Says it is programmed but isn't actually working
by TheMaximumWeasel on Sat Jan 07, 2006 11:33 pm
ok so I am programming my pic with IC-Prog I got the update for xp and the com and all that are corectly set up when I click read the light on my programmer is lit and I get just a blank reading then when I programming it says verify failed at 0000h ! and then when I read again I get just blank, default, no code programmed on it what is wrong.
Max
TheMaximumWeasel
by Student on Sun Jan 08, 2006 3:57 am
I think I had a similar problem, and so after trying many different things, I went out and bought a USB programmer. When I hooked it up and had it verify a chip that IC-prog had said failed, it verified correctly. So your PIC may be programmer, just not verifying correctly.
Student
by TheMaximumweasel on Sun Jan 08, 2006 2:28 pm
what is the difference between verify and read cause whenever I read it never shows the code I programmed.
Max
TheMaximumweasel
by Guest on Sun Jan 08, 2006 8:44 pm
Verify compares the code on the PIC to the code you loaded with IC-Prog (to verify it matches). Read just shows the code from the PIC.
Guest
by TheMaximumweasel on Sun Jan 08, 2006 11:32 pm
How come it won't program the microcontroller then cause every time I read it is allways all zero's
Max
TheMaximumweasel
by ut20xx on Mon Jan 09, 2006 10:18 pm
Maybe you have the cable hooked up wrong, or the cable or the PIC could be defective, or you serial port could just have issues with that programmer.
Try running the Hardware Check in IC-Prog (under the Settings menu).
ut20xx
by TheMaximumweasel on Fri Jan 13, 2006 4:57 pm
ok I did hardware check checked all of the boxes then when I click ok it closes and nothing happens
Max
TheMaximumweasel
by TheMaximumweasel on Fri Jan 13, 2006 5:02 pm
ok so I did a read then verify and it worked so the problem is is it won't program what could be wrong with where I soldered the wires could they be connected on accident or one of them might be switched.
Max
TheMaximumweasel
