Harddrive
Harddrive
by byrnerat101 on Fri Apr 08, 2005 2:52 pm
How would I go about swapping an ide harddrive for the cf card? Ive seen adapters for them but would i need to make any programming or other such changes? Anyone have a practicle way to power the device? Also, what format would the drive have to be in, what kind of partitioning scheme? Thanks,
~Patch
byrnerat101
by Guest on Sat Apr 30, 2005 6:06 am
Good idea! I would like to know too. HD has a lot more space for less money comparative to cards.
Guest
by xoxota on Sat Apr 30, 2005 5:14 pm
Caveat: I know nothing about this.
...but I would imagine the HD would need a seperate power supply (I really doubt the 3.7V would do it :)).
xoxota
by Tom61 on Sat Apr 30, 2005 6:49 pm
If it uses standard ATA commands it should work. Some of the newer laptop drives can use 3.3Volts for power.
Tom61
harddrive
by The_Truth on Thu Jul 07, 2005 1:59 am
lol.. just wait a few mts, and you can get one of the new NAND harddrives... 16 gigabytes, of NAND chips... the power consumption is alot lower(they claim it adds ~30minutes of battery life)... not sure about voltage tho...lol..
The_Truth
Re: harddrive
by xoxota on Fri Jul 08, 2005 10:33 am
The_Truth wrote:lol.. just wait a few mts, and you can get one of the new NAND harddrives... 16 gigabytes, of NAND chips
Dang! More info plz. Link?
xoxota
harddrive
by tony on Tue Nov 15, 2005 7:00 am
i was wondering did anyone manage to hook it up to a hard drive.
i have one i could use and i wouldn't need to transfer files to it as i have an adapter
tony
by kuenrg on Tue Nov 15, 2005 6:16 pm
I might pursue this sometime but not anytime soon so don't hold your breath.
However, a couple of comments...
Most current HDDs need 5V (I did a brief scan of the Fujitsu sight and they don't seem to offer any 3.3 but they're probably out there)
If you're thinking about tapping off the USB port (which would eliminate the mobility) - USB devices are limited to 500mA, a brief scan of the HDD's that I have give a range of 1A to 550mA - which is quite a lot. (Ipod's and the like don't use these regular 2.5" drives)
I happen to have some solid state disks that only require 250mA so that's why I'm considering this option but normally they would be much more expensive than an equivalent CF card.
I haven't looked at what data lines would be needed...
But the main thing is - it wouldn't fit in the the case so it wouldn't be very minty at all!
kuenrg
by TheMaximumweasel on Fri Jan 06, 2006 9:40 pm
also the filesystem used for minty can't read more than 2GB so your better off with just the CF cards.
Max
TheMaximumweasel
