IDE Setup Issues for BBB
by bRitch022 on Wed Jun 12, 2019 12:43 pm
Hey all,
I'm new to the BBB, and I've been trying to get a test project set up using PyCharm so that I can test a few functions, such as GPIO, I2C, and SPI before I connect to the BBB. So far I am not having much luck installing the Adafruit_BBIO library. I am getting some weird errors with '/Werror' when trying to execute cl.exe (see attachment)
My question: What is the best IDE to use to program the BBB with python? Is it possible from a windows system? I'm on Windows 7
Package install failure
Installed packages
Pycharm packages.PNG (86.67 KiB) Viewed 390 times
bRitch022
Re: IDE Setup Issues for BBB
by drewfustini on Wed Jun 12, 2019 4:29 pm
I don't think it would be possible to run the Adafruit_BBIO under windows. It is specifically meant to run on the BeagleBone.
I would recommend trying the browser-based Cloud9 IDE that is built-in to the BeagleBone:
https://beagleboard.org/Support/bone101
drewfustini
by bRitch022 on Mon Jun 17, 2019 5:16 pm
This makes sense -- What is an alternative for debugging on a windows PC?
bRitch022
by drewfustini on Mon Jun 17, 2019 6:26 pm
The Cloud9 IDE both Run and Debug options in it.
Also, there is a terminal ("shell") built-in to the CloudIDE so you can run command line programs through the BeagleBone on it.
drewfustini
