📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Pi Zero W kernel panic when installing
by z1231 on Fri Sep 13, 2019 6:29 pm
Customer support directed me to post here. In the latest raspbian lite Ive tried to install upgrade and jed multiple times on my pi zero w but it throws an error each time. I've tried multiple sd cards an older raspbian lite, the full version and different power sources. It can run basic commands like ping fine but installation doesn't work. When I used the same sd card on another board everything worked fine. Im assuming there is something wrong with board. This was all done over ssh and Putty, The SD cards were flashed with balenaEtcher.
pizerolog.txt
(6.23 KiB) Downloaded 13 times
z1231
Re: Pi Zero W kernel panic when installing
by adafruit_support_mike on Sun Sep 15, 2019 3:31 am
Hmm.. I don't recognize those errors.
Generally speaking, some part of the code that should connect to the internet and look for updates is failing, and the output you're getting looks like a coredump.
As a sanity check, have you enabled and configured the Wifi interface so it can communicate with the internet?
by z1231 on Sun Sep 15, 2019 10:00 am
I think so I put in a conf file with the following. I used the same file for the other board.
country=US
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
    ssid=name"
    psk="pass"
z1231
by adafruit_support_mike on Mon Sep 16, 2019 11:42 pm
There's a missing quotation mark in the 'ssid' line. Double check to make sure that's just a typo.
You might also want to check over in the RasPi Foundation forums to see if the folks there know what could generate that kind of failure:
http://www.raspberrypi.org/forums/
by z1231 on Wed Sep 18, 2019 10:04 am
Yes that's just a typo the file works with the other board. I have posted to the other forums and sadly I haven't gotten a reply yet.
z1231
by z1231 on Wed Sep 18, 2019 11:21 pm
z1231
by adafruit_support_carter on Mon Sep 23, 2019 5:47 pm
How repeatable are those error messages? Do they only show with running sudo apt update?
by z1231 on Thu Oct 03, 2019 11:46 pm
Looks like it was a problem having to due with the july release of raspbian lite. I was able to repeat the error with the old version, but was able to install with the sept release.
z1231
