridgeCapeforBBG_BBB repo. You can then add your files to the forked repo and push it to GitHub.
This will make it easier for others to see the changes you've made and reproduce errors that you experience.
silver2row
Yes Sir,
I am on it. Thank you for your help so far. I will add it to my repos and then make corrections. Wait...I have it in my repos. I will do some work on it.
Seth
Return to “Beagle Bone & Adafruit Beagle Bone products”
