Can;t install Adafruit_BBIO
szlztt
Post by szlztt »
Bought BBB from Adafruit. Angstrom Dist. When I try to install the Adafruit_BBIO I get the following error message:
Unknown package 'Adafruit_BBIO'.
Don't know what to do from here??
0miker0
Re: Can;t install Adafruit_BBIO
Post by 0miker0 »
Very odd. I have also purchased the BBB from Adafruit and have never had trouble installing Adafruit_BBIO. Exactly what text are you entering?
szlztt
Post by szlztt »
Thank you for your reply. I am happy to get help on this!
I am attempting to work through the PDF book "Getting started with BeagleBone" by Matt Richardson. Being a Newbie to Linux I decided to start simple. In Chapter 4 he suggests to load the Adafruit python library as follows from the Kernal at the prompt root@beaglebone:~#:
"opkg python-pip python-setuptools python-smbus"
When doing so I get a message as follows:
python-pip "library does not exist"
python-setuptools "library does not exist"
and the same for the -smbus
Then I tried: pip install Adafruit_BBIO
and get the following " pip tool does not exist" so it didn't get loaded
when I type : python
I do get:
Python 2.7.3 (default, May 29 2013, 21:25:00)
[GCC 4.7.3 20130205 (prerelease)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
So python is installed correctly on the BBB.
I also cannot get the time and date to update properly when using : "pool.ntp.org
it has been suggested that I reload the Angstrom image and flash it from the SD card. Do you think that would help? Should I use Debian instead?
Hope this helps.
Thank you again
adafruit_support_mike
Are you using Angstrom or Debian as the OS on your BBB?
szlztt
Post by szlztt »
Mike,
Thanks. I am using angstrom but I found the issue and I made the changes and managed to work it out. Turns out I needed to configure my local network connections to allow the BBB to access the internet connection through my computer then I had to go the the BBB kernel and modify a resolv.conf file in the /etc directory essentially telling the BBB to use the computer's URL to communicate through. After that I was able to opkg the python pip and load the Adafruit_BBIO library, blink an LED and even set the correct time which also was eluding me.
I followed this video http://www.youtube.com/watch?v=fzRVVtGNfj8
Thanks again for the help.
Glad to hear you got it working. ;-)
szlztt
Post by szlztt »
CAn someone please tell me where the link is to post a new topic?
drewfustini
Post by drewfustini »
This is the link to post a new topic in this "Beagle Bone & Adafruit Beagle Bone products" forum:
posting.php?mode=post&f=49
Here's an overview of how the Adafruit forums work:
https://www.youtube.com/watch?v=HnTXXu9Bve0
Return to “Beagle Bone & Adafruit Beagle Bone products”
