Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
How Adafruit_BBIO Library can be integrated in Qt Creator?
by geron on Thu Jul 07, 2016 7:24 pm
I`m trying to use Adafruit_BBIO Library into Qt Creator , but Qt Creator can not recognize the Library.
# Project created by QtCreator 2016-06-21T20:15:43
QT += core gui
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = Example_Beaglebone_Black_Switch
TEMPLATE = app
SOURCES += main.cpp\
mainwindow.cpp
HEADERS += mainwindow.h
FORMS += mainwindow.ui
unix:!macx: LIBS += -L$$PWD/../../../usr/local/lib/python2.7/dist-packages/Adafruit_BBIO/ -lGPIO
INCLUDEPATH += $$PWD/../../../usr/local/lib/python2.7/dist-packages/Adafruit_BBIO
DEPENDPATH += $$PWD/../../../usr/local/lib/python2.7/dist-packages/Adafruit_BBIO
INCLUDEPATH += gcc -c -I/usr/include/python2.7 sourcefile.c
unix: PKGCONFIG += python2.7
I get some errors when I try to use GPIO .
mainwindow.cpp
#include "mainwindow.h"
#include "ui_mainwindow.h"
MainWindow::MainWindow(QWidget *parent) :
QMainWindow(parent),
ui(new Ui::MainWindow)
ui->setupUi(this);
import; "Adafruit_BBIO.GPIO as GPIO";
GPIO.setup("P8_10", GPIO.OUT);
The errors
/home/reyesj/Example_Beaglebone_Black_Switch/mainwindow.cpp:12: error: 'import' was not declared in this scope
/home/reyesj/Example_Beaglebone_Black_Switch/mainwindow.cpp:12: warning: statement has no effect [-Wunused-value]
/home/reyesj/Example_Beaglebone_Black_Switch/mainwindow.cpp:13: error: 'GPIO' was not declared in this scope
Regards
geron
Re: How Adafruit_BBIO Library can be integrated in Qt Creato
by drewfustini on Fri Jul 08, 2016 2:19 pm
Adafruit_BBIO is a Python library so I don't think it would be compatible for Qt Creator which I believe is for C++.
You could use Adafruit_BBIO with PyQt potentially:
https://wiki.python.org/moin/PyQt
I did use PyQt on the BeagleBone a few years ago:
https://www.element14.com/community/com ... -python-qt
If you want to stick to C or C++, then you might want to look at:
libsoc: C library for interfacing with common SoC peripherals through generic kernel interfaces
https://github.com/jackmitch/libsoc
mraa: Low Level Skeleton Library for IO Communication on GNU/Linux platforms
https://github.com/intel-iot-devkit/mraa
drewfustini
by geron on Fri Jul 08, 2016 3:06 pm
Thanks a lot for your answer.
Now is clear for me , Adafruit_BBIO is not compatible with Qt Creator.
I will try to use PyQt .
geron
