BBB SPI simple BBIO example?
by jamieson_olsen on Fri May 03, 2019 1:34 pm
I have the BBB board flashed with the latest image. Trying to get a simple SPI python program up and running:
from Adafruit_BBIO.SPI import SPI
spi = SPI(0,0)
spi.close()
Running it returns:
IOError: [Errno 2] No such file or directory
So far the forum posts I've found talk about capes and slot files and kernel overlays -- it's my understanding that all of this low level stuff has changed.
Is there an up to date tutorial with a simple example showing how I can access SPI0 on my BBB?
jamieson_olsen
Re: BBB SPI simple BBIO example?
by drewfustini on Tue May 07, 2019 7:59 am
I'd like to know more about the configuration of your BeagleBone.
Please paste the output of:
sudo /opt/scripts/tools/version.sh
and please paste the output of:
ls -la /dev/spidev*
If you are able to, then it would also be helpful to see the output from strace which shows which system calls were issued:
Run:
sudo strace -f -o /tmp/strace.log python ./name-of-your.py
grep spidev /tmp/strace.log
drewfustini
