no wifi network in focus for pi zero w on noobs v2.4
by spicypenutsauce on Mon Apr 17, 2017 12:34 am
I puchased two pi zero w with camera from adafruit on Mach 17, 2017 which I did not received until a week later. One of the pi zero worked OK on the noobs v2.4 with Wifi network in focus and I could click the Wifi network and connected it to my router. The other pi zero W did not work the same. There is no Wifi network icon in focus.
The invoice number is 1396126. Order date: Friday 17 March 2017.
2 x Raspberry Pi Zero W Camera Pack.
I attached the invoice, the noobs v2.4 screen shot showing no Wifi Network in focused for this Pi Zero W, the front and back of the board.
I like to know if I can get a replacement board.
spicypenutsauce
Re: no wifi network in focus for pi zero w on noobs v2.4
by spicypenutsauce on Mon Apr 17, 2017 12:36 am
Here is the noobs screen shot with the pi zero w in front of the screen.
spicypenutsauce
by adafruit_support_mike on Tue Apr 18, 2017 2:45 am
Please post the output from `dmesg` on the Zero-W that doesn't see any nearby networks.
by spicypenutsauce on Thu Apr 20, 2017 1:48 am
pi-dmesg.log
this is the dmesg dump from my pi zero W that does not see the near by Wifi routers
(18.4 KiB) Downloaded 14 times
Here is my dmesg.
spicypenutsauce
by adafruit_support_mike on Fri Apr 21, 2017 4:20 am
Something unusual is happening there.. according to the messages, the OS thinks it's running on a Pi2:
[    0.000000] Linux version 4.4.50+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #970 Mon Feb 20 19:12:50 GMT 2017
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine model: Raspberry Pi Model B Rev 2
Try writing a fresh copy of the latest Raspbian to the SD card and see if that helps. As it is, the kernel isn't even looking for a Wifi chip.
by spicypenutsauce on Sat Apr 22, 2017 6:38 pm
I tried a newly made SD Card made from the posted noobs v2.4 and the dmesg still showing the same 'Machine model: Raspberry Pi Model B Rev 2'. This same SD Card when used on my other pi zero w board, it showed 'Machine model: Raspberry Pi Zero W Rev 1.1' . It looks like there is wrong SOC installed on my bad pi zero w.
So I tried 3 Noobs v2.4 SD Card on this bad pi zero w board, all showed the 'Raspberry Pi Model B Rev2' CPU.
Thanks,
Manot
spicypenutsauce
by adafruit_support_mike on Mon Apr 24, 2017 12:35 am
Thank you.
I'm not sure what's going wrong there, but it does sound like a discrepancy in the hardware. Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you a replacement RasPi Zero-W.
by spicypenutsauce on Fri Apr 28, 2017 10:03 pm
I have sent a note with my invoice number to support@adafruit.com and did not hear from the support group at all. Can you check if the message has been correctly delivered?
spicypenutsauce
by adafruit_support_mike on Sat Apr 29, 2017 4:29 am
I'll check with them, but double-check your trash folder and spam filter. They usually reply within minutes of getting a message.
by spicypenutsauce on Tue May 09, 2017 12:53 am
Did you check with your support@adafruit.com about my raspi Pi zero W replacement?
It has been a couple of weeks with no reply or actions.
Thanks,
Manot
spicypenutsauce
by adafruit_support_mike on Wed May 10, 2017 3:01 am
Your message was logged at 12:00 AM April 25, and their response was logged as going out at 6:27 April 25th.
Send another note, and be sure to check your spam filter, etc if you don't see a response in your inbox. The incoming address will either be support@adafruit.com or communitysupport@adafruit.com
