USB instead of serial
by qwerty693 on Mon Sep 26, 2005 3:02 pm
Another thing: I want to try and eliminate the problem of the stunningly slow transfer rate of the Minty by using a USB 2.0 interface rather than the Serial to USB chip. In otherwords, I understand that you could convert, with a chip from Serial to USB, but the total transfer rate still can't exeed like 115kbps, and if you could wire some type of direct USB chip onto the PCB, it might increase the speed a bunch.
qwerty693
by ryder1650 on Mon Sep 26, 2005 6:57 pm
you can use a USB 2 card reader also. Much easier I'd say.
ryder1650
by Guest on Mon Sep 26, 2005 8:36 pm
Only problem is, I'm trying to build mine without a removeable CF, rather a component one. So I can't just pop the card into a reader...
Guest
by qwerty693 on Mon Sep 26, 2005 8:37 pm
qwerty693
by terpDriver on Tue Oct 04, 2005 2:22 pm
The USB->serial chip isn't what is limiting the file transfer speed. Its the PIC microchip that slows it down.
terpDriver
