I recently puchased Raspberry Pi Zero W Camera Pack - Includes Pi Zero W[ID:3414] in Order 1805893
I imaged a new 32GB SanDisk microSDHC with 2018-06-27-raspbian-stretch-lite and put it in the Raspberry Pi Zero W.
Then I connected the camera board to the Raspberry Pi Zero W with the mini camera cable included in the kit.
I also connected a monitor via a miniHDMI adapter, a threee port USB hub with ethernet to the microUSB socket labeled "USB", and a 5V 2.5A power supply to the microUSB socket labeled "PWR". After boot up I used raspi-config to set localization and I enabeled the Raspberry Pi Camera.
I tried using raspistill to capture an image, but it didn't work. So I shutdown the Raspberry Pi and removed the power cable.
Then I removed the ribon cable from both ends and reattached the ribon cable again.
Then I checked the voltage at ic labeled U3 on the backside of the board and got 3.308 Volts. I tried using the raspistill command
pi@node:~ $ raspistill -v -o test.jpg
mmal: Cannot read camera info, keeping the defaults for OV5647
raspistill Camera App v1.3.11
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
On an ESD safe mat I detached the camera board from the ribon cable and removed the camera module from the board.
Then I reattached the camera module to the board and felt a good snap as it connected.
I reattached the ribon cable to the camera board and then reattached power to the Raspberry Pi Zero W.
It rebooted normally and then I checked the power at the U3 chip on the back of the camera board and again got 3.308 V
I tried raspistill again
Opacity 255
pi@node:~ $ vcgencmd get_camera
supported=1 detected=0
