AM2320 Beaglebone Black
ohnomrbill
Post by ohnomrbill »
Looking for documentation on interface of AM2320 to SDA/SCL on BeagleBone Black. CircuitPython install stuck on "Failed building wheel for hidapi"
drewfustini
Re: AM2320 Beaglebone Black
Post by drewfustini »
Is this the library that you are using?
https://github.com/adafruit/Adafruit_Ci ... hon_AM2320
Please run this command on your BeagleBone so I can view the version of Debian, kernel, and other configuration information:
sudo /opt/scripts/tools/version.sh
ohnomrbill
sorry for the delay... here goes:
git:/opt/scripts/:[029041f6866049997bbfd2c7667b3c6e8c95201c]
eeprom:[A335BNLT00A64313BBBK1801]
model:[TI_AM335x_BeagleBone_Black]
dogtag:[BeagleBoard.org Debian Stretch IoT Image 2020-06-01]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g31a8ae0206]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2015.10-00001-g143c9ee]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-14-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0]
kernel:[4.14.108-ti-r135]
nodejs:[v6.17.0]
/boot/uEnv.txt Settings:
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20200709.0-0~stretch+20200709]
pkg:[bb-wl18xx-firmware]:[1.20200702.0-0~stretch+20200702]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~stretch+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~stretch+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input i2c bluetooth netdev gpio admin spi iio docker tisdk weston-launch xenomai cloud9ide pwm eqep remoteproc]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 1.012934] remoteproc remoteproc0: wkup_m3 is available
[ 1.225328] remoteproc remoteproc0: powering up wkup_m3
[ 1.225445] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 1.229964] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 72.260029] remoteproc remoteproc1: 4a334000.pru is available
[ 72.278886] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 71.500753] pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 72.260159] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully
[ 72.279005] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully
dmesg | grep pinctrl-single
[ 0.696727] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[ 0.709360] gpio-of-helper ocp:cape-universal: ready
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
drewfustini
Please post the full text from the terminal when running the CircuitPython library, or attach a screenshot of the terminal window.
Also, the eMMC bootloader is too old (year 2015) and is blocking the newer one installed on the microSD. This can often cause problems for setting the pins to the correct mode for a given functionality.
Run this command to remove the u-boot bootloader on the eMMC:
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=10
ohnomrbill
thank you.... that worked to correct the boot loader...
drewfustini
Do you still get an error when installing the library?
ohnomrbill
Have not been able to install CircuitPython on the Beaglebone. Working through the layers of instructions...
drewfustini
You won't need CircuitPython itself, but instead Blinka (which is a CircuitPython compatibility layer for Linux boards) and the CircuitPython library that you want to use.
Have you tried installing Blinka?
Here are the instructions:
https://github.com/adafruit/Adafruit_Bl ... -from-pypi
Please paste the results so I can try to reproduce any errors.
ohnomrbill
pip3 install Adafruit-Blinka
Installing collected packages: RPi.GPIO, rpi-ws281x, sysv-ipc, pyusb, aenum, pyserial, pyftdi, Adafruit-PlatformDetect, Adafruit-Blinka
Successfully installed Adafruit-Blinka-5.2.3 Adafruit-PlatformDetect-2.14.1 RPi.GPIO-0.7.0 aenum-2.2.4 pyftdi-0.51.2 pyserial-3.4 pyusb-1.0.2 rpi-ws281x-4.2.4 s ysv-ipc-1.0.1
Will install libraries next...
ohnomrbill
from the 6.x bundle copied adafruit_am2320.mpy to /usr/local/lib/python3.5/dist-packages. This is the same folder as busio.py and board.py
Ran python3 am2320_simpletest.py
File "am2320_simpletest.py", line 4, in <module>
import adafruit_am2320
ImportError: No module named 'adafruit_am2320'
ohnomrbill
Downloaded bundle-py and moved adafruit_am2320.py and folder 'adafruit_bus_device' to /usr/local/lib/python3.5/dist-packages/
Ran am2320_simpletest.py successfully..
Thank you for your help.. I am a happy camper...
ohnomrbill
you were correct about retries. I am having to use try/except logic.
Return to “Beagle Bone & Adafruit Beagle Bone products”
