Volumio with Adafruit I2S 3W Stereo Speaker Bonnet
by neilhendrick2 on Thu Oct 12, 2017 3:54 pm
I have set up a Raspberry Pi 0 W using the latest version of Volumio (2.285) https://volumio.org/. And I have added the Adafruit I2S 3W Stereo Speaker Bonnet for Raspberry Pi https://www.adafruit.com/product/3346
So, I have turned on the Volumio setting in Playback Options for I2S Dac (ON), but I cannot determine how I should set the other options. There is no specific choice for "Adafruit I2S 3W Stereo Speaker Bonnet". I have tried to select various settings in this section and the result sometimes crashes and reboots the raspi, or alternatively just does nothing.
What should i select for Output Device?
What should i select for DAC Model?
Should I change other Playback options such as DSD Playback mode?
thanks for your help,
Neil
PS: I did do some testing and I am able to run sound through the DAC and hear it from the speakers using the following commands. These all work fine:
Simple white noise speaker test
speaker-test -c2
Simple WAV speaker test
speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/Front_Center.wav
Simple MP3 speaker test
mpg123 http://ice1.somafm.com/u80s-128-mp3
Output from alsamixer
lqqqqqqqqqqqqqqqqqqqqqqqqqqqqq AlsaMixer v1.0.28 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x Card: bcm2835 ALSA                                   F1:  Help               x
x Chip: Broadcom Mixer                                 F2:  System information x
x View: F3:[Playback] F4: Capture  F5: All             F6:  Select sound card  x
x Item: PCM [dB gain: -13.50]
neilhendrick2
Re: Volumio with Adafruit I2S 3W Stereo Speaker Bonnet
by adafruit_support_mike on Fri Oct 13, 2017 1:26 am
We don't know anything about volumeio, so don't have any suggestions to offer there.
The information about making the I2C amplifier talk to ALSA is in this part of the tutorial:
https://learn.adafruit.com/adafruit-spe ... y-pi-usage
Hopefully something there will look close enough to one of the volumeio settings to be useful.
