MintyComm download?
by ryder1650 on Sat May 28, 2005 4:51 pm
In my case I am really confused. I got the bootloader to program, the code was verified to be correct, the USB is recognized, but tinybld does not detect it. What could be wrong?
ryder1650
by luke on Sun May 29, 2005 12:06 am
i'm not sure if this will help you, but:
in my case, the usb was recognized, but a couple of the pins were not connected correctly. i can only assume that means that the a couple of the pins are necessary for communication but not for detection.
you should also check the frequencies of your crystals. also, the inductor bead is not listed in the directions as a part needed for the USB system, but it is in the schematic. have you soldered that in?
as a last check, I like to go in with a multimeter and check for connectivity between places that should be connected (i.e. each pin on the PIC and its end point. for example, pin 24 and 25 on the FTDI chip (RX,TX) and pin 43 & 44 on the PIC). Go through each connection used in the necessary system and ensure connectivity.
luke
by ryder1650_guest on Sun May 29, 2005 12:08 am
LOL, I had the baud rate set at 115200 instead of 19500, I got it to program!
ryder1650_guest
by terpDriver on Sun May 29, 2005 11:24 am
whoah. I changed my setting in the Tiny Bootloader program to 19200 and now it finds my PIC. I just get a "Could not write" error now.
terpDriver
by ryder1650 on Sun May 29, 2005 2:43 pm
Is the switch in the off position?
ryder1650
by terpDriver on Sun May 29, 2005 6:50 pm
i've tried it in both positions. also tried hitting "write flash" and then toggling the switch both ways. I'm building two minty's at the same time. i was able to get it to program one now. the only difference was i had the battery hooked up to that one. then i was able to open hyper terminal and get it to spit out garbage once, but now nothing (and i tried the two different speeds in hyperterminal. should the other hyper terminal settings be changed? i assume flow control should be none.)
terpDriver
by ryder1650 on Sun May 29, 2005 6:57 pm
In hyperterminal i found that my leads were not getting a good connection on the battery. I ended up having to use my fingers to hold the leads down (with electrical tape covering them) and then I got hyperterm to print the minty mp3 thing and then it said resetting card...
ryder1650
Re: MintyComm download?
by BugBountyPrograms on Tue Oct 23, 2018 5:16 pm
hi
BugBountyPrograms
