GPIO PULL-UP with BBIO not Working
by stumpja on Wed Jan 30, 2019 3:28 pm
I am admittedly new to the BBB and python scripting, but I've made some progress today. However, I have come to my first hard stop.
I'm trying to set up a couple inputs to have pull-ups enabled, but this seems to spit out the following error:
debian@beaglebone:/home/Python_Files$ sudo python fanTest.py
  File "fanTest.py", line 11, in <module>
    GPIO.setup(DISP_DOWN,GPIO.IN,pull_up_down=GPIO.PUD_UP)
ValueError: Set gpio mode failed, missing file or invalid permissions.
I have googled the error, and there are lots of suggestions, like old bootloader, and update library, all of which I think I have done. Many ask for the user to check the following.
sudo /opt/scripts/tools/version.sh
and
dmesg | grep bone
For completeness, I have done this as well. The results are as follows:
debian@beaglebone:/$ sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[bcfc0750f1851ba2d2809b3fdaa13ccea688f25e]
eeprom:[A335BNLT00C02818BBBK0B50]
model:[TI_AM335x_BeagleBone_Black]
dogtag:[BeagleBoard.org Debian Image 2018-10-07]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.09-00002-g0b54a51eee]:[location: dd MBR]
kernel:[4.14.71-ti-r80]
nodejs:[v6.14.4]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.4.20180928.0-0rcnee0~stretch+20180928]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[librobotcontrol]:[1.0.3-git20181005.0-0rcnee0~stretch+20181005]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[    1.102871] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[    1.114701] gpio-of-helper ocp:cape-universal: ready
END
debian@beaglebone:/home/Python_Files$ dmesg | grep bone
[    0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[   26.896995] systemd[1]: Set hostname to <beaglebone>.
The code I am executing is as follows. I know I am likely doing something wrong with the wait_for_edge stuff, but I haven't made it far enough along to really debug.
import Adafruit_BBIO.GPIO as GPIO
import Adafruit_BBIO.PWM as PWM
from time import sleep
DISP_UP="P9_42"
DISP_DOWN="P9_25"
DISP_LEFT="P8_26"
DISP_RIGHT="P9_41"
DISP_ENTER="P9_27"
FAN_DRV="P8_19"
GPIO.setup(DISP_UP,GPIO.IN,pull_up_down=GPIO.PUD_UP)
PWM.start(FAN_DRV,0,25000)
while(1):
   if GPIO.wait_for_edge(DISP_UP,GPIO.FALLING):
      PWM.set_duty_cycle(FAN_DRV,35)
   if GPIO.wait_for_edge(DISP_DOWN,GPIO.FALLING):
      PWM.set_duty_cycle(FAN_DRV,0)
   if GPIO.wait_for_edge(DISP_UP,GPIO.FALLING) and GPIO.wait_for_edge(DISP_DOWN,GPIO.FALLING):
      break
   sleep(0.2)
GPIO.cleanup()
PWM.stop(FAN_DRV)
PWM.cleanup()
Clearly I'm doing something stupid. Any ideas?
stumpja
Re: GPIO PULL-UP with BBIO not Working
by stumpja on Wed Jan 30, 2019 4:31 pm
UPDATE:
So made it farther. I can use all my buttons, just now my down button which is connected to "P9_25". Is there something about this pin that doesn't like the GPIO calls and can it be fixed?
I found the config-pin command line call, and tried to configure this pin as gpio but error message occurred. I think I found the issue, I just don't know how to fix it.
debian@beaglebone:/home/Python_Files$ config-pin P9.25 gpio
P9_25 pinmux file not found!
bash: /sys/devices/platform/ocp/ocp*P9_25_pinmux/state: No such file or directory
Cannot write pinmux file: /sys/devices/platform/ocp/ocp*P9_25_pinmux/state
Latest code:
from threading import Timer
DISP_UP="P9_42"
DISP_DOWN="P9_25"
DISP_LEFT="P8_26"
DISP_RIGHT="P9_41"
DISP_ENTER="P9_27"
FAN_DRV="P8_19"
GPIO.setup(DISP_UP,GPIO.IN,GPIO.PUD_UP)
GPIO.setup(DISP_ENTER,GPIO.IN,GPIO.PUD_UP)
GPIO.setup(DISP_LEFT,GPIO.IN,GPIO.PUD_UP)
GPIO.setup(DISP_RIGHT,GPIO.IN,GPIO.PUD_UP)
def debounce(wait):
    """ Decorator that will postpone a functions
        execution until after wait seconds
        have elapsed since the last time it was invoked. """
    def decorator(fn):
        def debounced(*args, **kwargs):
            def call_it():
                fn(*args, **kwargs)
            try:
                debounced.t.cancel()
            except(AttributeError):
                pass
            debounced.t = Timer(wait, call_it)
            #TODO: does this spawn too many threads on repeated calls and t.can$
            debounced.t.start()
        return debounced
    return decorator
@debounce(0.1) #debounce to call event only after stable for 0.1s
def gpioEventDebounce(gpio):
    """gpioEventDebounce is a wrapper around gpioEvent which fires after a rese$
    the debounce decorator sets the delay time in seconds"""
    print('event on',gpio)
GPIO.add_event_detect(DISP_UP,GPIO.FALLING,gpioEventDebounce)
GPIO.add_event_detect(DISP_ENTER,GPIO.FALLING,gpioEventDebounce)
GPIO.add_event_detect(DISP_LEFT,GPIO.FALLING,gpioEventDebounce)
GPIO.add_event_detect(DISP_RIGHT,GPIO.FALLING,gpioEventDebounce)
while(1):
        if GPIO.event_detected(DISP_UP):
        if GPIO.event_detected(DISP_ENTER):
        if GPIO.event_detected(DISP_LEFT):
                break
        if GPIO.event_detected(DISP_RIGHT):
                break
        sleep(0.2)
sleep(0.25)
GPIO.cleanup()
PWM.stop(FAN_DRV)
PWM.cleanup()
stumpja
by drewfustini on Mon Feb 04, 2019 10:04 pm
I can reproduce this as well:
debian@beaglebone:~$ sudo strace -o /tmp/strace python ./test.py
  File "./test.py", line 5, in <module>
With strace, I can see that:
3062  open("/sys/devices/platform/ocp/ocp:P9_25_pinmux/state", O_WRONLY|O_CREAT|O_TRUNC, 0666) = -1 ENOENT (No such file or directory)
This pin should be available as GPIO. I will followup with Robert Nelson who creates the BeagleBoard.org Debian images and kernel builds, and I will see what insights he may have. I suspect something will need to be changed in /boot/uEnv.txt so that this pin can be controlled by config-pin.
drewfustini
by stumpja on Tue Feb 05, 2019 9:16 am
drewfustini Looks like you are the adafruit beaglebone expert, and an extremely helpful one at that.
The answer to the latest issue in this thread can be found in another thread, which links another thread. :) That was fun.
Basically, in order for myself to set P9_25 as an input, I had to edit /boot/uEnv.txt, as you surmised. Uncommenting the following line did the trick.
disable_uboot_overlay_audio=1
So that worked, but it worked for several pins. In the original thread this solution was to fix P9_28. If Robert can shed more light on this, or point to a place that can, I would be very interested.
Thanks again for all your help!
stumpja
by drewfustini on Tue Feb 05, 2019 1:41 pm
Robert informs me that P9_25 is mcasp0_ahclkx which is used by HDMI Audio. Thus, disabling audio should be enough to allow it to be used as GPIO.
drewfustini
