Getting started with Adafruit_BBIO - pip install failing
by stlentz on Sat May 16, 2020 11:05 am
I have a new BBB and have installed the Buster IoT image 2020-04-06. I am following the instructions here:
https://learn.adafruit.com/setting-up-i ... -on-ubuntu
However, sudo pip install Adafruit_BBIO is failing at the arm-linux-gnueabinhf-gcc step with numerous errors starting with this:
source/py_gpio.c:558:14: error: cast between incompatible function types from ‘PyObject * (*)(PyObject *, PyObject *, PyObject *)’ {aka ‘struct _object * (*)(struct _object *, struct _object *, struct _object *)’} to ‘PyObject * (*)(PyObject *, PyObject *)’ {aka ‘struct _object * (*)(struct _object *, struct _object *)’} [-Werror=cast-function-type]
Any idea what I am missing?
Let me know if you want the full error dump.
Thanks in advance for any help.
stlentz
Re: Getting started with Adafruit_BBIO - pip install failing
by drewfustini on Sat May 16, 2020 3:10 pm
I need to try to reproduce this myself to see what the cause is.
However, one guess is that it is using Python 2 and not Python 3.
Can you try pip3 instead?
drewfustini
by stlentz on Sat May 16, 2020 3:52 pm
Hmm, that's interesting:
debian@beaglebone:/var/lib/cloud9$ sudo pip3 install Adafruit_BBIO
[sudo] password for debian:
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: Adafruit_BBIO in /usr/local/lib/python3.7/dist-packages/Adafruit_BBIO-1.1.1-py3.7-linux-armv7l.egg (1.1.1)
I guess I can get on with using it then.
And yes, pip was using Python 2.7.
Thanks for looking at this, might want to update the old tutorial pages.
stlentz
by sam_bristow on Wed Jul 15, 2020 1:06 am
The issue you are seeing is because the package on PyPI hasn't been updated in quite a while and is missing some fixes for newer compilers.
In particular https://github.com/adafruit/adafruit-be ... issues/308
You could grab the latest version from github which should work, otherwise it's a matter of waiting for a new build to be uploaded to PyPI (I've opened a ticket for this).
sam_bristow
by drewfustini on Fri Jul 17, 2020 6:43 am
Thanks for raising this issue. I'll make a new release.
drewfustini
