No Activity on DO pin when using Adafruit_BBIO python librar
AlexEshoo
Post by AlexEshoo »
I'm having some trouble getting the SPI devices talking on the Beaglebone black. Here's my setup so far:
I've added the following to /boot/uEnv.txt:
cape_enable=bone_capemgr.enable_partno=cape-universala
note: I also have
cape_enable=bone_capemgr.enable_partno=BB-CAN1
in that file since I use canbus also. Not sure if this will cause an issue (?)
Then I rebooted and ran the following commands:
sudo config-pin P9.17 spi_cs
sudo config-pin P9.18 spi
sudo config-pin P9.21 spi
sudo config-pin P9.22 spi_sclk
Then I have a python script `spi_example.py`:
from Adafruit_BBIO.SPI import SPI
spi = SPI(1,0)
spi.msh = 1000000  # Set max speed to 1Mhz
print spi.xfer2([3])
spi.close()
when I run this ( sudo python spi_example.py) I see the following output:
[255]
Which doesn't seem right.
I also hooked a logic analyzer up to it and there is no activity on any of the pins when the script runs.
Is there something obvious I am doing wrong?
drewfustini
Re: No Activity on DO pin when using Adafruit_BBIO python li
Post by drewfustini »
Hello, I would like to know more about how your BeagleBone is configured.
Please paste the output of:
sudo /opt/scripts/tools/version.sh
cat /boot/uEnv.txt
AlexEshoo
Post by AlexEshoo »
Version Info:
git:/opt/scripts/:[4dd50b306e4eb31a05bb72a9573febc3695f1f05]
eeprom:[A335BNLT000C1631BBBG0778]
dogtag:[BeagleBoard.org Debian Image 2017-03-19]
bootloader:[/dev/mmcblk0]:[U-Boot 2017.03-00002-gd12b1519b4]
bootloader:[/dev/mmcblk1]:[U-Boot 2016.03-00001-gd12d09f]
kernel:[4.4.54-ti-r93]
nodejs:[v4.8.0]
uEnv.txt:
#Docs: http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
uname_r=4.4.54-ti-r93
#uuid=
#dtb=
##BeagleBone Black/Green dtb's for v4.1.x (BeagleBone White just works..)
##BeagleBone Black: HDMI (Audio/Video) disabled:
#dtb=am335x-boneblack-emmc-overlay.dtb
##BeagleBone Black: eMMC disabled:
#dtb=am335x-boneblack-hdmi-overlay.dtb
##BeagleBone Black: HDMI Audio/eMMC disabled:
#dtb=am335x-boneblack-nhdmi-overlay.dtb
##BeagleBone Black: HDMI (Audio/Video)/eMMC disabled:
#dtb=am335x-boneblack-overlay.dtb
##BeagleBone Black: wl1835
#dtb=am335x-boneblack-wl1835mod.dtb
##BeagleBone Green: eMMC disabled
#dtb=am335x-bonegreen-overlay.dtb
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
#enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/<file0>.dtbo
#uboot_overlay_addr1=/lib/firmware/<file1>.dtbo
#uboot_overlay_addr2=/lib/firmware/<file2>.dtbo
#uboot_overlay_addr3=/lib/firmware/<file3>.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/<file4>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless)
#disable_uboot_overlay_emmc=1
#disable_uboot_overlay_video=1
#disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
###Cape Universal Enable
#enable_uboot_cape_universal=1
###U-Boot fdt tweaks...
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable video=HDMI-A-1:1024x768@60e
##Example v3.8.x
#cape_disable=capemgr.disable_partno=
#cape_enable=capemgr.enable_partno=
##Example v4.1.x
#cape_disable=bone_capemgr.disable_partno=
#cape_enable=bone_capemgr.enable_partno=
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
drewfustini
Could you please try that latest BeagleBoard.org Debian image?
http://beagleboard.org/latest-images
I would recommend Debian 9.3 2018-03-05 4GB SD IoT image:
http://debian.beagleboard.org/images/bo ... 4gb.img.xz
AlexEshoo
Post by AlexEshoo »
I updated to the latest image as you suggested, but I can't seem to get the pin mux set up now.
git:/opt/scripts/:[e307a944e0be0610ff5296e0abe4ad31a6e70daa]
model:[TI_AM335x_BeagleBone_Black]
dogtag:[BeagleBoard.org Debian Image 2018-03-05]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.01-00002-ge9ff418fb8]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2016.03-00001-gd12d09f]:[location: dd MBR]
kernel:[4.9.82-ti-r102]
nodejs:[v6.13.0]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg:[bb-cape-overlays]:[4.4.20180305.0-0rcnee0~stretch+20180305]
pkg:[bb-wl18xx-firmware]:[1.20170829-0rcnee2~stretch+20180104]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee0~stretch+20170830]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.enable_partno=cape-universala root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable]
dmesg | grep pinctrl-single
[    1.396254] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[    1.397275] gpio-of-helper ocp:cape-universal: ready
END
uEnv.txt
uname_r=4.9.82-ti-r102
#uuid=
#dtb=
###Master Enable
###Additional custom capes
#uboot_overlay_addr4=/lib/firmware/<file4>.dtbo
#uboot_overlay_addr5=/lib/firmware/<file5>.dtbo
#uboot_overlay_addr6=/lib/firmware/<file6>.dtbo
#uboot_overlay_addr7=/lib/firmware/<file7>.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/<file8>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.4.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo
###pru_uio (4.4.x-ti, 4.14.x-ti & mainline/bone kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#cmdline=coherent_pool=1M net.ifnames=0 quiet video=HDMI-A-1:1024x768@60e
But when I run:
The output I get is:
P9_17 pinmux file not found!
Pin has no cape: P9_17
I'm not really sure where I've gone wrong.
drewfustini
I think one issue is that the bootloader installed on the eMMC is quite old:
Please run this script to update the bootloader on the eMMC:
/opt/scripts/tools/developers/update_bootloader.sh
Reboot and then run this script:
If "bootloader:[eMMC-(default)]:" is still the old version, then try running this command which will delete the bootloader from the eMMC (which is OK if you are running from SD card):
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=10
AlexEshoo
Post by AlexEshoo »
I updated the bootloader using the script provided, but it did not update the eMMC. I just booted with the push button, however and was able to use `config-pin` again successfully. And when I tried the SPI library again, the data transmission was successful verified by logic analyzer. Thanks for all your help.
I did have a couple follow up questions, however. The output of the python script is still `[255]` while the data transmitted is `[3]` is this to be expected?
Also I would really like a way to update the bootloader on the eMMC as well, is there a good guide for doing this you can point me to?
drewfustini
This command should remove the bootloader from the emmc:
Then run the update boot loader script again.
As for the output, please post the code that you are running.
AlexEshoo
Post by AlexEshoo »
Thanks, I'll try that for the bootloader.
I am running the same code from my original post. I did notice that the MISO line is high for the duration of the transmission since I'm just measuring the bus without connecting a slave and I imagine there's a pull-up resistor for that pin. Is the output of xfer2 the value read from the MISO line during transmission?
drewfustini
Yes, looking at the function:
https://github.com/adafruit/adafruit-be ... ule.c#L298
I believe the return value is what was received while transmitting.
Return to “Beagle Bone & Adafruit Beagle Bone products”
