Pi Zero W, No device found for wifi. Replacement request.
by anthony_sinor on Mon Apr 19, 2021 1:14 am
Order 2495750-2387912096
I've tried:
Pi OS Full
Lite
Desktop with Recommended
MotionEyeOS
Pi OSs (All Stable)
ifconfig shows only shows loopback
MotionEyeOS gets stuck in a boot loop because it doesn't find the wifi chip. Boots fine with wired ethernet.
All images above work fine on the Pi Zero WH that I purchased in the same order.
anthony_sinor
Re: Pi Zero W, No device found for wifi. Replacement request
by adafruit_support_carter on Mon Apr 19, 2021 2:22 pm
Weird. Looks like the other one is a Pi Zero W. Can you try booting again with Pi OS LITE and then post the output of running this command:
dmesg | head -10
by anthony_sinor on Wed Apr 21, 2021 2:11 am
adafruit_support_carter wrote:Weird. Looks like the other one is a Pi Zero W. Can you try booting again with Pi OS LITE and then post the output of running this command:
dmesg | head -10
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.17+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 Mon Feb 22 11:26:13 GMT 2021
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] Memory policy: Data cache writeback
[    0.000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x000000001bffffff]
At Boot it Gives
[FAILED] Failed to start Configure Bluetooth Modems connected by UART.
Full dmesg
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000001bffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[    0.000000] On node 0 totalpages: 114688
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:8C:54:9B vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19154b2e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 374456K/458752K available (8638K kernel code, 1324K rwdata, 2816K rodata, 420K init, 837K bss, 18760K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 30576 entries in 60 pages
[    0.000000] ftrace: allocated 60 pages with 4 groups
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x324/0x564 with crng_init=0
[    0.000027] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000109] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000207] bcm2835: system timer (irq = 27)
[    0.000909] Console: colour dummy device 80x30
[    0.001594] printk: console [tty1] enabled
[    0.001697] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060392] pid_max: default: 32768 minimum: 301
[    0.060726] LSM: Security Framework initializing
[    0.061084] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.061160] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.063623] Disabling memory control group subsystem
[    0.063972] CPU: Testing write buffer coherency: ok
[    0.066071] Setting up static identity map for 0x8200 - 0x8238
[    0.067521] devtmpfs: initialized
[    0.080972] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.081446] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.081536] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.090438] pinctrl core: initialized pinctrl subsystem
[    0.092725] NET: Registered protocol family 16
[    0.097496] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.104537] audit: initializing netlink subsys (disabled)
[    0.106247] thermal_sys: Registered thermal governor 'step_wise'
[    0.107297] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.107398] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.107696] Serial: AMBA PL011 UART driver
[    0.110924] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1
[    0.131568] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.150968] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
[    0.160983] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
[    0.224125] bcm2835-dma 20007000.dma: DMA legacy API manager, dmachans=0x1
[    0.227486] SCSI subsystem initialized
[    0.228060] usbcore: registered new interface driver usbfs
[    0.228230] usbcore: registered new interface driver hub
[    0.228387] usbcore: registered new device driver usb
[    0.231466] clocksource: Switched to clocksource timer
[    2.242649] VFS: Disk quotas dquot_6.6.0
[    2.242859] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.243186] FS-Cache: Loaded
[    2.243663] CacheFiles: Loaded
[    2.265127] NET: Registered protocol family 2
[    2.266623] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    2.266797] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    2.266920] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    2.267026] TCP: Hash tables configured (established 4096 bind 4096)
[    2.267264] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    2.267350] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    2.267897] NET: Registered protocol family 1
[    2.269351] RPC: Registered named UNIX socket transport module.
[    2.269435] RPC: Registered udp transport module.
[    2.269475] RPC: Registered tcp transport module.
[    2.269510] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.271119] hw perfevents: no irqs for PMU, sampling events not supported
[    2.271259] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    2.276614] Initialise system trusted keyrings
[    2.277301] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    2.290181] zbud: loaded
[    2.293739] FS-Cache: Netfs 'nfs' registered for caching
[    2.295371] NFS: Registering the id_resolver key type
[    2.295498] Key type id_resolver registered
[    2.295543] Key type id_legacy registered
[    2.295817] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.297972] Key type asymmetric registered
[    2.298059] Asymmetric key parser 'x509' registered
[    2.298199] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    2.298258] io scheduler mq-deadline registered
[    2.298298] io scheduler kyber registered
[    2.301928] bcm2708_fb soc:fb: FB found 1 display(s)
[    2.341511] random: fast init done
[    2.365312] Console: switching to colour frame buffer device 228x61
[    2.399548] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
[    2.409643] bcm2835-rng 20104000.rng: hwrng registered
[    2.410593] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    2.413072] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    2.440735] brd: module loaded
[    2.460198] loop: module loaded
[    2.463438] Loading iSCSI transport class v2.0-870.
[    2.466427] libphy: Fixed MDIO Bus: probed
[    2.467209] usbcore: registered new interface driver smsc95xx
[    2.467496] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    3.196424] Core Release: 2.80a
[    3.196639] Setting default values for core params
[    3.196882] Finished setting default values for core params
[    3.397599] Using Buffer DMA mode
[    3.397775] Periodic Transfer Interrupt Enhancement - disabled
[    3.397982] Multiprocessor Interrupt Enhancement - disabled
[    3.398181] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.398502] Dedicated Tx FIFOs mode
[    3.399737] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = d7d14000 dma = 0x97d14000 len=9024
[    3.400237] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    3.410301] dwc_otg: Microframe scheduler enabled
[    3.410644] WARN::hcd_init_fiq:457: FIQ on core 0
[    3.428630] WARN::hcd_init_fiq:458: FIQ ASM at c0652330 length 36
[    3.446299] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000
[    3.463948] dwc_otg 20980000.usb: DWC OTG Controller
[    3.472909] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    3.482001] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    3.491249] Init: Port Power? op_state=1
[    3.500170] Init: Power Port (0)
[    3.510056] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    3.519230] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.528529] usb usb1: Product: DWC OTG Controller
[    3.537469] usb usb1: Manufacturer: Linux 5.10.17+ dwc_otg_hcd
[    3.546728] usb usb1: SerialNumber: 20980000.usb
[    3.557192] hub 1-0:1.0: USB hub found
[    3.566319] hub 1-0:1.0: 1 port detected
[    3.577654] dwc_otg: FIQ enabled
[    3.577690] dwc_otg: NAK holdoff enabled
[    3.577706] dwc_otg: FIQ split-transaction FSM enabled
[    3.577739] Module dwc_common_port init
[    3.578460] usbcore: registered new interface driver usb-storage
[    3.588299] mousedev: PS/2 mouse device common for all mice
[    3.599491] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.613412] sdhci: Secure Digital Host Controller Interface driver
[    3.622541] sdhci: Copyright(c) Pierre Ossman
[    3.632673] mmc-bcm2835 20300000.mmcnr: could not get clk, deferring probe
[    3.643441] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    3.653113] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.663566] ledtrig-cpu: registered to indicate activity on CPUs
[    3.673462] hid: raw HID events driver (C) Jiri Kosina
[    3.683390] usbcore: registered new interface driver usbhid
[    3.692908] usbhid: USB HID core driver
[    3.710342] Initializing XFRM netlink socket
[    3.720461] NET: Registered protocol family 17
[    3.730078] Key type dns_resolver registered
[    3.739930] registered taskstats version 1
[    3.748731] Loading compiled-in X.509 certificates
[    3.777716] uart-pl011 20201000.serial: cts_event_workaround enabled
[    3.786879] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    3.800241] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    3.812979] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    3.822188] mmc-bcm2835 20300000.mmcnr: DMA channel allocated
[    3.832204] Indeed it is in host mode hprt0 = 00021501
[    3.920160] sdhost: log_buf @ (ptrval) (97d13000)
[    3.981336] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.999308] of_cfs_init
[    4.031993] of_cfs_init: OK
[    4.063371] usb 1-1: new full-speed USB device number 2 using dwc_otg
[    4.075122] Waiting for root device PARTUUID=19154b2e-02...
[    4.085143] Indeed it is in host mode hprt0 = 00021501
[    4.178952] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.188247] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.207656] mmc1: Controller never released inhibit bit(s).
[    4.245858] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.258572] mmc0: Problem switching card into high-speed mode!
[    4.273916] mmc0: new SDHC card at address 0001
[    4.289537] mmc-bcm2835 20300000.mmcnr: no support for card's volts
[    4.289580] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.308306] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.317693] mmc1: error -22 whilst initialising SDIO card
[    4.337576] mmc1: Controller never released inhibit bit(s).
[    4.349981] mmcblk0: mmc0:0001 SD 7.44 GiB
[    4.366170] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.375995] mmc1: Got command interrupt 0x00030000 even though no command operation was in progress.
[    4.395451] mmc1: Controller never released inhibit bit(s).
[    4.410006]  mmcblk0: p1 p2
[    4.422487] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[    4.432198] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.442039] usb 1-1: Product: USB Receiver
[    4.451345] usb 1-1: Manufacturer: Logitech
[    4.471206] input: Logitech USB Receiver as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:046D:C52B.0001/input/input0
[    4.543561] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-20980000.usb-1/input0
[    4.564114] input: Logitech USB Receiver Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input1
[    4.576064] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input2
[    4.652468] input: Logitech USB Receiver System Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input3
[    4.664889] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-20980000.usb-1/input1
[    4.683862] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-20980000.usb-1/input2
[    4.740952] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    4.751985] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    4.926707] EXT4-fs (mmcblk0p2): recovery complete
[    4.947422] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.958646] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    4.985538] devtmpfs: mounted
[    5.004364] Freeing unused kernel memory: 420K
[    5.015227] Kernel memory protection not selected by kernel config.
[    5.026312] Run /sbin/init as init process
[    5.037053]   with arguments:
[    5.037078]     /sbin/init
[    5.037092]   with environment:
[    5.037105]     HOME=/
[    5.037117]     TERM=linux
[    6.273578] systemd[1]: System time before build time, advancing clock.
[    6.564384] NET: Registered protocol family 10
[    6.578441] Segment Routing with IPv6
[    6.749094] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.775453] systemd[1]: Detected architecture arm.
[    6.846182] systemd[1]: Set hostname to <raspberrypi>.
[   10.177048] random: systemd: uninitialized urandom read (16 bytes read)
[   10.222694] random: systemd: uninitialized urandom read (16 bytes read)
[   10.236368] systemd[1]: Listening on Journal Audit Socket.
[   10.263270] random: systemd: uninitialized urandom read (16 bytes read)
[   10.276336] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.305140] systemd[1]: Listening on Syslog Socket.
[   10.333536] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.361245] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.397007] systemd[1]: Created slice system-getty.slice.
[   10.425549] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.786318] systemd[1]: Reached target Paths.
[   11.943564] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.023855] systemd[1]: Listening on udev Kernel Socket.
[   12.162172] systemd[1]: Starting udev Coldplug all Devices...
[   12.262300] systemd[1]: Reached target Slices.
[   12.440142] systemd[1]: Started Load Kernel Modules.
[   12.581946] systemd[1]: Started Restore / save the current clock.
[   12.677380] systemd[1]: Mounted RPC Pipe File System.
[   12.794722] systemd[1]: Started Journal Service.
[   15.841647] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.218861] systemd-journald[74]: Received request to flush runtime journal from PID 1
[   22.038360] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[   22.056005] mc: Linux media interface: v0.10
[   22.092142] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[   22.092200] [vc_sm_connected_init]: start
[   22.105031] [vc_sm_connected_init]: installed successfully
[   22.536755] videodev: Linux video capture interface: v2.00
[   22.784965] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   22.802308] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   22.813283] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   22.831288] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[   22.844219] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[   22.859272] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[   22.881820] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[   22.944430] bcm2835_audio bcm2835_audio: card created with 8 channels
[   22.946882] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[   22.972630] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[   23.041808] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[   23.043449] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[   23.069447] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[   23.069526] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[   23.069610] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[   23.069654] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[   23.069690] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[   23.081386] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[   23.175345] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[   23.175450] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[   23.254337] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[   23.254442] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[   23.295680] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[   23.295792] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[   28.382896] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-20980000.usb-1/input2
[   28.539963] input: Logitech Wireless Device PID:4078 Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4078.0004/input/input5
[   28.573596] input: Logitech Wireless Device PID:4078 Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4078.0004/input/input6
[   28.575215] input: Logitech Wireless Device PID:4078 Consumer Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4078.0004/input/input7
[   28.576209] input: Logitech Wireless Device PID:4078 System Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4078.0004/input/input8
[   28.585717] hid-generic 0003:046D:4078.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4078] on usb-20980000.usb-1/input2:1
[   29.501939] random: crng init done
[   29.501983] random: 7 urandom warning(s) missed due to ratelimiting
[   35.797706] input: Logitech K600 TV as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4078.0004/input/input12
[   35.822959] logitech-hidpp-device 0003:046D:4078.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K600 TV] on usb-20980000.usb-1/input2:1
[   59.914688] 8021q: 802.1Q VLAN Support v1.8
[   61.129791] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   62.319104] uart-pl011 20201000.serial: no DMA platform data
[   62.410477] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   62.868139] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[  108.996256] logitech-hidpp-device 0003:046D:4078.0004: HID++ 4.5 device connected.
Sysctrl output for failure during boot
● hciuart.service - Configure Bluetooth Modems connected by UART
   Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2021-03-04 23:05:45 GMT; 2min 10s ago
  Process: 310 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
Mar 04 23:05:13 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Mar 04 23:05:45 raspberrypi btuart[310]: Initialization timed out.
Mar 04 23:05:45 raspberrypi btuart[310]: bcm43xx_init
Mar 04 23:05:45 raspberrypi systemd[1]: hciuart.service: Control process exited, code=exited, status=1/FAILURE
Mar 04 23:05:45 raspberrypi systemd[1]: hciuart.service: Failed with result 'exit-code'.
Mar 04 23:05:45 raspberrypi systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
The dates are the date time is what the Pi currently reports. There was a clk message in dmesg @3.63
anthony_sinor
by adafruit_support_carter on Wed Apr 21, 2021 11:04 am
Thanks. To rule out this being a weird power issue - are you using the same power supply that works on the Zero WH?
Same for the USB items you have attached. Looks like various Logitech devices. All those attached to Zero WH boots OK?
by anthony_sinor on Wed Apr 21, 2021 3:54 pm
The power supply for the Pi WH produces the same error.
I've also tested with official power supply, CanaKit pi4 supply, various usb chargers, powered hubs and usb2/3 laptop ports. The only other thing I can try is a 24v->5v buck converter to the gpio header, but I can't guarantee a good connection without soldering.
The only thing connected is a logitech wireless keyboard/mouse combo via a logitech rf dongle. I could try my other keyboard, but its a Raz or chroma that needs more power than the pi itself.
anthony_sinor
by adafruit_support_carter on Wed Apr 21, 2021 5:07 pm
Let's just replace it. Weird issue, not sure what it could be. Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement Pi Zero W.
by anthony_sinor on Wed Apr 21, 2021 5:39 pm
Thank you!
anthony_sinor
