Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
WiFi Problems
WiFi Problems
by MikeRH on Mon Feb 22, 2016 2:12 am
I followed the tutorial to install and configure a wifi dongle on the BBB. I'm using a UWN200 wifi adapter. I booted up the BBB to add some new features to my project and I noticed that my wifi was no longer working. I've tried rerunning through the steps but I can't seem to get anywhere.
I always get the message: ifup: interface ra0 already configured.
I will then try ifdown and ifup again but I get the message:
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 17
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
I'm concerned there might be something wrong with the drivers since I don't see running when I run ifconfig:
ra0 Link encap:Ethernet HWaddr 00:0c:43:00:02:c6
inet6 addr: fe80::20c:43ff:fe00:2c6/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:38175 errors:0 dropped:2 overruns:0 frame:0
TX packets:2359 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:8592839 (8.1 MiB) TX bytes:260337 (254.2 KiB)
Any help is greatly appreciated.
MikeRH
Re: WiFi Problems
by drewfustini on Mon Feb 22, 2016 5:09 pm
What was the URL of the tutorial that you followed?
It is possible that the driver isn't loaded.
Please passte the output of:
lsusb
and the output of:
dmesg
drewfustini
Re: WiFi Problems
by MikeRH on Mon Feb 22, 2016 6:00 pm
Thank you for the quick reply. I forgot to add that the wifi was working up until recently and I didn't make any changes. It just seemed to stop working. Tutorial: https://learn.adafruit.com/setting-up-w ... bone-black Here is the requested output.
lsusb:
root@beaglebone:~# lsusb
Bus 001 Device 002: ID 148f:7601 Ralink Technology, Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg
root@beaglebone:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone70 (root@a5-imx6q-wandboard-2gb) (gcc ve rsion 4.6.3 (Debian 4.6.3-14) ) #1 SMP Fri Jan 23 02:15:42 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c08c09c0, node_mem_map c093e00 0
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES2.1 (l2cache sgx neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d4e000 s14080 r8192 d14592 u36864
[ 0.000000] pcpu-alloc: s14080 r8192 d14592 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 129792
[ 0.000000] Kernel command line: console=tty0 console=ttyO0,115200n8 root=/de v/mmcblk0p2 rootfstype=ext4 rootwait quiet init=/lib/systemd/systemd
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memor y cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 505344k/505344k available, 18944k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07fda30 (8151 kB)
[ 0.000000] .init : 0xc07fe000 - 0xc083b700 ( 246 kB)
[ 0.000000] .data : 0xc083c000 - 0xc08c3980 ( 543 kB)
[ 0.000000] .bss : 0xc08c3980 - 0xc093d140 ( 486 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895 6ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000365] Calibrating delay loop... 993.47 BogoMIPS (lpj=969728)
[ 0.029187] pid_max: default: 32768 minimum: 301
[ 0.029325] Security Framework initialized
[ 0.029380] Mount-cache hash table entries: 512
[ 0.035113] Initializing cgroup subsys cpuacct
[ 0.035135] Initializing cgroup subsys memory
[ 0.035176] Initializing cgroup subsys blkio
[ 0.035263] CPU: Testing write buffer coherency: ok
[ 0.035642] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.035694] Setting up static identity map for 0x804d4d08 - 0x804d4d54
[ 0.036607] Brought up 1 CPUs
[ 0.036622] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[ 0.037398] devtmpfs: initialized
[ 0.045746] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.097867] pinctrl core: initialized pinctrl subsystem
[ 0.098001] rstctl core: initialized rstctl subsystem
[ 0.098277] regulator-dummy: no parameters
[ 0.098592] NET: Registered protocol family 16
[ 0.099112] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.104688] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.105243] platform 49000000.edma: alias fck already exists
[ 0.105259] platform 49000000.edma: alias fck already exists
[ 0.105272] platform 49000000.edma: alias fck already exists
[ 0.105927] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.106023] OMAP GPIO hardware version 0.1
[ 0.106833] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.107554] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.108248] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.108499] of_get_named_gpio_flags exited with status 52
[ 0.108516] gpio-rctrl rstctl.4: loaded OK
[ 0.111852] No ATAGs?
[ 0.111869] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113086] cpsw.0: No hwaddr in dt. Using d0:5f:b8:ff:27:6d from efuse
[ 0.113106] cpsw.1: No hwaddr in dt. Using d0:5f:b8:ff:27:6f from efuse
[ 0.121206] bio: create slab <bio-0> at 0
[ 0.127425] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.127578] of_get_named_gpio_flags: can't parse gpios property
[ 0.127699] vmmcsd_fixed: 3300 mV
[ 0.129293] SCSI subsystem initialized
[ 0.129524] usbcore: registered new interface driver usbfs
[ 0.129582] usbcore: registered new interface driver hub
[ 0.129791] usbcore: registered new device driver usb
[ 0.131039] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.131926] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-00 24/input/input0
[ 0.133535] DCDC1: at 1500 mV
[ 0.134361] vdd_mpu: 925 <--> 1325 mV at 1325 mV
[ 0.135199] vdd_core: 925 <--> 1150 mV at 1125 mV
[ 0.135997] LDO1: at 1800 mV
[ 0.136801] LDO2: at 3300 mV
[ 0.138281] LDO3: 1800 mV
[ 0.139120] LDO4: at 3300 mV
[ 0.139831] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.140288] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.140796] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.142129] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.142273] media: Linux media interface: v0.10
[ 0.142333] Linux video capture interface: v2.00
[ 0.142400] pps_core: LinuxPPS API ver. 1 registered
[ 0.142408] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.142432] PTP clock support registered
[ 0.142892] Advanced Linux Sound Architecture Driver Initialized.
[ 0.143470] NetLabel: Initializing
[ 0.143480] NetLabel: domain hash size = 128
[ 0.143487] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.143555] NetLabel: unlabeled traffic allowed by default
[ 0.143733] Switching to clocksource gp_timer
[ 0.175133] NET: Registered protocol family 2
[ 0.175766] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.175846] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.175926] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.175988] TCP: reno registered
[ 0.176002] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.176026] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.176259] NET: Registered protocol family 1
[ 0.176652] RPC: Registered named UNIX socket transport module.
[ 0.176663] RPC: Registered udp transport module.
[ 0.176670] RPC: Registered tcp transport module.
[ 0.176676] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.176903] Trying to unpack rootfs image as initramfs...
[ 0.371886] Freeing initrd memory: 2800K
[ 0.372195] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counter s available
[ 0.372543] CPU PMU: attempt to register multiple PMU devices!
[ 0.372569] arm-pmu: probe of arm-pmu failed with error -28
[ 0.372875] omap2_mbox_probe: platform not supported
[ 0.523241] VFS: Disk quotas dquot_6.5.2
[ 0.523379] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.524091] NFS: Registering the id_resolver key type
[ 0.524160] Key type id_resolver registered
[ 0.524169] Key type id_legacy registered
[ 0.524436] fuse init (API version 7.20)
[ 0.524918] Btrfs loaded
[ 0.525022] msgmni has been set to 992
[ 0.526693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 48)
[ 0.526710] io scheduler noop registered
[ 0.526718] io scheduler deadline registered
[ 0.526740] io scheduler cfq registered (default)
[ 0.527874] tps65217-bl tps65217-bl: no platform data provided
[ 0.527914] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.528424] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.529792] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.530068] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UA RT0
[ 0.541944] console [ttyO0] enabled
[ 0.542650] [drm] Initialized drm 1.1.0 20060810
[ 0.549989] brd: module loaded
[ 0.553697] loop: module loaded
[ 0.553774] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.553816] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.553857] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.553892] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.553927] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.560693] bone-capemgr bone_capemgr.9: Baseboard: 'A335BNLT,00C0,3214BBBK80 97'
[ 0.560720] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-b lack
[ 0.591077] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.628183] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.665291] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.702400] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.708617] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 0.708640] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 0.708655] bone-capemgr bone_capemgr.9: slot #4: 'Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G'
[ 0.708734] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 0.708752] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 0.708766] bone-capemgr bone_capemgr.9: slot #5: 'Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI'
[ 0.708841] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 0.708859] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 0.708873] bone-capemgr bone_capemgr.9: slot #6: 'Bone-Black-HDMIN,00A0,Texa s Instrument,BB-BONELT-HDMIN'
[ 0.709199] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2 G:00A0 (prio 1)
[ 0.709214] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G :00A0 (prio 1)
[ 0.709291] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI :00A0 (prio 1)
[ 0.709303] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI: 00A0 (prio 1)
[ 0.709336] bone-capemgr bone_capemgr.9: initialized OK.
[ 0.709795] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G :00A0 (prio 1)
[ 0.709819] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware 'cape-b one-2g-emmc1.dtbo' for board-name 'Bone-LT-eMMC-2G', version '00A0'
[ 0.709837] bone-capemgr bone_capemgr.9: slot #4: dtbo 'cape-bone-2g-emmc1.dt bo' loaded; converting to live tree
[ 0.710021] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 0.710630] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 0.710647] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G: 00A0 (prio 1)
[ 0.711810] OneNAND driver initializing
[ 0.712264] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI: 00A0 (prio 1)
[ 0.712288] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware 'cape-b oneblack-hdmi-00A0.dtbo' for board-name 'Bone-Black-HDMI', version '00A0'
[ 0.712319] bone-capemgr bone_capemgr.9: slot #5: dtbo 'cape-boneblack-hdmi-0 0A0.dtbo' loaded; converting to live tree
[ 0.712876] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 0.714822] usbcore: registered new interface driver cdc_ether
[ 0.714877] usbcore: registered new interface driver rndis_host
[ 0.714977] usbcore: registered new interface driver cdc_ncm
[ 0.715390] platform 4830e000.fb: alias fck already exists
[ 0.716495] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 0.716514] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:0 0A0 (prio 1)
[ 0.716756] usbcore: registered new interface driver cdc_acm
[ 0.716765] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 0.716772] Initializing USB Mass Storage driver...
[ 0.716858] usbcore: registered new interface driver usb-storage
[ 0.716865] USB Mass Storage support registered.
[ 0.717007] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.717246] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 0.717263] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:480 dsps _musb_init: OK
[ 0.717289] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.717299] musb-hdrc: MHDRC RTL version 2.0
[ 0.717307] musb-hdrc: setup fifo_mode 4
[ 0.717322] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.717402] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 0.717412] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 0.717799] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMI N:00A0 (prio 2)
[ 0.717816] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 0.717831] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 0.717857] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware 'cape-b oneblack-hdmin-00A0.dtbo' for board-name 'Bone-Black-HDMIN', version '00A0'
[ 0.717886] bone-capemgr bone_capemgr.9: slot #6: dtbo 'cape-boneblack-hdmin- 00A0.dtbo' loaded; converting to live tree
[ 0.718195] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8 .45 (#5:BB-BONELT-HDMI)
[ 0.727799] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.734542] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BON ELT-HDMIN:00A0 (prio 2)
[ 0.744162] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 0.744176] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:480 dsps _musb_init: OK
[ 0.744199] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.744209] musb-hdrc: MHDRC RTL version 2.0
[ 0.744216] musb-hdrc: setup fifo_mode 4
[ 0.744227] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.744305] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 0.744315] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 0.744325] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.744553] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.744581] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 0.744651] usb usb1: default language 0x0409
[ 0.744683] usb usb1: udev 1, busnum 1, minor = 0
[ 0.744695] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.744706] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 0.744716] usb usb1: Product: MUSB HDRC host driver
[ 0.744725] usb usb1: Manufacturer: Linux 3.8.13-bone70 musb-hcd
[ 0.744734] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 0.745129] usb usb1: usb_probe_device
[ 0.745146] usb usb1: configuration #1 chosen from 1 choice
[ 0.745185] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 0.745285] hub 1-0:1.0: usb_probe_interface
[ 0.745296] hub 1-0:1.0: usb_probe_interface - got id
[ 0.745313] hub 1-0:1.0: USB hub found
[ 0.745336] hub 1-0:1.0: 1 port detected
[ 0.745430] hub 1-0:1.0: standalone hub
[ 0.745443] hub 1-0:1.0: individual port power switching
[ 0.745452] hub 1-0:1.0: no over-current protection
[ 0.745459] hub 1-0:1.0: Single TT
[ 0.745469] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 0.745479] hub 1-0:1.0: power on to power good time: 10ms
[ 0.745505] hub 1-0:1.0: local power source is good
[ 0.745562] hub 1-0:1.0: enabling power on all ports
[ 0.746173] mousedev: PS/2 mouse device common for all mice
[ 0.747697] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 0.747911] i2c /dev entries driver
[ 0.748883] pps_ldisc: PPS line discipline registered
[ 0.748980] Driver for 1-wire Dallas network protocol.
[ 0.750175] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.750608] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-d evel@redhat.com
[ 0.750642] cpuidle: using governor ladder
[ 0.750651] cpuidle: using governor menu
[ 0.750896] of_get_named_gpio_flags exited with status 6
[ 0.750907] of_get_named_gpio_flags: can't parse gpios property
[ 0.750915] of_get_named_gpio_flags: can't parse gpios property
[ 0.750936] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[ 0.758165] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 0.758649] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 0.758699] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 0.758862] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 0.759263] omap_hsmmc mmc.5: pins are not configured from the driver
[ 0.786560] of_get_named_gpio_flags: can't parse gpios property
[ 0.786576] of_get_named_gpio_flags: can't parse gpios property
[ 0.786584] of_get_named_gpio_flags: can't parse gpios property
[ 0.786614] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 0.786677] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC _RSTn
[ 0.786689] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 0.786968] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 0.787012] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 0.787415] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 0.787492] omap_hsmmc mmc.11: pins are not configured from the driver
[ 0.814027] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.825708] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.832987] pinctrl-single 44e10800.pinmux: could not request pin 21 on devic e pinctrl-single
[ 0.841935] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 0.841959] of_get_named_gpio_flags exited with status 53
[ 0.841970] of_get_named_gpio_flags exited with status 54
[ 0.841980] of_get_named_gpio_flags exited with status 55
[ 0.841991] of_get_named_gpio_flags exited with status 56
[ 0.842003] of_get_named_gpio_flags exited with status 53
[ 0.842143] of_get_named_gpio_flags exited with status 54
[ 0.842276] of_get_named_gpio_flags exited with status 55
[ 0.842373] of_get_named_gpio_flags exited with status 56
[ 0.842700] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.842950] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 0.843052] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 0.844298] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 0.844379] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 0.844421] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 0.847088] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 0.847140] hub 1-0:1.0: hub_suspend
[ 0.847166] usb usb1: bus auto-suspend, wakeup 1
[ 0.847600] usbcore: registered new interface driver usbhid
[ 0.847609] usbhid: USB HID core driver
[ 0.848451] ashmem: initialized
[ 0.848650] logger: created 256K log 'log_main'
[ 0.848825] logger: created 256K log 'log_events'
[ 0.849114] logger: created 256K log 'log_radio'
[ 0.849308] logger: created 256K log 'log_system'
[ 0.851217] of_get_named_gpio_flags exited with status 59
[ 0.852033] davinci_evm sound.14: nxp-hdmi-hifi <-> 48038000.mcasp mapping o k
[ 0.854059] TCP: cubic registered
[ 0.854133] NET: Registered protocol family 10
[ 0.855008] NET: Registered protocol family 17
[ 0.855255] Key type dns_resolver registered
[ 0.855416] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.855441] ThumbEE CPU extension supported.
[ 0.855471] Registering SWP/SWPB emulation handler
[ 0.856079] registered taskstats version 1
[ 0.857576] of_get_named_gpio_flags: can't parse gpios property
[ 0.857597] tilcdc 4830e000.fb: No power control GPIO
[ 0.883841] mmc0: host does not support reading read-only switch. assuming wr ite-enable.
[ 0.887809] mmc0: new high speed SDHC card at address aaaa
[ 0.888331] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 0.890065] mmcblk0: p1 p2
[ 0.919818] usb usb1: usb wakeup-resume
[ 0.919856] usb usb1: usb auto-resume
[ 0.919876] hub 1-0:1.0: hub_resume
[ 0.919911] hub 1-0:1.0: port 1: status 0101 change 0001
[ 0.942571] mmc1: BKOPS_EN bit is not set
[ 0.946365] mmc1: new high speed MMC card at address 0001
[ 0.946877] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[ 0.947078] mmcblk1boot0: mmc1:0001 MMC04G partition 1 2.00 MiB
[ 0.947276] mmcblk1boot1: mmc1:0001 MMC04G partition 2 2.00 MiB
[ 0.948195] mmcblk1: p1 p2
[ 0.949866] mmcblk1boot1: unknown partition table
[ 0.951090] mmcblk1boot0: unknown partition table
[ 0.972466] tilcdc 4830e000.fb: found TDA19988
[ 0.973049] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 0.973058] [drm] No driver support for vblank timestamp query.
[ 0.973345] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 0.973361] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.982652] Console: switching to colour frame buffer device 128x48
[ 0.988715] tilcdc 4830e000.fb: fb0: frame buffer device
[ 0.988725] tilcdc 4830e000.fb: registered panic notifier
[ 0.988749] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.022808] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 1.022853] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[ 1.036409] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.036421] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.043260] libphy: 4a101000.mdio: probed
[ 1.043289] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driv er SMSC LAN8710/LAN8720
[ 1.043466] Detected MACID = d0:5f:b8:ff:27:6d
[ 1.043574] cpsw 4a100000.ethernet: NAPI disabled
[ 1.045132] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:0 1 UTC (946684801)
[ 1.049900] ALSA device list:
[ 1.049924] #0: TI BeagleBone Black
[ 1.050643] Freeing init memory: 244K
[ 1.123278] udevd[100]: starting version 175
[ 1.128320] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.247970] usb 1-1: default language 0x0409
[ 1.612801] usb 1-1: udev 2, busnum 1, minor = 1
[ 1.612825] usb 1-1: New USB device found, idVendor=148f, idProduct=7601
[ 1.612837] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.613309] usb 1-1: usb_probe_device
[ 1.613329] usb 1-1: configuration #1 chosen from 1 choice
[ 1.613514] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 1.614349] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 1.614383] hub 1-0:1.0: port 1 enable change, status 00000503
[ 2.415631] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em
[ 2.415651] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.750275] EXT4-fs (mmcblk0p2): recovery complete
[ 3.758310] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 4.784992] rtusb init rt2870 --->
[ 4.785070] rt2870 1-1:1.0: usb_probe_interface
[ 4.785085] rt2870 1-1:1.0: usb_probe_interface - got id
[ 4.785812]
[ 4.785812]
[ 4.785812] === pAd = e0dc3000, size = 852552 ===
[ 4.785812]
[ 4.785920] <-- RTMPAllocTxRxRingMemory, Status=0
[ 4.786538] <-- RTMPAllocAdapterBlock, Status=0
[ 4.786555] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x8
[ 4.786561] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x4
[ 4.786568] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x5
[ 4.786574] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x6
[ 4.786580] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x7
[ 4.786586] RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x9
[ 4.797014] NVM is EFUSE
[ 4.797037] Endpoint(8) is for In-band Command
[ 4.797045] Endpoint(4) is for WMM0 AC0
[ 4.797051] Endpoint(5) is for WMM0 AC1
[ 4.797057] Endpoint(6) is for WMM0 AC2
[ 4.797063] Endpoint(7) is for WMM0 AC3
[ 4.797069] Endpoint(9) is for WMM1 AC0
[ 4.797076] Endpoint(84) is for Data-In
[ 4.797082] Endpoint(85) is for Command Rsp
[ 4.800309] usbcore: registered new interface driver rt2870
[ 5.103104] udevd[240]: starting version 175
[ 5.980559] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 7.303861] FW Version:0.1.00 Build:7640
[ 7.303878] Build Time:201302052146____
[ 7.303881] ILM Length = 45380(bytes)
[ 7.303883] DLM Length = 0(bytes)
[ 7.313205] Loading FW....
[ 7.479932] usb 1-1: wpa_supplicant timed out on ep0in len=0/4
[ 7.479951] #
[ 7.491834] RTMP_TimerListAdd: add timer obj e0e40e24!
[ 7.491855] RTMP_TimerListAdd: add timer obj e0e40e6c!
[ 7.491863] RTMP_TimerListAdd: add timer obj e0e40eb4!
[ 7.491872] RTMP_TimerListAdd: add timer obj e0e40ddc!
[ 7.491884] RTMP_TimerListAdd: add timer obj e0e40d04!
[ 7.491892] RTMP_TimerListAdd: add timer obj e0e40d4c!
[ 7.491900] RTMP_TimerListAdd: add timer obj e0dd5edc!
[ 7.491907] RTMP_TimerListAdd: add timer obj e0dc52f0!
[ 7.491915] RTMP_TimerListAdd: add timer obj e0dc533c!
[ 7.491923] RTMP_TimerListAdd: add timer obj e0dd5fc4!
[ 7.491933] RTMP_TimerListAdd: add timer obj e0dd5e4c!
[ 7.491945] RTMP_TimerListAdd: add timer obj e0dd5f7c!
[ 7.512624] cfg_mode=9
[ 7.512646] wmode_band_equal(): Band Equal!
[ 7.513216] Key1Str is Invalid key length(0) or Type(0)
[ 7.513270] Key2Str is Invalid key length(0) or Type(0)
[ 7.513323] Key3Str is Invalid key length(0) or Type(0)
[ 7.513375] Key4Str is Invalid key length(0) or Type(0)
[ 7.514285] 1. Phy Mode = 14
[ 7.514294] 2. Phy Mode = 14
[ 7.514303] NVM is Efuse and its size =1d[1e0-1fc]
[ 7.529419] 3. Phy Mode = 14
[ 7.529439] AntCfgInit: primary/secondary ant 0/1
[ 7.732074] ---> InitFrequencyCalibration
[ 7.732094] InitFrequencyCalibrationMode:Unknow mode = 3
[ 7.732103] InitFrequencyCalibration: frequency offset in the EEPROM = 66(0x4 2)
[ 7.732110] <--- InitFrequencyCalibration
[ 7.732136] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 7.736426] MCS Set = ff 00 00 00 01
[ 7.746492] <==== rt28xx_init, Status=0
[ 7.749703] 0x1300 = 00064300
[ 7.749717] RTMPDrvOpen(1):Check if PDMA is idle!
[ 7.749799] RTMPDrvOpen(2):Check if PDMA is idle!
[ 7.756457] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 7.756771] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 7.924094] omap_rng 48310000.rng: base address of priv is -97452032
[ 7.946910] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 10.929439] ===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1116
[ 10.932797] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 11.042627] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 11.042645] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 11.056443] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 21.142436] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 21.142749] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 23.245906] ===>rt_ioctl_giwscan. 8(8) BSS returned, data->length = 1257
[ 23.247482] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 23.331311] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 23.331326] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 23.344769] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 33.422258] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 33.422570] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 35.520152] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1439
[ 35.523031] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 35.619965] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 35.619982] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 35.633556] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 45.682294] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 45.682655] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 47.783911] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1428
[ 47.784727] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 47.806224] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 47.806241] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 47.820755] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 57.868582] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 57.868924] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 59.967410] ===>rt_ioctl_giwscan. 10(10) BSS returned, data->length = 1633
[ 59.970313] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 59.994325] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 59.994341] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 60.011049] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 70.095540] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 70.096040] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 72.215533] ===>rt_ioctl_giwscan. 10(10) BSS returned, data->length = 1633
[ 72.217024] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 72.281272] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 72.281292] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 72.295024] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 73.180701] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 73.192773] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 73.467496] ERROR!!! MlmeEnqueueForRecv: fRTMP_ADAPTER_HALT_IN_PROGRESS
[ 73.467596] ERROR!!! MlmeEnqueueForRecv: fRTMP_ADAPTER_HALT_IN_PROGRESS
[ 73.489323] AsicSendCmdToAndes: !fRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD && fRTMP_ ADAPTER_IDLE_RADIO_OFF
[ 73.489377] unlink cmd rsp urb
[ 75.364752] gadget: using random self ethernet address
[ 75.373272] usb0: MAC 6e:9f:0d:e1:2b:39
[ 75.373290] usb0: HOST MAC d0:5f:b8:ff:27:6f
[ 75.384194] gadget: Mass Storage Function, version: 2009/09/11
[ 75.384215] gadget: Number of LUNs=1
[ 75.384238] lun0: LUN: removable file: /dev/mmcblk0p1
[ 75.384370] gadget: Multifunction Composite Gadget
[ 75.384399] gadget: g_multi ready
[ 75.384441] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 75.386930] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 75.386969] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 75.387041] usb usb2: default language 0x0409
[ 75.387074] usb usb2: udev 1, busnum 2, minor = 128
[ 75.387086] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 75.387097] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 75.387107] usb usb2: Product: MUSB HDRC host driver
[ 75.387116] usb usb2: Manufacturer: Linux 3.8.13-bone70 musb-hcd
[ 75.387126] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 75.392300] usb usb2: usb_probe_device
[ 75.392322] usb usb2: configuration #1 chosen from 1 choice
[ 75.392379] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 75.392506] hub 2-0:1.0: usb_probe_interface
[ 75.392519] hub 2-0:1.0: usb_probe_interface - got id
[ 75.392538] hub 2-0:1.0: USB hub found
[ 75.392563] hub 2-0:1.0: 1 port detected
[ 75.392574] hub 2-0:1.0: standalone hub
[ 75.392582] hub 2-0:1.0: individual port power switching
[ 75.392592] hub 2-0:1.0: no over-current protection
[ 75.392600] hub 2-0:1.0: Single TT
[ 75.392610] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 75.392620] hub 2-0:1.0: power on to power good time: 10ms
[ 75.392641] hub 2-0:1.0: local power source is good
[ 75.392700] hub 2-0:1.0: enabling power on all ports
[ 75.493635] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 75.493698] hub 2-0:1.0: hub_suspend
[ 75.493726] usb usb2: bus auto-suspend, wakeup 1
[ 75.571449] CAUTION: musb: Babble Interrupt Occurred
[ 75.572806] RTMP_TimerListAdd: add timer obj e0e40e24!
[ 75.572823] RTMP_TimerListAdd: add timer obj e0e40e6c!
[ 75.572832] RTMP_TimerListAdd: add timer obj e0e40eb4!
[ 75.572841] RTMP_TimerListAdd: add timer obj e0e40ddc!
[ 75.572852] RTMP_TimerListAdd: add timer obj e0e40d04!
[ 75.572860] RTMP_TimerListAdd: add timer obj e0e40d4c!
[ 75.572868] RTMP_TimerListAdd: add timer obj e0dd5edc!
[ 75.572876] RTMP_TimerListAdd: add timer obj e0dc52f0!
[ 75.572884] RTMP_TimerListAdd: add timer obj e0dc533c!
[ 75.572892] RTMP_TimerListAdd: add timer obj e0dd5fc4!
[ 75.572903] RTMP_TimerListAdd: add timer obj e0dd5e4c!
[ 75.572917] RTMP_TimerListAdd: add timer obj e0dd5f7c!
[ 75.625813] cfg_mode=9
[ 75.625836] wmode_band_equal(): Band Equal!
[ 75.626409] Key1Str is Invalid key length(0) or Type(0)
[ 75.626464] Key2Str is Invalid key length(0) or Type(0)
[ 75.626516] Key3Str is Invalid key length(0) or Type(0)
[ 75.626569] Key4Str is Invalid key length(0) or Type(0)
[ 75.627482] 1. Phy Mode = 14
[ 75.627489] 2. Phy Mode = 14
[ 75.627498] NVM is Efuse and its size =1d[1e0-1fc]
[ 75.666705] CAUTION: musb: Babble Interrupt Occurred
[ 75.681171] 3. Phy Mode = 14
[ 75.681192] AntCfgInit: primary/secondary ant 0/1
[ 75.785784] gadget: high-speed config #1: Multifunction with RNDIS
[ 75.948921] ---> InitFrequencyCalibration
[ 75.948944] InitFrequencyCalibrationMode:Unknow mode = 3
[ 75.948955] InitFrequencyCalibration: frequency offset in the EEPROM = 66(0x4 2)
[ 75.948961] <--- InitFrequencyCalibration
[ 75.948990] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 75.952852] MCS Set = ff 00 00 00 01
[ 75.963042] <==== rt28xx_init, Status=0
[ 75.978034] 0x1300 = 00064300
[ 75.978052] RTMPDrvOpen(1):Check if PDMA is idle!
[ 75.979042] RTMPDrvOpen(2):Check if PDMA is idle!
[ 75.999895] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 76.000254] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 78.529127] ===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1107
[ 78.533107] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 78.630397] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 78.630417] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 78.645059] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 89.185013] net eth0: initializing cpsw version 1.12 (0)
[ 89.195060] net eth0: phy found : id is : 0x7c0f1
[ 89.195097] libphy: PHY 4a101000.mdio:01 not found
[ 89.200176] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 89.222790] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 90.694791] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 90.695633] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 92.806341] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1507
[ 92.809997] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 92.864780] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 92.864800] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 92.880351] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 94.948566] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. O pts: (null)
[ 102.939448] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 102.942336] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 105.097582] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1473
[ 105.107042] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 105.153482] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 105.153524] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 105.173038] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 115.277706] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 115.280970] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 117.409938] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1439
[ 117.416456] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 117.448699] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 117.448739] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 117.471005] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 127.570488] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 127.571190] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 129.696030] ===>rt_ioctl_giwscan. 8(8) BSS returned, data->length = 1381
[ 129.704698] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 129.738191] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 129.738234] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 129.763230] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 139.822522] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 139.822883] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 141.951117] ===>rt_ioctl_giwscan. 10(10) BSS returned, data->length = 1633
[ 141.960551] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 142.019487] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 142.019530] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 142.039195] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 152.142212] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 152.142873] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 154.265587] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1365
[ 154.275047] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 154.308437] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 154.308478] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 154.331701] PeerAssocReqSanity - IE_EXT_CAPABILITY!
[ 164.431618] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 164.432280] /build/buildd/mt7601u/src/os/linux/../../common/cmm_asic.c:2008 a ssert KeyIdx < 4failed
[ 166.559162] ===>rt_ioctl_giwscan. 9(9) BSS returned, data->length = 1360
[ 166.568778] ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=6)
[ 166.699213] PeerBeaconAtJoinAction(): HT-CtrlChannel=6, CentralChannel=>8
[ 166.699255] PeerBeaconAtJoinAction(): Set CentralChannel=8
[ 166.717956] PeerAssocReqSanity - IE_EXT_CAPABILITY!
MikeRH
Re: WiFi Problems
by drewfustini on Mon Feb 22, 2016 11:12 pm
I searched for UWN200. Is this it?
http://www.logicsupply.com/uwn200/
It looks like LogicSupply does have a tutorial:
http://www.logicsupply.com/explore/io-h ... -tutorial/
Direct link to Google Docs:
https://docs.google.com/document/d/1-CI ... v29ly6yl74
drewfustini
Re: WiFi Problems
by MikeRH on Tue Feb 23, 2016 1:54 am
Thank you Drew, I'm not sure why I didn't see that. I'll give that tutorial a shot.
MikeRH
Re: WiFi Problems
by MikeRH on Fri Mar 18, 2016 11:01 am
Unfortunately I ran through their tutorial and it did not go well. While the tutorial steps went well, my Beaglebone will not even recognize the device now. For some reason ra0 will not show up in ifconfig and I'm a bit lost as to why. Could my usb drive be damaged, if so is there a way to check this? I've e-mailed logicsupply to see if they have any advice but I may need to start fresh. Right now I have a project I've been constructing in the cloud9 ide. Would it be safe to reflash the device and reload all of my project files?
MikeRH
Re: WiFi Problems
by drewfustini on Fri Mar 18, 2016 12:59 pm
MikeRH wrote:Unfortunately I ran through their tutorial and it did not go well. While the tutorial steps went well, my Beaglebone will not even recognize the device now. For some reason ra0 will not show up in ifconfig and I'm a bit lost as to why. Could my usb drive be damaged, if so is there a way to check this?
It could be a hardware problem if you don't see it in "lsusb" output. You may want to post one the official BeagleBoard.org mailing list to see if anyone else has encountered this issue:
http://groups.google.com/forum/#!categories/beagleboard
Make sure you back up your project before reflashing the card. I believe they should be in /var/lib/cloud9
drewfustini
Re: WiFi Problems
by MikeRH on Fri Mar 18, 2016 1:05 pm
Thank you, the device shows up in lsusb but I can't seem to get an interface in ifconfig or iwconfig. I have everything backed up in a repository so I'll probably reflash and see if I still have the same problems.
MikeRH
Re: WiFi Problems
by jstoner on Wed Jun 29, 2016 2:42 pm
Looks like I have the same problem. I'm using a wifi dongle from here. Same tutorial.
The dongle:
https://www.adafruit.com/products/1012
Here's the ifdown/ifup output:
0s   #> ifdown wlan0
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/00:e0:4c:0f:01:d0
Sending on   LPF/wlan0/00:e0:4c:0f:01:d0
Sending on   Socket/fallback
[ root@rcdev:~ ]
0s  #> ifup wlan0
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
Here's the lsusb output:
1s  #> lsusb
Bus 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Here's the relevant dmesg output:
[    0.903248] usb usb1: usb wakeup-resume
[    0.903296] usb usb1: usb auto-resume
[    0.903316] hub 1-0:1.0: hub_resume
[    0.903351] hub 1-0:1.0: port 1: status 0101 change 0001
[    0.963705] udevd[95]: starting version 175
[    1.006756] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[    1.006815] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[    1.112249] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.232095] usb 1-1: default language 0x0409
[    1.232642] usb 1-1: udev 2, busnum 1, minor = 1
[    1.232658] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
[    1.232669] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.232679] usb 1-1: Product: 802.11n WLAN Adapter
[    1.232688] usb 1-1: Manufacturer: Realtek
[    1.232697] usb 1-1: SerialNumber: 00e04c000001
[    1.233217] usb 1-1: usb_probe_device
[    1.233235] usb 1-1: configuration #1 chosen from 1 choice
[    1.233369] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[    1.233992] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    1.234025] hub 1-0:1.0: port 1 enable change, status 00000503
[    2.105419] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.105438] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    2.935778] EXT4-fs (mmcblk0p2): recovery complete
[    2.937161] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.876326] usbcore: registered new interface driver rt2870
[    4.070557] udevd[227]: starting version 175
[    4.978964] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[    6.338017] omap_rng 48310000.rng: base address of priv is -97452032
[    6.354526] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    6.833396] net eth0: initializing cpsw version 1.12 (0)
[    6.839273] net eth0: phy found : id is : 0x7c0f1
[    6.839308] libphy: PHY 4a101000.mdio:01 not found
[    6.844363] net eth0: phy 4a101000.mdio:01 not found on slave 1
[    6.876057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.549192] rtl8192cu 1-1:1.0: usb_probe_interface
[    7.549218] rtl8192cu 1-1:1.0: usb_probe_interface - got id
[    8.459684] usbcore: registered new interface driver rtl8192cu
[    9.915465] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[    9.915525] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   15.208428] usb0: MAC 78:a5:04:c8:99:20
[   15.208447] usb0: HOST MAC 78:a5:04:c8:99:2a
[   15.215692]  gadget: Mass Storage Function, version: 2009/09/11
[   15.215714]  gadget: Number of LUNs=1
[   15.215737]  lun0: LUN: removable file: /dev/mmcblk0p1
[   15.215870]  gadget: Multifunction Composite Gadget
[   15.215898]  gadget: g_multi ready
[   15.215941] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[   15.216263] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[   15.216292] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[   15.216367] usb usb2: default language 0x0409
[   15.216399] usb usb2: udev 1, busnum 2, minor = 128
[   15.216411] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   15.216422] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.216432] usb usb2: Product: MUSB HDRC host driver
[   15.216441] usb usb2: Manufacturer: Linux 3.8.13-bone79 musb-hcd
[   15.216451] usb usb2: SerialNumber: musb-hdrc.0.auto
[   15.219045] usb usb2: usb_probe_device
[   15.219066] usb usb2: configuration #1 chosen from 1 choice
[   15.219122] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[   15.219248] hub 2-0:1.0: usb_probe_interface
[   15.219260] hub 2-0:1.0: usb_probe_interface - got id
[   15.219281] hub 2-0:1.0: USB hub found
[   15.219306] hub 2-0:1.0: 1 port detected
[   15.219316] hub 2-0:1.0: standalone hub
[   15.219325] hub 2-0:1.0: individual port power switching
[   15.219334] hub 2-0:1.0: no over-current protection
[   15.219343] hub 2-0:1.0: Single TT
[   15.219353] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[   15.219362] hub 2-0:1.0: power on to power good time: 10ms
[   15.219385] hub 2-0:1.0: local power source is good
[   15.219441] hub 2-0:1.0: enabling power on all ports
[   15.325200] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[   15.325373] hub 2-0:1.0: hub_suspend
[   15.325401] usb usb2: bus auto-suspend, wakeup 1
[   18.610442] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[   72.691206] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  202.149132] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Here's what I'm running:
64s #> cat /etc/dogtag
BeagleBoard.org Debian Image 2015-11-03
jstoner
Re: WiFi Problems
by drewfustini on Wed Jun 29, 2016 11:31 pm
I can't seem to find my Ourlink wifi stick [PID 1012]. When I receive the new one, I'll attempt to reproduce.
However, from the tutorial:
Out of the box the 3.8 kernel seems to have problems with popular WiFi adapters, like the Realtek-based adapters in the Adafruit store. In particular you might experience problems like the WiFi adapter randomly not connecting to a wireless network on boot. I'll show later in the guide that a simple script to reset the wireless adapter on boot greatly improves reliability of Realtek and other adapters on the BeagleBone Black.
Please try the instructions under:
WiFi Reset Service
The next step is to install a small script that will reset the WiFi interface by bringing it down and back up again automatically on boot. With the latest 3.8 kernel I found this reset script was necessary to get reliable performance with Realtek and some Atheros WiFi adapters, so don't skip installing it! Later kernels or more stable adapters might not require the reset service, but it can't hurt to install it for them too.
drewfustini
Re: WiFi Problems
by jstoner on Thu Jun 30, 2016 4:07 pm
I did that. Reran the script just to be sure. Same results.
jstoner
