using universal-io / SPI mode
by rifo on Fri Jun 24, 2016 1:03 pm
I am planning to use SPI 1 in my project. I thought of proceeding like below, can you please comment whether this makes sense?
// Disable HDMI by adding below line to uEnv.txt
cape_disable=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
// Load univ overlay files
echo cape-univ-hdmi > /sys/devices/bone_capemgr.9/slots
echo cape-universal > /sys/devices/bone_capemgr.9/slots
// Change appropriate pin modes to SPI
config-pin P9.28 spi
config-pin P9.29spi
config-pin P9.30 spi
config-pin P9.31 spi
thanks a lot
rifo
rifo
Re: using universal-io / SPI mode
by drewfustini on Fri Jun 24, 2016 9:44 pm
Which Debian image are you using?
Are there other pins / peripherals that you are planing to use?
drewfustini
by rifo on Sat Jun 25, 2016 3:18 am
I am using " BeagleBoard.org Debian Image 2015-03-01 " and
my kernel version is "Linux beaglebone 3.8.13-bone79 #1 SMP Tue Oct 13 20:44:55 UTC 2015 armv7l GNU/Linux"
Actually I want to control multiple spi slave devices so I planned to use extra GPIOs to as Slave Select.
rifo
by drewfustini on Sun Jun 26, 2016 5:47 am
For the Linux 3.8 kernel, it may be simpler to just use a device tree overlay for SPI0 or SPI1.
For example, to enable SPI0, edit /boot/uboot/uEnv.txt:
cape_enable=capemgr.enable_partno=BB-SPIDEV0
Verify that SPIDEV0 is loaded:
$ cat /sys/devices/bone_capemgr.9/slots
<snip>
7: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-SPIDEV0
As for using GPIO as Chip Select, you should check out this post :
GPIO Chip Selects with the BeagleBone
drewfustini
by rifo on Sun Jun 26, 2016 6:28 am
Hello Drew
Thanks again for the answers. I may add a gps and some other sensors later on during the project.
So to have a general solution
can you please comment about changing to spi mode with config-pin?
rifo
by drewfustini on Thu Jun 30, 2016 1:29 am
Here is example of configuring the SPI0 pins.
First, verify cape unverisal is loaded:
root@beaglebone:~# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,cape-universaln
root@beaglebone:~# uname -a
Linux beaglebone 4.4.11-ti-r29 #1 SMP Fri May 27 22:58:36 UTC 2016 armv7l GNU/Linux
root@beaglebone:~# cat /etc/dogtag
BeagleBoard.org Debian Image 2016-06-05
Next check the possible modes for the pins:
root@beaglebone:~# config-pin -l P9.17
default gpio gpio_pu gpio_pd spi i2c pwm
root@beaglebone:~# config-pin -l P9.17 #SPI0_CS
root@beaglebone:~# config-pin -l P9.18 #SPI0_D1
root@beaglebone:~# config-pin -l P9.22 #SPI0_SCLK
default gpio gpio_pu gpio_pd spi uart i2c pwm
root@beaglebone:~# config-pin -l P9.21 #SPI0_D0
Set the SPI0 pins to spi mode:
root@beaglebone:~# config-pin P9.17 spi #SPI0_CS
root@beaglebone:~# config-pin P9.18 spi #SPI0_1
root@beaglebone:~# config-pin P9.21 spi #SPI0_D0
root@beaglebone:~# config-pin P9.22 spi #SPI0_SCLK
Check that the pins were set to SPI mode OK:
root@beaglebone:~# config-pin -q P9.17
P9_17 Mode: spi
root@beaglebone:~# config-pin -q P9.18
P9_18 Mode: spi
root@beaglebone:~# config-pin -q P9.21
P9_21 Mode: spi
root@beaglebone:~# config-pin -q P9.22
P9_22 Mode: spi
drewfustini
