Problems to define a GPIO pin as input in Begalebone black
Re: Problems to define a GPIO pin as input in Begalebone bl
by NICOCASAL on Fri Oct 12, 2018 1:36 pm
Thank you
I was able to solve the problem using the sudo python command.
However, I still can not enable the permanent internet connection ( when the BBB boot).
I also need a command that allows me to run several programs (codes) automatically when the BBB boot (turns off and on).
Can you please help me to find the correct commands?
Best regards
Hugo
NICOCASAL
by drewfustini on Tue Oct 16, 2018 11:25 am
NICOCASAL wrote:Thank you
Are you using Ethernet or WiFi?
To run a command automatically, you can configure systemd to run a service:
systemd: Writing and Enabling a Service
drewfustini
by NICOCASAL on Mon Oct 22, 2018 12:29 am
thank very much
I am using the internet sevice through cellular router( Digi WR11).
Now , I have already permanent internet service. The following step is to run the scripts automatically when the BBB reboot or power on.
To test I am using the code to blink USR3 led ( see examples/robot path in the folder cloud9 ).
I used the following commands:
root@beaglebone:/var/lib/cloud9# crontab -e
In nano editor :
@reboot /var/lib/cloud9/examples/ robot /blink.py
But it does not work .
Can you please give me some suggest?
Regards
Hugo
NICOCASAL
by drewfustini on Tue Oct 23, 2018 8:08 pm
This does not look like a valid command:
It appears that you may have spaces in that path: "/ robot /"
If there are in fact spaces in the directory name, I would suggest renaming it without spaces.
drewfustini
by NICOCASAL on Wed Oct 24, 2018 4:36 pm
Hello
I already can to run the scripts automatically , but now I have a problem .
When I run any script in cloud9( inside BBB) in automatic mode ( running at startup), ie, at reboot or power on and off the unit and if I include the command line GPIO.setup("Px_xx",GPIO.IN) , the program don't execute. However , when I run the same scripts without this line , it works well.
I tested with several GPIO inputs pins and the same always happens
Also, when I run the same scripts in manual mode in cloud9 , all work well.
How Can I see the errors in the scripts
Do you have some idea what happen?
Bellow , I show one simple script :
import Adafruit_BBIO.GPIO as GPIO
import time
GPIO.setup("P9_16",GPIO.IN) # this line is the problem
GPIO.setup("USR3",GPIO.OUT)
while True:
GPIO.output("USR3",GPIO.HIGH)
time.sleep(2)
GPIO.output("USR3",GPIO.LOW)
time.sleep(2)
Thank you in advance
Hugo
NICOCASAL
by NICOCASAL on Wed Oct 24, 2018 11:29 pm
Hello again
I forgot send you the error message.
Bellow can you find it
I tested a bit more and I saw this happen if I configure any GPIO pin as input or output in the same script where USRx pin is used.
Regard
Hugo
Important: use os.getenv(PORT, 8080) as the port and os.getenv(IP, 0.0.0.0) as the host in your scripts!
File "/var/lib/cloud9/Telemetria/alarmaprueba3.py", line 5, in <module>
ValueError: Set gpio direction failed, missing file or invalid permissions.
NICOCASAL
by drewfustini on Sun Oct 28, 2018 9:58 pm
It is important to see the output of the version script to determine if your BeagleBone is configured correctly.
Please try running this script:
sudo /opt/scripts/tools/version.sh
and paste the output in your reply.
drewfustini
by NICOCASAL on Sun Oct 28, 2018 11:23 pm
Thank you
Here the output of the version script.
root@beaglebone:~# sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[73593ebe3b7d3cc381eeb502d45ccb33a6ec5e78]
eeprom:[A335BNLT000C1820BBBG1530]
model:[TI_AM335x_BeagleBone_Black]
dogtag:[BeagleBoard.org Debian Image 2018-08-30]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
kernel:[4.14.67-ti-r73]
nodejs:[v6.14.4]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.4.20180803.0-0rcnee0~stretch+20180804]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[librobotcontrol]:[1.0.2-git20180829.0-0rcnee0~stretch+20180830]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[ 1.099565] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[ 1.111578] gpio-of-helper ocp:cape-universal: ready
END
Regards
Hugo
NICOCASAL
by drewfustini on Tue Oct 30, 2018 1:19 pm
Thanks, I will try to reproduce this issue when running in the Cloud9 IDE on my BeagleBone Black
drewfustini
by NICOCASAL on Mon Nov 12, 2018 12:26 am
Hello Drew
Did you have opportunity to revise my problem?
Hugo
NICOCASAL
by drewfustini on Tue Nov 20, 2018 3:14 am
From the console terminal inside Cloud9, please run these commands and paste the output:
id
grep gpio /etc/group
ls -l /sys/class/gpio/gpio*/value
drewfustini
by HUGOCASAL on Tue Nov 20, 2018 3:30 pm
Hello
This is the information
Regards
debian@beaglebone:/var/lib/cloud9$ id
uid=1000(debian) gid=1000(debian) groups=1000(debian),4(adm),15(kmem),20(dialout),24(cdrom),25(floppy),29(audio),30(dip),44(video),46(plugdev),100(users),101(systemd-journal),108(i2c),111(bluetooth),112(netdev),115(cloud9ide),992(xenomai),993(weston-launch),994(tisdk),995(spi),996(admin),997(eqep),998(pwm),999(gpio)
debian@beaglebone:/var/lib/cloud9$ grep gpio /etc/group
gpio:x:999:debian
debian@beaglebone:/var/lib/cloud9$ ls -l /sys/class/gpio/gpio*/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio10/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio110/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio111/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio112/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio113/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio114/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio115/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio116/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio117/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio11/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio12/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio13/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio14/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio15/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio20/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio22/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio23/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio26/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio27/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio2/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio30/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio31/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio32/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio33/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio34/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio35/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio36/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio37/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio38/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio39/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio3/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio44/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio45/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio47/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio48/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio49/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio4/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio50/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio51/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio5/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio60/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio61/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio62/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio63/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio65/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio66/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio67/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio68/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio69/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio70/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio71/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio72/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio73/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio74/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio75/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio76/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio77/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio78/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio79/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio7/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio80/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio81/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio86/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio87/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio88/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio89/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio8/value
-rw-rw-r-- 1 root gpio 4096 Dec 31 1999 /sys/class/gpio/gpio9/value
HUGOCASAL
by drewfustini on Wed Nov 21, 2018 4:43 am
Thanks. I am asking Robert C Nelson who creates the BeagleBone Debian images. I think it may be an issue that the Cloud9 IDE user is not in the gpio group. I will followup after I hear back from Robert.
drewfustini
cron
