My Raspberry pi3 B+ does not boot (new firmware)
by osossomething on Tue Jun 19, 2018 4:41 pm
hi,
this is regarding Order #1777059-0180028111
the pi only booted once to raspberry rainbow screen for a short time and it never booted back. I downloaded the latest firmware with no results at all. the red LED is always on and the screen is blank. I moved the sd card to my raspberry pi zero and it boots without issues
I followed the official installation guide and I have plenty of raspberry Pi devices before. I used a raspberry AC power adaptor and it does not make a difference. I tried this 2 weeks ago and I double checked today. I could upload a video of the whole process
regards
osossomething
Re: My Raspberry pi3 B+ does not boot (new firmware)
by adafruit_support_carter on Tue Jun 19, 2018 5:10 pm
Which specific OS version were you using? Do you have a multimeter we could use for testing?
by osossomething on Wed Jun 20, 2018 8:36 pm
adafruit_support_carter wrote:Which specific OS version were you using? Do you have a multimeter we could use for testing?
I used both win 10 and ubuntu 16 to create the sd card. I used latest Noob 2.8 installer and also the latest raspian stretch from 2 days ago. the sd card boot on my raspberry pi zero so I believe the sd card is ok, only the pi3 B+ does not work. yes I have a multi-meter.
here is a video of me debugging the issue
https://www.youtube.com/watch?v=DaFbFNi ... e=youtu.be
regards
osossomething
by adafruit_support_carter on Thu Jun 21, 2018 12:11 pm
Thanks for the video. Can you check the voltages on the 3.3V and 5V of the GPIO header:
https://pinout.xyz/#
You can just do that with power applied. Not worried about the SD card / booting at this point. Just wondering if it may be power related.
by osossomething on Thu Jun 21, 2018 5:33 pm
adafruit_support_carter wrote:Thanks for the video. Can you check the voltages on the 3.3V and 5V of the GPIO header:
5V pin is measuring 5V but the 3V pin is measuring 8mV
osossomething
by adafruit_support_carter on Thu Jun 21, 2018 5:43 pm
Well, that's no good. Thanks for checking. Let's replace it. Send an email to support@adafruit.com with a link to this thread and they can get you a replacement Pi 3B+.
