Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
BeagleBone: Speed of I2C bus
by vex73 on Thu Dec 18, 2014 12:57 pm
I just got some sensors that I interfaced with my BB (LPS331AP, L3GD20H, LSM303D) using I2C. It works fine reading data, but I am still stuck facing a problem:
The I2C reading seems really slow (20ms between each using a loop), and I don't think it is because of the sensors. I am using I2C #1, 100kHz
Here below is the code (Python):
import commands
import datetime
 # Compass LSM303D (accelerometer and magnetometer)
print "Client started ..."
print "i2cdetect -r -y 1"
print commands.getoutput("i2cdetect -r -y 1")
print "Attempt to connect to the Compass..."
x = commands.getoutput("i2cget -y 1 0x1D 0x0F b")
if x == '0x49':
    print "Beagle Bone is connected with the Compass"
else:
    print "Cannot connect to the Compass"
commands.getoutput("i2cset -y 1 0x1D 0x21 0x00 b") #CTRL2
# magnetic sensor into continuous mode from sleep mode
commands.getoutput("i2cset -y 1 0x1D 0x20 0x57 b") #CTRL1 0x57
# ctrl5 parameter
commands.getoutput("i2cset -y 1 0x1D 0x24 0x64") #CTRL5
commands.getoutput("i2cset -y 1 0x1D 0x25 0x20") #CTRL6
commands.getoutput("i2cset -y 1 0x1D 0x26 0x00") #CTRL7
while True:
    time_1 = datetime.datetime.now()
    #read x-axis accelerometer
    x = commands.getoutput("i2cget -y 1 0x1D 0x28 b") #Low
    time_2 = datetime.datetime.now()
    print "int : "+str(time_2 - time_1)
Any idea ?
Thanks;
vex73
Re: BeagleBone: Speed of I2C bus
by adafruit2 on Fri Dec 19, 2014 2:39 pm
yow, you are using python but then calling a command line program, theres a ton of layers going on, please use the python smbus package!
adafruit2
Site Admin
by tdicola on Fri Dec 19, 2014 5:17 pm
Yeah check out the python-smbus library to natively access the I2C hardware. We use it a lot with the different libraries, etc. being ported to the Pi. Unfortunately there isn't that great of documentation on it, but you can find some basic info here: http://wiki.erazor-zone.de/wiki:linux:python:smbus:doc and the kernel smbus docs (this is the definitive API, but it's in C and a little tougher to use): http://git.kernel.org/cgit/linux/kernel ... s-protocol
You can install the python-smbus library pretty easily with an apt-get package too:
sudo apt-get update
sudo apt-get install python-smbus
tdicola
by madGambol on Tue Sep 06, 2016 11:13 am
I'm looking at the SMBus style interface embodied in the AdaFruit_I2C python class, and I don't understand what the parameter "reg" is doing. I'm reading an I2C address and a "register" doesn't factor into it. From an I2C address, I read or write N bytes. So what is "reg" doing?
I added to this topic because I can't find the "new topic" button.
madGambol
by drewfustini on Wed Sep 07, 2016 12:16 am
Please see my response in the topic:
AdaFruit_I2C reg parameter
drewfustini
by edebonis on Thu Sep 08, 2016 9:50 am
Hi, i fix the slow response programming in C. I made a cuple of functions and call them with my main code in python.
edebonis
