I purchased adafruit brass flow meters to be interfaced using GPIO and event_detect with callback. The code works fine without reporting any errors but the callback procedure never executes. A meter reports that the the pin P8_14 does change.
Does callback work on the Beaglebone GPIO? Are there any examples on the Adafruit site using callback?
beaglebone GPIO callback
- drewfustini
Re: beaglebone GPIO callback
Hi, are you using the Adafruit BBIO Python library?
Could you please post your code so that I can get a better understanding?
Also, please post the output of these commands so that I know the version of the system software on your beaglebone:
Drew
cat /etc/dogtag
cat /etc/issue
uname -a
Drew
- x13
Hi Drew
#!/usr/bin/python
#pins.py
import Adafruit_BBIO.GPIO as GPIO
from time import sleep, strftime, time
####GPIO.cleanup()
def setupPins():
GPIO.setup("P8_8", GPIO.IN) # pressure switch
GPIO.setup("P8_7", GPIO.OUT) # circ pump
GPIO.output("P8_7", GPIO.LOW) # set low
GPIO.setup("P8_9", GPIO.OUT) # well on
GPIO.output("P8_9", GPIO.LOW)
GPIO.setup("P8_10", GPIO.OUT) # well off
GPIO.output("P8_10", GPIO.LOW)
GPIO.setup("P9_17", GPIO.OUT) #latching valve sols
GPIO.output("P9_17", GPIO.LOW)
GPIO.setup("P9_18", GPIO.OUT)
GPIO.output("P9_18", GPIO.LOW)
GPIO.setup("P9_21", GPIO.OUT)
GPIO.output("P9_21", GPIO.LOW)
GPIO.setup("P9_22", GPIO.OUT)
GPIO.output("P9_22", GPIO.LOW)
GPIO.setup("P9_23", GPIO.OUT)
GPIO.output("P9_23", GPIO.LOW)
GPIO.setup("P9_24", GPIO.OUT)
GPIO.output("P9_24", GPIO.LOW)
GPIO.setup("P8_12", GPIO.IN) #wall flow
GPIO.setup("P8_14", GPIO.IN) #heat flow
def countFlow(pin):
global ct
ct += 1
print ct
def flow(valve):
global ct
v = valve
if v == 'wall':
pin = "P8_12"
print 'v = wall'
GPIO.add_event_detect(pin, GPIO.FALLING, callback=countFlow)
ct = 0
sleep(5)
GPIO.setup("P8_12",GPIO.IN) #reset wall flow
elif v == 'heat':
pin = "P8_14"
print 'v = heat'
ct = 0
sleep(5)
GPIO.setup("P8_14",GPIO.IN) #reset heat flow
else:
print "Bad valve specification"
return ct
--------The main program-------
#!/usr/bin/python
#ytestflow.py
import pins, os
pins.setupPins()
count = pins.flow('wall')
print "flow count ",count
-------I am only testing P8__12 with this test----------
root@beaglebone:~# cat /etc/dogtag
BeagleBoard.org Debian Image 2015-07-28
root@beaglebone:~# cat /etc/issue
Debian GNU/Linux 7 \n \l
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
The IP Address for eth0 is: 192.168.2.165
The IP Address for usb0 is: 192.168.7.2
root@beaglebone:~# uname -a
Linux beaglebone 3.8.13-bone72 #1 SMP Tue Jun 16 21:36:04 UTC 2015 armv7l GNU/Linux
For this test during the 5 s sleep time I cycled the P8__12 pin from 0 to 2.5 v measured on the pin. I have a mosfet level converter so I used a jumber from 0 to 5v on the mosfet drain to cycle the input to the pin.
Thanks for your help!
Neil Poulson (x13)
#!/usr/bin/python
#pins.py
####GPIO.cleanup()
def setupPins():
def countFlow(pin):
global ct
ct += 1
print ct
def flow(valve):
global ct
v = valve
if v == 'wall':
pin = "P8_12"
print 'v = wall'
ct = 0
sleep(5)
elif v == 'heat':
pin = "P8_14"
print 'v = heat'
ct = 0
sleep(5)
else:
return ct
#!/usr/bin/python
#ytestflow.py
import pins, os
pins.setupPins()
Neil Poulson (x13)
- x13
I believe I have found an error in the code and will fix it and try again later today.
I suggest that anyone working on helping me put your effort on hold until I post my results.
Thanks.
Neil Poulson
Thanks.
Neil Poulson
- drewfustini
UPDATE: looks like we were both typing at the same time :). Please let me know if you need further help
Thanks for posting the code.
If you haven't already, then could you please try using the latest version of adafruit-beaglebone-io-python (follow the Manual instructions in the README).
Justin Cooper's comments in the repo indicate that GPIO event callbacks do work, although the tutorial does not include them: Using the Adafruit_BBIO Library: GPIO.
There is example from that tutorial page:
Could you check if that works for you?
It would help to understand if the trouble is event detection, or just that the callback handler is not getting called.
thanks,
drew
GPIO.add_event_detect("P9_12", GPIO.FALLING)
#your amazing code here
#detect wherever:
if GPIO.event_detected("P9_12"):
print "event detected!"
thanks,
drew
- x13
Hi Drew
I fixed the error in my code edited my post; the callback procedure now gets called and counts. I eventually get a segmentation error.
How can I stop the event dectection? I installed a recent Debian image and Adafruit_GPIO so I may have the latest version.
- drewfustini
Is there any additional error messages when the segmentation error occurs?x13 wrote:Hi Drew
It did find this issue on the github repo:
GPIO callback causing segmentation fault #42
I will attempt to replicate the issue as well.
Drew
- drewfustini
I created this test program:
countFlow() is run when the event is detected:
I was doing this by connecting the P8_12 through a resistor to the 3.3V pin (P9_4). This causes P8_12 to go high which will produce a rising edge event.
I noticed though that countFlow() is called often. I believe this is because there is no deboucning. I removed the print statement from countFlow() because it takes too long to run.
I didn't encounter any segmentation errors. Are you still having that issue?
ct = 0
def countFlow(pin):
global ct
ct += 1
GPIO.add_event_detect("P8_12", GPIO.RISING, countFlow)
while 1:
print "ct=%d" % ct
GPIO.output("P8_10", GPIO.HIGH)
sleep(1)
sleep(1)
GPIO.cleanup()
debian@beaglebone:~/support/callback$ sudo python test4.py
ct=0
ct=0
ct=14
ct=44
ct=44
ct=44
^CTraceback (most recent call last):
File "test4.py", line 17, in <module>
sleep(1)
KeyboardInterrupt
- x13
Hi Drew
I had the same trouble with using a shorting jumper. On a RPI_GPIO post I found:
bouncetime=100
GPIO.remove_event_detect(pin)
I added these to my code and have not produced any errors.
I wonder if I was adding an interrupt each time I called the procedure.
The above items don't seem to be documented in the Adafruit_GPIO for beaglebone
but they seem to work. Are they really functional.
Neil
bouncetime=100
Neil
- drewfustini
Thanks for the tip about bouncetime. I see that now in py_gpio.c:
Is your program now working as expected?
static int add_py_callback(char *channel, unsigned int gpio, unsigned int bouncetime, PyObject *cb_func)
- x13
Hi Drew
Yes, it is. Thanks for your help, I finished the calibration of the brass flow meters last evening.
Is there a documentation on your site which describes all of the functions of the Adafruit_GPIO for beaglebone black?
Neil Poulson
Neil Poulson
- drewfustini
Glad to hear it!
There is this tutorial: Using the Adafruit_BBIO Library. I will talk to Justin about adding more to it, especially for event callback, as you have highlighted.
I'll also created a pull request with event callback documentation for the adafruit-beaglebone-io-python README
- drewfustini
Glad to hear it!
I'll also created a pull request with event callback documentation for the adafruit-beaglebone-io-python README.
thanks,
drew
thanks,
drew
