UNIBBB case
UNIBBB case
by jmd2777 on Thu Feb 04, 2021 3:32 pm
Hi.
I recently bought 3 UNIBBB cases. On all 3 cases the top fits loosely in the case. If I turn the case vertical, the top falls out. This happens with either the mesh top or the slotted top. What is supposed to hold the top in place? Is it just a spring fit? Or is there supposed to be a ledge that holds the top? The instructions say "Install top cover by using slits on inside of case". I don't see any slits.
I want to know if mine are defective or if I'm not using it correctly.
Thank you.
jmd2777
Re: UNIBBB case
by drewfustini on Thu Feb 04, 2021 3:58 pm
Normally we try to handle troubleshooting of BeagleBone hardware and software issues on here rather than through the Adafruit support email. But I think in this case, please email support@adafruit.com as I've not used this case myself.
[update: I wrote the wrong email address initially, and I have changed it to the correct address: support@adafruit.com]
drewfustini
Re: UNIBBB case
by adafruit2 on Thu Feb 04, 2021 6:46 pm
its been a while since we put one together but from what i recall, it just sits on top, there's no mechanical thing keeping it there (other than gravity) and the paperclip lets you fish it off.
adafruit2
Site Admin
Re: UNIBBB case
by jmd2777 on Fri Feb 12, 2021 12:56 pm
The support department only pointed me back to this thread. So it seems like the top for this case is not designed to fit securely. I will post this to help anyone else who may be considering the UniBBB case. It comes with mounting holes and mounting screws. This makes it seem like you could attach it to a wall or behind a desk. However if you try to mount the UniBBB vertically, the top will fall off. As adafruit2 said, it is only gravity holding the top on.
jmd2777
