POE Splitter's Ethernet not working
by TomOlson on Wed Nov 07, 2018 10:10 am
Hi, I bought 14 of these "PoE Splitter with MicroUSB Plug - Isolated 12W - 5V 2.4 Amp" - PartNo. 3785 on Sunday. They power up my Raspberry Pi, but my network boot fails because there is no Ethernet connection through the splitter. We are using a Cisco Catalyst 2960-S POE+ switch which supports 802.3at, the update to the 802.3af standard.
If I power from an adapter and plug the Ethernet directly in from the switch to the Pi, it boots fine. So, something not working in the POE splitter's Ethernet. I tried 3 of the 14 with the same behavior, the yellow light on the splitters Ethernet port lights steady, but that's it. I see there are references to other Adafruit POE splitters having issues with Ethernet.
What next? Thanks, Tom
TomOlson
Re: POE Splitter's Ethernet not working
by adafruit_support_mike on Thu Nov 08, 2018 4:20 am
As a sanity check, could you test all of them please? It won't have any effect on the return/replacement status, and will tell us whether the issue applies to specific units or all of them.
by adafruit2 on Thu Nov 08, 2018 10:43 am
worth checking - what if you connect them to a non-PoE hub e.g. if you get ethernet thru? we tested them with a basic 100mbps ethernet switch
adafruit2
Site Admin
by TomOlson on Thu Nov 08, 2018 4:37 pm
All 14 are DOA. Ethernet does not work on a non-POE switch.
TomOlson
by adafruit2 on Thu Nov 08, 2018 4:47 pm
thats unusual - do you by chance have the packaging for any? we dont want to replace em if they're *all* bad
adafruit2
Site Admin
by TomOlson on Thu Nov 08, 2018 5:19 pm
Yeah, I agree, it's unusual and disappointing. I do have the packaging. They are all in their little plastic bags.
TomOlson
by adafruit2 on Thu Nov 08, 2018 6:46 pm
can you post a pic of one packaging? might help us identify whats up. we'll also test some stock tomorrow
adafruit2
Site Admin
by TomOlson on Thu Nov 08, 2018 6:55 pm
Here's a picture.
IMG_0297 (1).png (101.48 KiB) Viewed 135 times
TomOlson
by adafruit2 on Thu Nov 08, 2018 11:20 pm
thanks, that datecode helps!
adafruit2
Site Admin
by TomOlson on Fri Nov 09, 2018 9:26 am
Ok, so what's next? I've lost a few days on my project and have no plan. Am I returning these for a refund or replacements?
If replacements, can we check that they work before shipment? If this item is suspect, any other suggestions? Thanks.
TomOlson
by adafruit2 on Fri Nov 09, 2018 11:36 am
hiya we'll check our stock today - we dont want to replace if they're broken! we have to set up a router, find some Pis, etc. so we'll reply later!
adafruit2
Site Admin
by TomOlson on Fri Nov 09, 2018 11:45 am
Yup, I don't want any additional ones that don't work.
Catch you later.
TomOlson
by adafruit2 on Sun Nov 11, 2018 6:37 pm
ok checked 5 and...they're fine! power & ping and evething.
same batch and everything. so, maybe its your hub? we're using a TPlink TL-SG1008p
adafruit2
Site Admin
by TomOlson on Mon Nov 12, 2018 11:06 am
I bought another POE splitter on Amazon from a company called Uctronics over the weekend. I tried it this morning and the Pi booted fine. I don't think it's the switch. We're running a Cisco Catalyst 2960-S POE+. I also went back and grabbed 3 from your batch, as a sanity check, and the Pi would not boot (gets power, no Ethernet).
I'm not sure where you want to go with this.
1) I can return the 14 and get a refund.
2) I can return the 14, and you can ship me another 14. If you do that can you include and separate the 5 you checked as working? I'll check those first. Or, check another 9 and send me 14 that are checked as working.
Frankly, I'm frustrated. Not with Adafruit, but all I want is something that works so I can get my Pi's working ASAP. You're the 3rd vendor I tried where I had to return hardware, because it did not work. I didn't expect this to be a big issue. I went to you guys because of my experience and your reputation as a company. Even you guys now checking your existing stock is an example of why I shopped with you. Anyway, enough of my rant.
What's next?
TomOlson
by adafruit2 on Mon Nov 12, 2018 12:40 pm
the 5 we tested went back in stock. since you're the only person with an issue we really don't think replacing them will make any difference - it just doesn't work with your setup. you can return them all for a refund
email support@adafruit.com to let em know, and a link to this thread.
thx!
adafruit2
Site Admin
