BeagleBone Blue: Set gpio direction failed
by vmasan on Sun Jun 24, 2018 11:09 am
I'm using Cloud9 IDE to write code for BeagleBone Blue with Debian 9.4 2018-06-17 4GB SD LXQT installed (found here https://beagleboard.org/latest-images)
Here is the code:
import Adafruit_BBIO.GPIO as GPIO
GPIO.setup("P8_9", GPIO.IN)
GPIO.setup("P8_7", GPIO.OUT)
while True:
    if GPIO.input("P8_9"):
        GPIO.output("P8_7", GPIO.HIGH)
    else:
        GPIO.output("P8_7", GPIO.LOW)
According to this link https://github.com/beagleboard/beaglebone-blue/blob/master/BeagleBone_Blue_Pin_Table.csv, P8_9 is pause button and P8_7 is red LED.
But I get this error:
  File "/var/lib/cloud9/examples/blink.py", line 4, in <module>
ValueError: Set gpio direction failed, missing file or invalid permissions.
I have tried updating kernel and bootloader according to this issue on github https://github.com/adafruit/adafruit-beaglebone-io-python/issues/248, but that did not solve the problem.
Here is sudo /opt/scripts/tools/version.sh output:
git:/opt/scripts/:[31292bce1d4b35b497cc7a013d6d57e7e1f4f5c4]
eeprom:[A335BNLTBLA21712EL003553]
model:[TI_AM335x_BeagleBone_Blue]
dogtag:[BeagleBoard.org Debian Image 2018-06-17]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
kernel:[4.17.2-bone3]
nodejs:[v6.14.3]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.4.20180622.0-0rcnee0~stretch+20180622]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[roboticscape]:[0.4.4-git20180608.0-0rcnee0~stretch+20180609]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[    0.937803] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
Also, i have to mention that there's no problem runing this code:
So, there's no problem with LED pins. I tried another button (MODE_BTN) but same error.
Thanks.
vmasan
Re: BeagleBone Blue: Set gpio direction failed
by drewfustini on Tue Jul 03, 2018 4:28 pm
It would be helpful if you could run strace so that I can better understand what is happening.
Install strace (if it doesn't already exist):
sudo apt-get install strace
Then run strace, replace test.py with the name of your test program:
strace -f -o strace.log python test.py
Paste the contents of strace.log into a GitHub Gist and post the link in a reply here.
drewfustini
