Sometimes I have to take my headless linux BBB to places that I don't know the WiFi SSID/Password before hand. SSH does not reliably work via usb, which is a pain anyways with my enclosure.
Is there a wireless way to change SSID/Password settings on the fly. I'm a mechanical Engineer, I don't know complex linux concepts, maybe this is trivial.
Some consumer IoT devices broadcast there own network for initial config of home SSID/Password. Is that possible? Necessary equipment/software/code?
Changing to arbitrary wifi network on headless system
- kdeangel
- drewfustini
Re: Changing to arbitrary wifi network on headless system
WiFiDog is software that allows Linux to act as a captive wifi portal:
http://dev.wifidog.org/
Jason Kridner of BeagleBoard.org and SeeedStudio have been working on using that for the setup process of the BeagleBone Green Wireless (which has built-in WiFi):
Pillar1989/wifidog-server
https://libraries.io/github/Pillar1989/wifidog-server
jadonk/wifidog-gateway forked from Pillar1989/wifidog-gateway
Repository for the wifidog-gateway captive portal designed for embedded systems
https://github.com/jadonk/wifidog-gateway
jadonk/wifidog-server forked from Pillar1989/wifidog-server
wifidog nodejs server
https://github.com/jadonk/wifidog-server
You may want to ask about this use case on the beagleboard mailing list:
https://groups.google.com/forum/#!topic/beagleboard
