Resistive Touchscreen on 2.8 PiTFT Plus Doesn't Respond to T
by blahblahblah123 on Wed Apr 24, 2019 11:12 am
Hi there,
I ordered the 1 x PiTFT Plus Assembled 320x240 2.8" TFT + Resistive Touchscreen[ID:2298].
The resistive touchscreen doesn't respond to touch after I went through the easy install process. The screen works but using a stylus or a finger does not create any effect. I have a Jessie model Raspberry pi.
I found another forum where Adafruit had the person go through a number of steps like taking a picture, etc. Please let me know what you need me to do.
blahblahblah123
Re: Resistive Touchscreen on 2.8 PiTFT Plus Doesn't Respond
by adafruit_support_mike on Fri Apr 26, 2019 3:58 am
Yep, we check some diagnostic information to see if we can get things working.
Post the contents of your /boot/config.txt file, and the output from the command `dmesg`, both between CODE tags please.
by blahblahblah123 on Fri Apr 26, 2019 10:32 pm
How do I do that? I'm a bit of a novice.
blahblahblah123
by adafruit_support_mike on Sat Apr 27, 2019 4:24 am
Start by logging into the RasPi. If you’re using the command-line interface (text only, no GUI), you can enter commands directly. If you’re using the GUI, open an xterm window (there should be a button for it on the menu bar), and use that to enter commands.
The command you want is:
sudo sh -c “dmesg >/boot/dmesg.txt”
Then shut the RasPi down and plug the SD card into a desktop computer. It will mount as a small removable drive named BOOT, and will contain several files. Two of them will be named ‘config.txt’ and ‘dmesg.txt’.
Copy the contents of those files and paste them between CODE tags please. The CODE tags are much easier for us to read than just attaching the files to the post.
by blahblahblah123 on Wed May 29, 2019 1:04 am
This thing is super tiny and doesn't plug into my laptop. You guys have one heck of a bad return policy. How do I get the stuff from the sd card if there's no place to plug it in?
blahblahblah123
by adafruit_support_mike on Wed May 29, 2019 12:19 pm
Our return/replace policy cover production defects and early component failures, and we verify those with a debugging process. We don’t authorize returns/replacements for configuration problems or general “it doesn’t work the way I expected” issues. For those, we provide free tech support.
If your computer doesn’t have a built-in SD reader, there are versions that plug into a USB port. We have some in the shop:
https://www.adafruit.com/product/939
but you can also get them from places like Walmart.
by blahblahblah123 on Wed May 29, 2019 12:25 pm
A built in micro sd reader?
blahblahblah123
by blahblahblah123 on Wed May 29, 2019 12:26 pm
Is there any non sd option?
blahblahblah123
by blahblahblah123 on Wed May 29, 2019 11:21 pm
Hey Walmart is p far from where I live and I'm working.
In the spirit of the tech support aspect, do you have any general guesses as to any quick change I might want to try first to get the touch working. Like, assuming it's not defective, what's the best bet for powering the thing on with my keyboard plugged in and trying to get the touch screen to work?
blahblahblah123
by adafruit_support_mike on Fri May 31, 2019 2:26 am
I'm limited by the information I can get from you, and so far I don't have anything with diagnostic value.
I need to know if the software to run the PiTFT has been installed properly, if that software is seeing the PiTFT when the RasPi boots, and if the pieces that should be running are actually running. Until we find some way to get information from the RasPi to a place where I can read it, we're stuck.
by blahblahblah123 on Sat Jun 01, 2019 11:17 pm
I just learned to mount a USB (I'm using the thing for non touch purposes to at least put it to use). Can I transfer whatever you're looking for to that and view it on my desktop?
blahblahblah123
by adafruit_support_mike on Mon Jun 03, 2019 12:29 am
If you can log into the RasPi, execute the command:
dmesg >dmesg.txt
and copy that file onto a USB thumb drive, then yes, that will work. Move the thumb drive to your desktop computer, open the file, and paste the contents between CODE tags please.
by blahblahblah123 on Mon Jun 10, 2019 10:31 pm
DMESG
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.18-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 SMP Thu Feb 25 14:22:53 GMT 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 80876f80, node_mem_map b9bb4000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 12 pages/cpu @bafaf000 s20416 r8192 d20544 u49152
[    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa22082 bcm2709.serial=0xb6659d2f smsc95xx.macaddr=B8:27:EB:65:9D:2F bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939412K/966656K available (6024K kernel code, 534K rwdata, 1660K rodata, 448K init, 757K bss, 19052K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807895a0   (7686 kB)
      .init : 0x8078a000 - 0x807fa000   ( 448 kB)
      .data : 0x807fa000 - 0x8087fac0   ( 535 kB)
       .bss : 0x80882000 - 0x8093f79c   ( 758 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]    Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000243] Console: colour dummy device 80x30
[    0.001284] console [tty1] enabled
[    0.001338] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001407] pid_max: default: 32768 minimum: 301
[    0.001722] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001765] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002761] Initializing cgroup subsys blkio
[    0.002809] Initializing cgroup subsys memory
[    0.002857] Initializing cgroup subsys devices
[    0.002900] Initializing cgroup subsys freezer
[    0.002950] Initializing cgroup subsys net_cls
[    0.003021] CPU: Testing write buffer coherency: ok
[    0.003107] ftrace: allocating 20309 entries in 60 pages
[    0.048746] CPU0: update cpu_capacity 1024
[    0.048810] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.048843] [bcm2709_smp_prepare_cpus] enter
[    0.048992] Setting up static identity map for 0x8240 - 0x8274
[    0.050744] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.051065] [bcm2709_secondary_init] enter cpu:1
[    0.051109] CPU1: update cpu_capacity 1024
[    0.051115] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.051488] [bcm2709_boot_secondary] cpu:2 started (0) 18
[    0.051744] [bcm2709_secondary_init] enter cpu:2
[    0.051766] CPU2: update cpu_capacity 1024
[    0.051772] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.052124] [bcm2709_boot_secondary] cpu:3 started (0) 18
[    0.052308] [bcm2709_secondary_init] enter cpu:3
[    0.052329] CPU3: update cpu_capacity 1024
[    0.052335] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.052397] Brought up 4 CPUs
[    0.052495] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.052524] CPU: All CPU(s) started in HYP mode.
[    0.052550] CPU: Virtualization extensions available.
[    0.053244] devtmpfs: initialized
[    0.071799] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.072069] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072915] pinctrl core: initialized pinctrl subsystem
[    0.073458] NET: Registered protocol family 16
[    0.078578] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.079546] bcm2709.uart_clock = 48000000
[    0.083902] bcm2709: Mini UART enabled
[    0.083970] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.084017] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.084190] Serial: AMBA PL011 UART driver
[    0.084336] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    0.084775] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.149480] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[    0.149551] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[    0.150150] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[    0.150187] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[    0.150760] SCSI subsystem initialized
[    0.150963] usbcore: registered new interface driver usbfs
[    0.151070] usbcore: registered new interface driver hub
[    0.151185] usbcore: registered new device driver usb
[    0.151732] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-25 14:25
[    0.178827] Switched to clocksource arch_sys_counter
[    0.220387] FS-Cache: Loaded
[    0.220670] CacheFiles: Loaded
[    0.229873] NET: Registered protocol family 2
[    0.230833] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.230975] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.231185] TCP: Hash tables configured (established 8192 bind 8192)
[    0.231299] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.231368] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.231690] NET: Registered protocol family 1
[    0.232010] RPC: Registered named UNIX socket transport module.
[    0.232042] RPC: Registered udp transport module.
[    0.232070] RPC: Registered tcp transport module.
[    0.232097] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.233071] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.234155] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.247567] VFS: Disk quotas dquot_6.6.0
[    0.247895] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.249951] FS-Cache: Netfs 'nfs' registered for caching
[    0.250879] NFS: Registering the id_resolver key type
[    0.250947] Key type id_resolver registered
[    0.250975] Key type id_legacy registered
[    0.253024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.253195] io scheduler noop registered
[    0.253234] io scheduler deadline registered (default)
[    0.253539] io scheduler cfq registered
[    0.255813] BCM2708FB: allocated DMA memory fa800000
[    0.255860] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.261292] Console: switching to colour frame buffer device 80x30
[    0.266212] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.271589] console [ttyS0] disabled
[    0.273237] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[    1.470055] console [ttyS0] enabled
[    1.478244] vc-cma: Videocore CMA driver
[    1.486315] vc-cma: vc_cma_base      = 0x00000000
[    1.495637] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.506031] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.516503] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.544227] brd: module loaded
[    1.557548] loop: module loaded
[    1.564954] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[    1.579143] Loading iSCSI transport class v2.0-870.
[    1.589266] usbcore: registered new interface driver smsc95xx
[    1.600234] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.811415] Core Release: 2.80a
[    1.818007] Setting default values for core params
[    1.827336] Finished setting default values for core params
[    2.038278] Using Buffer DMA mode
[    2.045213] Periodic Transfer Interrupt Enhancement - disabled
[    2.056279] Multiprocessor Interrupt Enhancement - disabled
[    2.066955] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.075695] Dedicated Tx FIFOs mode
[    2.083211] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[    2.102384] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[    2.135677] dwc_otg: Microframe scheduler enabled
[    2.135726] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040ecc0
[    2.146943] WARN::hcd_init_fiq:413: FIQ ASM at 0x8040f030 length 36
[    2.158749] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
[    2.170141] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.179805] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.194897] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[    2.205648] Init: Port Power? op_state=1
[    2.213631] Init: Power Port (0)
[    2.220644] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.233311] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.248229] usb usb1: Product: DWC OTG Controller
[    2.257500] usb usb1: Manufacturer: Linux 4.1.18-v7+ dwc_otg_hcd
[    2.268892] usb usb1: SerialNumber: 3f980000.usb
[    2.278629] hub 1-0:1.0: USB hub found
[    2.286343] hub 1-0:1.0: 1 port detected
[    2.294621] dwc_otg: FIQ enabled
[    2.294630] dwc_otg: NAK holdoff enabled
[    2.294638] dwc_otg: FIQ split-transaction FSM enabled
[    2.294670] Module dwc_common_port init
[    2.294929] usbcore: registered new interface driver usb-storage
[    2.306456] mousedev: PS/2 mouse device common for all mice
[    2.317729] bcm2835-cpufreq: min=600000 max=1200000
[    2.327508] sdhci: Secure Digital Host Controller Interface driver
[    2.339117] sdhci: Copyright(c) Pierre Ossman
[    2.348039] sdhost: log_buf @ ba813000 (fa813000)
[    2.428860] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.461748] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    2.472840] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[    2.488926] Indeed it is in host mode hprt0 = 00021501
[    2.499717] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.518810] mmc0: new high speed SDHC card at address 59b4
[    2.518944] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.519308] ledtrig-cpu: registered to indicate activity on CPUs
[    2.519429] hidraw: raw HID events driver (C) Jiri Kosina
[    2.519616] usbcore: registered new interface driver usbhid
[    2.519618] usbhid: USB HID core driver
[    2.520017] Initializing XFRM netlink socket
[    2.520041] NET: Registered protocol family 17
[    2.520150] Key type dns_resolver registered
[    2.520578] Registering SWP/SWPB emulation handler
[    2.559475] registered taskstats version 1
[    2.559654] vc-sm: Videocore shared memory driver
[    2.559663] [vc_sm_connected_init]: start
[    2.562299] [vc_sm_connected_init]: end - returning 0
[    2.651268] Waiting for root device /dev/mmcblk0p7...
[    2.651485] mmcblk0: mmc0:59b4 USD   15.0 GiB
[    2.654862]  mmcblk0: p1 p2 < p5 p6 p7 >
[    2.671503] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.673061] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.674618] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.677409] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.678866] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.679028] Indeed it is in host mode hprt0 = 00001101
[    2.743349] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
[    2.757925] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
[    2.767164] mmc1: new high speed SDIO card at address 0001
[    2.879121] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.891502] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.905238] hub 1-1:1.0: USB hub found
[    2.912878] hub 1-1:1.0: 5 ports detected
[    3.198862] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.309111] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.321825] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.339410] smsc95xx v1.0.4
[    3.401907] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:9d:2f
[    3.658891] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[    3.778639] usb 1-1.2: New USB device found, idVendor=1997, idProduct=2433
[    3.791555] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.806797] usb 1-1.2: Product: Mini Keyboard
[    3.815646] usb 1-1.2: Manufacturer:
[    3.829616] input:   Mini Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1997:2433.0001/input/input0
[    3.909051] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [  Mini Keyboard] on usb-3f980000.usb-1.2/input0
[    3.938216] input:   Mini Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input1
[    4.019183] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [  Mini Keyboard] on usb-3f980000.usb-1.2/input1
[    4.118860] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[    4.212951] EXT4-fs (mmcblk0p7): orphan cleanup on readonly fs
[    4.224779] EXT4-fs (mmcblk0p7): 2 orphan inodes deleted
[    4.235364] EXT4-fs (mmcblk0p7): recovery complete
[    4.255438] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c
[    4.268572] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.284260] usb 1-1.3: Product: USB Keyboard
[    4.293141] usb 1-1.3: Manufacturer: Logitech
[    4.302211] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    4.319136] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    4.321544] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0003/input/input2
[    4.379087] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.3/input0
[    4.384561] devtmpfs: mounted
[    4.385271] Freeing unused kernel memory: 448K (8078a000 - 807fa000)
[    4.449275] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0004/input/input3
[    4.529090] hid-generic 0003:046D:C31C.0004: input,hidraw3: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.3/input1
[    4.628885] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[    4.743900] usb 1-1.5: New USB device found, idVendor=093a, idProduct=2510
[    4.757124] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.769331] random: systemd urandom read with 86 bits of entropy available
[    4.785987] usb 1-1.5: Product: USB Optical Mouse
[    4.785999] usb 1-1.5: Manufacturer: PixArt
[    4.808027] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:093A:2510.0005/input/input4
[    4.808164] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    4.808513] systemd[1]: Detected architecture 'arm'.
[    4.868750] hid-generic 0003:093A:2510.0005: input,hidraw4: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.5/input0
[    5.054432] NET: Registered protocol family 10
[    5.065228] systemd[1]: Inserted module 'ipv6'
[    5.077608] systemd[1]: Set hostname to <raspberrypi>.
[    5.474073] systemd[1]: Expecting device dev-ttyS0.device...
[    5.487869] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    5.504367] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.520612] systemd[1]: Starting Remote File Systems (Pre).
[    5.534059] systemd[1]: Reached target Remote File Systems (Pre).
[    5.546109] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    5.566968] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.586307] systemd[1]: Starting Encrypted Volumes.
[    5.598563] systemd[1]: Reached target Encrypted Volumes.
[    5.609398] systemd[1]: Starting Swap.
[    5.619636] systemd[1]: Reached target Swap.
[    5.628479] systemd[1]: Expecting device dev-mmcblk0p6.device...
[    5.642377] systemd[1]: Starting Root Slice.
[    5.653535] systemd[1]: Created slice Root Slice.
[    5.663184] systemd[1]: Starting User and Session Slice.
[    5.676119] systemd[1]: Created slice User and Session Slice.
[    5.687444] systemd[1]: Starting Delayed Shutdown Socket.
[    5.700399] systemd[1]: Listening on Delayed Shutdown Socket.
[    5.711618] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    5.726487] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.739743] systemd[1]: Starting Journal Socket (/dev/log).
[    5.752886] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.764381] systemd[1]: Starting udev Control Socket.
[    5.776478] systemd[1]: Listening on udev Control Socket.
[    5.787079] systemd[1]: Starting udev Kernel Socket.
[    5.799004] systemd[1]: Listening on udev Kernel Socket.
[    5.809466] systemd[1]: Starting Journal Socket.
[    5.820900] systemd[1]: Listening on Journal Socket.
[    5.830858] systemd[1]: Starting System Slice.
[    5.841995] systemd[1]: Created slice System Slice.
[    5.851751] systemd[1]: Starting File System Check on Root Device...
[    5.868113] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    5.882337] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    5.894513] systemd[1]: Starting system-autologin.slice.
[    5.908037] systemd[1]: Created slice system-autologin.slice.
[    5.919410] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.933296] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.945541] systemd[1]: Starting Increase datagram queue length...
[    5.961812] systemd[1]: Starting Restore / save the current clock...
[    5.984084] systemd[1]: Mounted Huge Pages File System.
[    6.023925] systemd[1]: Starting Load Kernel Modules...
[    6.041257] systemd[1]: Mounting POSIX Message Queue File System...
[    6.102847] systemd[1]: Started Set Up Additional Binary Formats.
[    6.115498] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.140461] systemd[1]: Starting udev Coldplug all Devices...
[    6.157683] systemd[1]: Mounting Debug File System...
[    6.173611] systemd[1]: Starting Slices.
[    6.174643] fuse init (API version 7.23)
[    6.193535] systemd[1]: Reached target Slices.
[    6.207070] systemd[1]: Mounted Debug File System.
[    6.219732] systemd[1]: Mounted POSIX Message Queue File System.
[    6.235255] systemd[1]: Started Increase datagram queue length.
[    6.304560] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    6.343065] i2c /dev entries driver
[    6.366178] systemd[1]: Started Load Kernel Modules.
[    6.380031] systemd[1]: Started Restore / save the current clock.
[    6.406184] systemd[1]: Time has been changed
[    6.452872] systemd[1]: Started udev Coldplug all Devices.
[    6.470215] systemd[1]: Started File System Check on Root Device.
[    6.563064] systemd[1]: Mounting Configuration File System...
[    6.578946] systemd[1]: Mounting FUSE Control File System...
[    6.595071] systemd[1]: Starting Apply Kernel Variables...
[    6.611534] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.629422] systemd[1]: Starting Syslog Socket.
[    6.641768] systemd[1]: Listening on Syslog Socket.
[    6.651812] systemd[1]: Starting Journal Service...
[    6.668952] systemd[1]: Started Journal Service.
[    6.827957] systemd-udevd[108]: starting version 215
[    7.211692] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    7.489805] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    7.569418] cfg80211: Calling CRDA to update world regulatory domain
[    7.706609] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[    7.707796] usbcore: registered new interface driver brcmfmac
[    7.858896] random: nonblocking pool is initialized
[    7.866563] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[    7.893715] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    8.039952] bcm2835-rng 3f104000.rng: hwrng registered
[    8.041378] spi spi0.0: setting up native-CS0 as GPIO 8
[    8.041568] spi spi0.1: setting up native-CS1 as GPIO 7
[    8.042820] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[    8.197614] ft6236 1-0038: failed to read from controller: -5
[    8.197660] ft6236: probe of 1-0038 failed with error -5
[    8.288760] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[    8.308087] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[    8.310163] fbtft_of_value: buswidth = 8
[    8.310183] fbtft_of_value: debug = 0
[    8.310194] fbtft_of_value: rotate = 90
[    8.310204] fbtft_of_value: fps = 30
[    8.488924] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=33, spi0.0 at 64 MHz
[    8.529827] systemd-journald[105]: Received request to flush runtime journal from PID 1
[    8.587015] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    8.587041] cfg80211: World regulatory domain updated:
[    8.587050] cfg80211:  DFS Master region: unset
[    8.587059] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.587073] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.587086] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.587138] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.587152] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.587167] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.587179] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.587191] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.587203] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    8.924854] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    8.924879] brcmfmac: brcmf_add_if: ignore IF event
[    9.829505] uart-pl011 3f201000.uart: no DMA platform data
[   10.190794] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
[   10.771169] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   10.771399] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.007902] cfg80211: Calling CRDA for country: US
[   12.031292] cfg80211: Regulatory domain changed to country: US
[   12.031315] cfg80211:  DFS Master region: FCC
[   12.031324] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   12.031339] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   12.031353] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[   12.031368] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[   12.031380] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   12.031393] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   14.435204] Bluetooth: Core ver 2.20
[   14.435280] NET: Registered protocol family 31
[   14.435290] Bluetooth: HCI device and connection manager initialized
[   14.435314] Bluetooth: HCI socket layer initialized
[   14.435331] Bluetooth: L2CAP socket layer initialized
[   14.435363] Bluetooth: SCO socket layer initialized
[   14.450636] Bluetooth: HCI UART driver ver 2.3
[   14.450655] Bluetooth: HCI UART protocol H4 registered
[   14.450664] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.450673] Bluetooth: HCI UART protocol BCM registered
[   14.747309] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.747328] Bluetooth: BNEP filters: protocol multicast
[   14.747352] Bluetooth: BNEP socket layer initialized
[   35.182643] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[92018.441764] usb 1-1.4: new high-speed USB device number 7 using dwc_otg
[92018.551158] usb 1-1.4: New USB device found, idVendor=0951, idProduct=1666
[92018.551181] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[92018.551194] usb 1-1.4: Product: DataTraveler 3.0
[92018.551206] usb 1-1.4: Manufacturer: Kingston
[92018.551218] usb 1-1.4: SerialNumber: 60A44C42568CF281E990DEBE
[92018.559270] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[92018.559599] scsi host0: usb-storage 1-1.4:1.0
[92019.552555] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0      PQ: 0 ANSI: 6
[92019.553868] sd 0:0:0:0: [sda] 60437492 512-byte logical blocks: (30.9 GB/28.8 GiB)
[92019.554250] sd 0:0:0:0: [sda] Write Protect is off
[92019.554269] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[92019.554577] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[92019.558917]  sda: sda1
[92019.561896] sd 0:0:0:0: [sda] Attached SCSI removable disk
[92019.570743] sd 0:0:0:0: Attached scsi generic sg0 type 0
[92020.077669] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
CONFIG
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=0
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# NOOBS Auto-generated Settings:
dtparam=spi=on
# --- added by adafruit-pitft-helper Thu 18 Apr 02:07:44 UTC 2019 ---
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=pitft28-capacitive,rotate=90,speed=64000000,fps=30
# --- end adafruit-pitft-helper Thu 18 Apr 02:07:44 UTC 2019 ---
hdmi_cvt=640 480 60 1 0 0 0
blahblahblah123
by blahblahblah123 on Thu Jun 13, 2019 1:39 am
Hey, just checking on where we are on this one!
blahblahblah123
by adafruit_support_carter on Fri Jun 14, 2019 4:16 pm
Looks like maybe your are using an older (~2016) version of Raspbian:
Try updating to a newer release of Raspbian. Use the one suggested from the Easy Install setup:
https://learn.adafruit.com/adafruit-pit ... -install-2
Once you download the .zip file and extract the .img, you can install that to the SD card using Etcher:
https://www.raspberrypi.org/documentati ... /README.md
And then run the TFT Easy Installs script again.
