I am currently attempting to run a 2.2” TFT LCD display (https://www.adafruit.com/product/1480) on a BeagleBone Green Wireless. I am following an Adafruit tutorial (found here https://learn.adafruit.com/user-space-s ... li9341-2-8 ). Though the tutorial is not specifically made for this configuration, Matthew McMillian has accomplished this and has his experience (http://matthewcmcmillan.blogspot.com/20 ... nWZkbrkNGJ) linked to in the Adafruit tutorial. After retrieving the Adafruit ILI9341 library the setup.py install script was run using the following command:
sudo python setup.py install
admini@beaglebone:~/Adafruit_Python_ILI9341-master$ sudo python examples/image.py
File "examples/image.py", line 41, in <module>
disp = TFT.ILI9341(DC, rst=RST, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE, max_speed_hz=64000000))
File "build/bdist.linux-armv7l/egg/Adafruit_ILI9341/ILI9341.py", line 137, in __init__
File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/GPIO.py", line 278, in setup
ValueError: Set gpio direction failed, missing file or invalid permissions.
cat /etc/issue
Debian GNU/Linux 9 \n \l
BeagleBoard.org Debian Image 2017-08-31
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
Default username:password is [debian:temppwd]
cat /etc/dogtag
uname –a
Linux beaglebone 4.9.45-ti-r57 #1 SMP PREEMPT Fri Aug 25 22:58:38 UTC 2017 armv71 GNU/Linux
Optargs=capemgr.enable_partno=BB-SPIDEVO
ls -la /dev/spi*
crw-rw---- 1 root spi 153, 1 Feb 27 17:00 /dev/spidev1.0
crw-rw---- 1 root spi 153, 1 Feb 27 17:00 /dev/spidev1.1
crw-rw---- 1 root spi 153, 1 Feb 27 17:00 /dev/spidev2.0
crw-rw---- 1 root spi 153, 1 Feb 27 17:00 /dev/spidev2.1
