Adafruit 2.8" PiTFT how to get working on Zero W
by m47k0 on Fri Sep 08, 2017 7:26 am
hi
have tried Easy Install
have tried the 3 Step Install that follows the Easy Install
have tried various methods gleaned from posts in forum here
from what I can make out current 'Stretch' version of the OS breaks things
does anyone have a recipe that works?
thanks
Mark
m47k0
Re: Adafruit 2.8" PiTFT how to get working on Zero W
by adafruit_support_mike on Sat Sep 09, 2017 1:09 am
For now, the best solution is to use the last release of Jessie and install PiTFT support on top of that. You can get older Raspbian OS images here:
http://downloads.raspberrypi.org/raspbian/images/
by lbendlin on Sat Sep 09, 2017 9:22 pm
Also, you may need to run the "installsdl.sh" script that downports SDL to version 1.2. Otherwise your touchscreen will not work with pygame.
lbendlin
by m47k0 on Mon Sep 11, 2017 3:58 am
hi
thanks for response
downloading img...
its for a Processing based project
Mark
m47k0
by m47k0 on Mon Sep 11, 2017 9:57 am
hi
I'm now running 2017-07-05-raspbian-jessie & about to try again
in
viewtopic.php?f=50&t=121797
skorpioskorpio provides the following:
In current distributions it really isn't necessary to use the Ada Fruit kernel, any of the more recent distributions of Raspbian have everything in the kernels already to support the PiTFTs you just need to do a little editing of the /boot/config.txt file and /boot/cmdline.txt file.
& then provides this config text
# Adafruit PiTFT and 4DS TFT
[pi0]
device_tree=bcm2708-rpi-0-w.dtb
dtoverlay=pitft28-resistive,rotate=180,speed=16000000,fps=20
dtoverlay=pi3-disable-wifi
[pi3]
device_tree=bcm2710-rpi-3-b.dtb
dtoverlay=pitft35-resistive,rotate=270,speed=62000000,fps=60
[all]
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
I don't need to disable wifi or add the 3.5" screen
So - will just editing the config.txt file with the relevant bits of the above get things working
thanks
Mark
m47k0
by adafruit_support_mike on Tue Sep 12, 2017 12:19 am
Good information.. thanks for posting it!
by m47k0 on Tue Sep 12, 2017 10:56 am
hi
it was a question not an answer...
where I am now I've edit config.txt so it ends
[pi0]
dtoverlay=pitft28-resistive,rotate=270,speed=16000000,fps=20
[all]
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
I've also edited cmdline.txt to:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=449c8f80-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fbcon=map:10 fbcon=font:VGA8x8
It now boots into a pile of green text on the pitft - but then stops on a blank black screen with a '-' char at the top
Any guidance on how to proceed would be good.
thanks
Mark
m47k0
by adafruit_support_mike on Wed Sep 13, 2017 2:42 am
by m47k0 on Wed Sep 13, 2017 10:11 am
hi
done
Section "Device"
  Identifier "display"
  Driver "fbdev"
  Option "fbdev" "/dev/fb0"
EndSection
& get X up onscreen
mouse & keyboard work - but not touch
so from
https://learn.adafruit.com/adafruit-pit ... stallation
I've also done
sudo nano /etc/modules
and add
stmpe-ts
on a line at the end
this is not enabling touch
Mark
m47k0
by m47k0 on Fri Sep 15, 2017 5:51 am
hi
so any further thoughts on how get touch to work
this project needs touch & thats what this thing is supposed to do
Mark
m47k0
by adafruit_support_mike on Sat Sep 16, 2017 1:47 am
Post the output from `dmesg` please. We'll see what the OS has to say.
by m47k0 on Mon Sep 18, 2017 5:38 am
hope it means more to you than me...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:34:49 BST 2017
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c0914874, node_mem_map db010000
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:DB:1D:5C vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=449c8f80-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet fbcon=map:10 fbcon=font:VGA8x8 splash plymouth.ignore_serial_console
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 435936K/458752K available (5946K kernel code, 489K rwdata, 1948K rodata, 400K init, 734K bss, 14624K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
    lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc05d6bbc   (5947 kB)
      .init : 0xc0840000 - 0xc08a4000   ( 400 kB)
      .data : 0xc08a4000 - 0xc091e728   ( 490 kB)
       .bss : 0xc091e728 - 0xc09d5f28   ( 734 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000062] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000154] bcm2835: system timer (irq = 27)
[    0.000632] Console: colour dummy device 80x30
[    0.000655] console [tty1] enabled
[    0.000680] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060299] pid_max: default: 32768 minimum: 301
[    0.060725] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060741] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.061805] Disabling cpuset control group subsystem
[    0.062012] CPU: Testing write buffer coherency: ok
[    0.062070] ftrace: allocating 21712 entries in 64 pages
[    0.176685] Setting up static identity map for 0x8200 - 0x8238
[    0.178666] devtmpfs: initialized
[    0.188529] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.188933] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.188960] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.190234] pinctrl core: initialized pinctrl subsystem
[    0.191677] NET: Registered protocol family 16
[    0.194294] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.204163] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.204178] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.204281] Serial: AMBA PL011 UART driver
[    0.207419] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.208104] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.257468] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[    0.260063] SCSI subsystem initialized
[    0.260310] usbcore: registered new interface driver usbfs
[    0.260420] usbcore: registered new interface driver hub
[    0.260615] usbcore: registered new device driver usb
[    0.266753] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[    0.268794] clocksource: Switched to clocksource timer
[    0.324960] VFS: Disk quotas dquot_6.6.0
[    0.325076] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.325375] FS-Cache: Loaded
[    0.325732] CacheFiles: Loaded
[    0.345047] NET: Registered protocol family 2
[    0.346416] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.346504] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.346598] TCP: Hash tables configured (established 4096 bind 4096)
[    0.346690] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.346716] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.347010] NET: Registered protocol family 1
[    0.347753] RPC: Registered named UNIX socket transport module.
[    0.347764] RPC: Registered udp transport module.
[    0.347769] RPC: Registered tcp transport module.
[    0.347774] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.349207] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.351610] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.371572] FS-Cache: Netfs 'nfs' registered for caching
[    0.373306] NFS: Registering the id_resolver key type
[    0.373352] Key type id_resolver registered
[    0.373358] Key type id_legacy registered
[    0.377811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.378179] io scheduler noop registered
[    0.378191] io scheduler deadline registered (default)
[    0.378660] io scheduler cfq registered
[    0.384498] BCM2708FB: allocated DMA memory 5b500000
[    0.384557] BCM2708FB: allocated DMA channel 0 @ dc80d000
[    0.393066] Console: switching to colour frame buffer device 82x52
[    0.401042] bcm2835-rng 20104000.rng: hwrng registered
[    0.401204] vc-cma: Videocore CMA driver
[    0.401214] vc-cma: vc_cma_base      = 0x00000000
[    0.401222] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.401227] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.401615] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.426831] brd: module loaded
[    0.439253] loop: module loaded
[    0.439274] Loading iSCSI transport class v2.0-870.
[    0.440143] usbcore: registered new interface driver smsc95xx
[    0.440171] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.668499] Core Release: 2.80a
[    0.668519] Setting default values for core params
[    0.668555] Finished setting default values for core params
[    0.868990] Using Buffer DMA mode
[    0.869002] Periodic Transfer Interrupt Enhancement - disabled
[    0.869007] Multiprocessor Interrupt Enhancement - disabled
[    0.869018] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.869107] Dedicated Tx FIFOs mode
[    0.869762] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[    0.869788] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    0.869801] dwc_otg: Microframe scheduler enabled
[    0.869886] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04512ec
[    0.869899] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04515c8 length 36
[    0.869925] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
[    0.869997] dwc_otg 20980000.usb: DWC OTG Controller
[    0.870060] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.870182] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.870232] Init: Port Power? op_state=1
[    0.870238] Init: Power Port (0)
[    0.870610] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.870627] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.870638] usb usb1: Product: DWC OTG Controller
[    0.870647] usb usb1: Manufacturer: Linux 4.9.35+ dwc_otg_hcd
[    0.870656] usb usb1: SerialNumber: 20980000.usb
[    0.871816] hub 1-0:1.0: USB hub found
[    0.871907] hub 1-0:1.0: 1 port detected
[    0.872867] dwc_otg: FIQ enabled
[    0.872877] dwc_otg: NAK holdoff enabled
[    0.872882] dwc_otg: FIQ split-transaction FSM enabled
[    0.872903] Module dwc_common_port init
[    0.873396] usbcore: registered new interface driver usb-storage
[    0.873852] mousedev: PS/2 mouse device common for all mice
[    0.875482] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.875991] bcm2835-cpufreq: min=700000 max=1000000
[    0.876610] sdhci: Secure Digital Host Controller Interface driver
[    0.876618] sdhci: Copyright(c) Pierre Ossman
[    0.877084] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[    0.879643] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[    0.879821] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.880345] ledtrig-cpu: registered to indicate activity on CPUs
[    0.880494] hidraw: raw HID events driver (C) Jiri Kosina
[    0.880768] usbcore: registered new interface driver usbhid
[    0.880775] usbhid: USB HID core driver
[    0.882044] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
[    0.884446] Initializing XFRM netlink socket
[    0.884505] NET: Registered protocol family 17
[    0.884682] Key type dns_resolver registered
[    0.887273] registered taskstats version 1
[    0.887806] vc-sm: Videocore shared memory driver
[    0.887828] [vc_sm_connected_init]: start
[    0.893783] [vc_sm_connected_init]: end - returning 0
[    0.902709] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.905156] sdhost: log_buf @ db513000 (5b513000)
[    0.978873] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.981434] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.981449] mmc-bcm2835 20300000.mmc: DMA channel allocated
[    1.011308] random: fast init done
[    1.056396] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.058474] mmc0: new high speed SDHC card at address 0001
[    1.059018] of_cfs_init
[    1.059139] of_cfs_init: OK
[    1.059988] Waiting for root device PARTUUID=449c8f80-02...
[    1.061138] mmcblk0: mmc0:0001 0000 7.44 GiB
[    1.069275]  mmcblk0: p1 p2
[    1.079442] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.081097] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.082739] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.085666] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.089035] Indeed it is in host mode hprt0 = 00021501
[    1.193680] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.193788] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.195628] devtmpfs: mounted
[    1.197033] Freeing unused kernel memory: 400K (c0840000 - c08a4000)
[    1.197044] This architecture does not have kernel memory protection.
[    1.261162] mmc1: new high speed SDIO card at address 0001
[    1.288916] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.289141] Indeed it is in host mode hprt0 = 00001101
[    1.519670] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    1.519711] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.519724] usb 1-1: Product: USB 2.0 Hub
[    1.521088] hub 1-1:1.0: USB hub found
[    1.521250] hub 1-1:1.0: 4 ports detected
[    1.620990] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    1.621763] systemd[1]: Detected architecture 'arm'.
[    1.761377] NET: Registered protocol family 10
[    1.763352] systemd[1]: Inserted module 'ipv6'
[    1.766418] systemd[1]: Set hostname to <raspberrypi>.
[    1.766839] systemd[1]: Initializing machine ID from random generator.
[    1.767383] systemd[1]: Installed transient /etc/machine-id file.
[    1.838968] usb 1-1.2: new high-speed USB device number 3 using dwc_otg
[    1.978556] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1006
[    1.978577] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.978587] usb 1-1.2: Product: Keyboard Hub
[    1.978597] usb 1-1.2: Manufacturer: Apple, Inc.
[    1.978606] usb 1-1.2: SerialNumber: 000000000000
[    1.980299] hub 1-1.2:1.0: USB hub found
[    1.980711] hub 1-1.2:1.0: 3 ports detected
[    2.078962] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[    2.089203] hub 1-1.2:1.0: hub_ext_port_status failed (err = -71)
[    2.089862] usb 1-1.2: Failed to suspend device, error -71
[    2.210904] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8152
[    2.210925] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.210937] usb 1-1.4: Product: USB 10/100 LAN
[    2.210946] usb 1-1.4: Manufacturer: Realtek
[    2.210955] usb 1-1.4: SerialNumber: 00E04C360B15
[    2.213408] usb 1-1.2: USB disconnect, device number 3
[    2.518924] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[    2.533135] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[    2.540182] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    2.541066] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.541282] systemd[1]: Starting Remote File Systems (Pre).
[    2.658405] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1006
[    2.658427] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.658440] usb 1-1.2: Product: Keyboard Hub
[    2.658450] usb 1-1.2: Manufacturer: Apple, Inc.
[    2.658459] usb 1-1.2: SerialNumber: 000000000000
[    2.659863] hub 1-1.2:1.0: USB hub found
[    2.660045] hub 1-1.2:1.0: 3 ports detected
[    2.873508] fuse init (API version 7.26)
[    2.924929] i2c /dev entries driver
[    2.978956] usb 1-1.2.1: new low-speed USB device number 6 using dwc_otg
[    3.117220] usb 1-1.2.1: New USB device found, idVendor=05ac, idProduct=0304
[    3.117242] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.117252] usb 1-1.2.1: Product: Apple Optical USB Mouse
[    3.117261] usb 1-1.2.1: Manufacturer: Mitsumi Electric
[    3.218998] usb 1-1.2.2: new low-speed USB device number 7 using dwc_otg
[    3.361707] usb 1-1.2.2: New USB device found, idVendor=05ac, idProduct=0250
[    3.361729] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.361738] usb 1-1.2.2: Product: Apple Keyboard
[    3.361749] usb 1-1.2.2: Manufacturer: Apple Inc.
[    4.185769] systemd-udevd[121]: starting version 215
[    6.179172] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.494351] input: Mitsumi Electric Apple Optical USB Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:05AC:0304.0001/input/input0
[    6.529480] apple 0003:05AC:0304.0001: input,hidraw0: USB HID v1.10 Mouse [Mitsumi Electric Apple Optical USB Mouse] on usb-20980000.usb-1.2.1/input0
[    6.532922] input: Apple Inc. Apple Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/0003:05AC:0250.0002/input/input1
[    6.600762] apple 0003:05AC:0250.0002: input,hidraw1: USB HID v1.11 Keyboard [Apple Inc. Apple Keyboard] on usb-20980000.usb-1.2.2/input0
[    6.635588] input: Apple Inc. Apple Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.1/0003:05AC:0250.0003/input/input2
[    6.699450] apple 0003:05AC:0250.0003: input,hidraw2: USB HID v1.11 Device [Apple Inc. Apple Keyboard] on usb-20980000.usb-1.2.2/input1
[    6.898722] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    7.058120] stmpe-spi spi0.1: unknown chip id: 0x0
[    7.058198] stmpe-spi: probe of spi0.1 failed with error -22
[    8.199613] usbcore: registered new interface driver brcmfmac
[    8.433500] brcmfmac: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    9.027881] systemd-journald[117]: Received request to flush runtime journal from PID 1
[    9.382184] usbcore: registered new interface driver r8152
[    9.393068] usbcore: registered new interface driver cdc_ether
[    9.478977] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
[    9.691150] r8152 1-1.4:1.0 eth0: v1.08.8
[   10.279142] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[   10.334971] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[   10.336413] fbtft_of_value: buswidth = 8
[   10.336427] fbtft_of_value: debug = 0
[   10.336433] fbtft_of_value: rotate = 270
[   10.336438] fbtft_of_value: fps = 20
[   11.486121] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 16 MHz
[   13.272914] random: crng init done
[   13.697866] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   13.697903] brcmfmac: power management disabled
[   14.652807] uart-pl011 20201000.serial: no DMA platform data
[   15.719177] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   18.047992] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:167932k SSFS
[   18.573082] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.138887] Bluetooth: Core ver 2.22
[   19.139023] NET: Registered protocol family 31
[   19.139030] Bluetooth: HCI device and connection manager initialized
[   19.140711] Bluetooth: HCI socket layer initialized
[   19.140734] Bluetooth: L2CAP socket layer initialized
[   19.140787] Bluetooth: SCO socket layer initialized
[   19.156103] Bluetooth: HCI UART driver ver 2.3
[   19.156120] Bluetooth: HCI UART protocol H4 registered
[   19.156125] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   19.156340] Bluetooth: HCI UART protocol Broadcom registered
[   19.706265] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.706277] Bluetooth: BNEP filters: protocol multicast
[   19.706304] Bluetooth: BNEP socket layer initialized
m47k0
by adafruit_support_mike on Tue Sep 19, 2017 2:17 am
It starts to make more sense after you've read a few hundred.. ;-)
The OS says it can't find the touchscreen driver:
Could you post a photo showing the back of the PiTFT please?
by m47k0 on Tue Sep 19, 2017 4:03 am
hi
see below
m47k0
by adafruit_support_mike on Wed Sep 20, 2017 2:20 am
Are those hammer headers in the RasPi, or regular pin header?
