Adafruit_BBIO.GPIO troubles with systemd service
by ManMan88 on Wed Sep 04, 2019 7:09 am
I'm using Beaglebone Black c, with Ubuntu 18.04.3 LTS running on a 16gb sd card.
I have a python script which uses the Adafruit_BBIO.GPIO module.
This script runs just fine when it is launched manually.
I want this script to run automatically when BBB boots.
So I created a systemd service for that.
The service runs the script, however, it encounters permission errors:
Sep 04 10:40:34 arm python[2506]: Adafruit_BBIO: gpio_export: 66 couldn't write "/sys/class/gpio/export": 1-Operation not permitted
Sep 04 10:40:34 arm python[2506]: Adafruit_BBIO: gpio_set_direction(): 66 couldn't open '/sys/class/gpio/gpio66/direction': 2-No such file or directory
These errors are the result of calling the command:
GPIO.setup("P8_7", GPIO.OUT)
I tried so many things to fix it with no success.
Mainly, I tried to change the /sys/class/gpio/export (and others) permission with chmod or chgrp - nothing worked.
This is my service:
[Unit]
Description="bringup beaglebone_upstart"
After=network.target
[Service]
Type=simple
ExecStart=/usr/sbin/beaglebone_upstart-start
WorkingDirectory=/home/ubuntu
[Install]
WantedBy=multi-user.target
The /usr/sbin/beaglebone_upstart-start ultimately launches a ROS launch file which runs a python script (ROS node) which uses the Adafruit_BBIO.GPIO module.
Again - this works fine when launched manually with roslaunch... or with python <script.py>.
Does anyone has an idea how to solve it?
Thank you!
ManMan88
Re: Adafruit_BBIO.GPIO troubles with systemd service
by drewfustini on Thu Oct 10, 2019 7:43 am
I think this could be related to not having the correct udev rules on
the Ubuntu image you are using.
I'll check with Robert Nelson who I believe produces the Ubuntu image.
He also does the official BeagleBoard.org Debian images and kernel
builds.
drewfustini
