Raspberry pi 7" touchscreen problem
by CryDice on Mon May 07, 2018 7:50 am
hi , i tried to connect my raspberry to the display , i connected every cable and i tried with and without Yellow and green cable.
when i power up my raspberry the touchscreen only show vertical lines. i listen that can be a screen problem .
i need a solution faster as you can because i want to make my exam's project.
in the micro sd i have installed raspbian .
Order No: 1725346-1741849926
i will link some images here:
https://drive.google.com/open?id=1-nBZa ... O2oTtS1Vzv
https://drive.google.com/open?id=1vwcGJ ... ZR_ZqxyLqc
https://drive.google.com/open?id=1CWXSa ... GNlUnObwhP
https://drive.google.com/open?id=1iKgWB ... r30CDUOrtV
CryDice
Re: Raspberry pi 7" touchscreen problem
by adafruit_support_carter on Wed May 16, 2018 1:15 pm
How are you powering the setup - what is your power supply and where are you connecting it?
Did you add ignore_lcd=0 to /boot/config.txt?
https://www.raspberrypi.org/documentati ... /README.md
by CryDice on Wed May 16, 2018 1:56 pm
Hi , thank you for the reply.
I’m powering up the raspberry with a 5V 2.5A charger and I connected the display board to the raspberry .
5V screen = 1 pin of the right side
Ground screen = 3 pin of the right side
But I also tried to power up the display from the micro USB port directly on the touchscreen board.
CryDice
by adafruit_support_carter on Wed May 16, 2018 2:12 pm
Try making the change to /boot/config.txt mentioned above and try powering it this way again.
For now, leave all four of those jumper cables attached. You seem to have them connected properly.
by CryDice on Thu May 17, 2018 12:26 pm
i just tried but nothing happens, i've got the same problem.
CryDice
by adafruit_support_carter on Thu May 17, 2018 1:39 pm
Are you sure the Pi itself is OK and booting? Can you log into it over wifi after booting?
by CryDice on Thu May 17, 2018 2:02 pm
Yes i’m sure about that . I use the pi normally and it boot and WiFi connecting normally
CryDice
by adafruit_support_carter on Fri May 18, 2018 11:34 am
Inlining images for reference:
by adafruit_support_carter on Fri May 18, 2018 11:38 am
Not sure what's wrong. Everything looks connected correctly. Let's replace it. Send an email to support@adafruit.com with a link to this thread and they can get you a replacement display. They may also arrange return shipping for the one you have now.
by CryDice on Fri May 18, 2018 1:58 pm
I’ve just done . Thank you very much
CryDice
by adafruit2 on Sun May 20, 2018 2:18 pm
check the ears on the Display connector are fully pushed in, on your pics they're loose and they need to be fully seated. that's on the display half of the cable
adafruit2
Site Admin
by CryDice on Sun May 20, 2018 3:04 pm
You are right ! I just tried and it works!
You should stop the replacement order!
CryDice
by adafruit2 on Sun May 20, 2018 3:29 pm
email support@adafruit - we dont handle the resplacement shipments here
thx
adafruit2
Site Admin
by CryDice on Mon May 21, 2018 11:18 am
I’have done .
I have another question . How I can set the display brightness? The display is so dark , I tried to do this :
https://raspberrypi.stackexchange.com/q ... en-display
The brightness is modified but with the max set (255) the screen result so dark.
I have a good power source .
CryDice
by adafruit2 on Mon May 21, 2018 1:46 pm
yeah its not the brightest screen, its not IPS
adafruit2
Site Admin
