LED Backpack not working on beaglebone black with debian 9.4
by TheGribble on Thu Aug 30, 2018 4:59 am
I've got a seven segment LED backpack I'm trying to get working with a beaglebone black. I've got a clean install of the latest stable BB image (Debian 9.4 2018-06-17 4GB SD IoT) and followed the instructions given here (https://learn.adafruit.com/led-backpack ... ack/wiring) until I try to run the sample code. I then get this error:
  File "sevensegment_test.py", line 33, in <module>
    display.begin()
  File "/usr/local/lib/python2.7/dist-packages/Adafruit_LED_Backpack-1.8.1-py2.7.egg/Adafruit_LED_Backpack/HT16K33.py", line 53, in begin
    self._device.writeList(HT16K33_SYSTEM_SETUP | HT16K33_OSCILLATOR, [])
  File "/usr/local/lib/python2.7/dist-packages/Adafruit_GPIO-1.0.3-py2.7.egg/Adafruit_GPIO/I2C.py", line 129, in writeList
    self._bus.write_i2c_block_data(self._address, register, data)
  File "/usr/local/lib/python2.7/dist-packages/Adafruit_PureIO-0.2.3-py2.7.egg/Adafruit_PureIO/smbus.py", line 294, in write_i2c_block_data
    self._device.write(data)
IOError: [Errno 16] Device or resource busy
If I run i2cdetect it seems to find the backpack on the right address:
i2cdetect -r 2
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-2 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- UU UU UU UU -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
root@beaglebone:~/Adafruit_Python_LED_Backpack/examples#
Has anybody got any ideas?
TheGribble
Re: LED Backpack not working on beaglebone black with debian
by drewfustini on Thu Aug 30, 2018 12:58 pm
It is import to know what versions of software you have installed on your BeagleBone, especially the version of u-boot bootloader on the eMMC.
Please run:
sudo /opt/scripts/tools/version.sh
and copy the output into your reply.
Also, please upload a photo that shows how the hardware is connected.
drewfustini
by TheGribble on Fri Aug 31, 2018 7:22 am
Hiya, thanks for getting back!
Here's the output of the version script:
debian@beaglebone:~/Adafruit_Python_LED_Backpack/examples$ sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[31292bce1d4b35b497cc7a013d6d57e7e1f4f5c4]
eeprom:[A335BNLT00C04815BBBK0BA1]
model:[TI_AM335x_BeagleBone_Black]
dogtag:[BeagleBoard.org Debian Image 2018-06-17]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
kernel:[4.14.49-ti-r54]
nodejs:[v6.14.3]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.4.20180611.0-0rcnee0~stretch+20180611]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[roboticscape]:[0.4.4-git20180608.0-0rcnee0~stretch+20180609]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[    1.062655] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[    1.069381] gpio-of-helper ocp:cape-universal: ready
END
I've attached a photo of the setup; I believe I've wired the beaglebone to the display as in the diagram (pins 1, 5, 19, 20), the only other connectionsare the wires from pins 2 and 6 to a 5V bench supply to power the board:
One thing I forgot to say earlier - the first time I ran the example I got an error
ImportError: No module named Adafruit_PureIO.smbus
so I installed it using
 git clone https://github.com/adafruit/Adafruit_Python_PureIO.git
Thanks again for your help,
Ben.
TheGribble
by TheGribble on Fri Aug 31, 2018 7:40 am
I've been playing with it and I seem to be reading registers successfully from the backpack using i2cget:
$ i2cget -y 2 0x70 0
0x98
I've watched the traffic with a logic analyser and it all looks as it should, so I'm pretty sure the wiring is correct. When I run the sample I don't see anything on the analyser at all.
Cheers,
Ben.
TheGribble
by drewfustini on Sat Sep 01, 2018 4:28 am
It would be helpful if you could run strace so that I can better understand what is happening.
Install strace (if it doesn't already exist):
sudo apt-get install strace
Then run strace, replace test.py with the name of your test program:
strace -f -o strace.log python sevensegment_test.py
Paste the contents of strace.log into a GitHub Gist and post the link in a reply here.
drewfustini
by TheGribble on Mon Sep 03, 2018 4:17 am
TheGribble
by drewfustini on Thu Sep 06, 2018 7:55 pm
Thanks for the strace output.
This seems like the relevant lines:
4414  open("/dev/i2c-1", O_RDWR|O_LARGEFILE) = 3
4414  fstat64(3, {st_mode=S_IFCHR|0660, st_rdev=makedev(89, 1), ...}) = 0
4414  ioctl(3, _IOC(0, 0x07, 0x03, 0x00), 0x70) = 0
4414  write(3, "!", 1)                  = -1 EBUSY (Device or resource busy)
Python is trying to access /dev/i2c-1
Please run strace with i2cdetect as I would like to verify it is using the name device path:
strace -f -o strace.log python i2cdetect -r 2
drewfustini
by TheGribble on Fri Sep 07, 2018 6:58 am
Gist from strace i2cdetect is here: https://gist.github.com/TheGribble/e45c3c948f88944e50a6bb27f637fb1c
Cheers,
Ben.
TheGribble
by drewfustini on Mon Sep 10, 2018 12:08 am
Thanks. Looking at the strace output:
3347 open("/dev/i2c-2", O_RDWR) = 3
It looks like i2cdetect has opened /dev/i2c-2.
However, Python was trying to access /dev/i2c-1.
Could you post the code for sevensegment_test.py?
I think there should be a place to change the I2C bus that is being used.
drewfustini
by drewfustini on Mon Sep 10, 2018 12:13 am
I see the code located at https://github.com/adafruit/Adafruit_Py ... nt_test.py
I think that this should be commented out:
# Create display instance on default I2C address (0x70) and bus number.
display = SevenSegment.SevenSegment()
And this should be uncommented:
# Alternatively, create a display with a specific I2C address and/or bus.
# display = SevenSegment.SevenSegment(address=0x74, busnum=1)
Then try changing busnum=1 to busnum=2
drewfustini
by TheGribble on Mon Sep 10, 2018 7:19 am
Got it, thank you!
The magic combination was:
display = SevenSegment.SevenSegment(address=0x70, busnum=2)
so I'm all up and running now.
I'm now a bit surprised by the demo though - has this always been broken on the Beaglebone or have I not followed the wiring instructions correctly?
Either way, thanks for all of your help!
Ben.
TheGribble
by drewfustini on Tue Sep 11, 2018 2:39 am
Good to hear.
There was a change in the past in how the i2c devices are enumerated.
I'll take a look at creating a pull request.
drewfustini
by drewfustini on Tue Sep 11, 2018 3:45 am
fyi - I have created this pull request:
Adafruit_Python_LED_Backpack #26
drewfustini
by TheGribble on Thu Sep 13, 2018 8:44 am
Excellent, thanks for all your help!
TheGribble
