Cyberdeck hat not working with Hyperpixel4
by Zelphior on Mon Apr 19, 2021 10:14 pm
I have a hyperpixel 4 that I can connect directly to the GPIO headers (with a header extension) on my pi 400. The screen faces away from the keyboard but it works. I just bought a cyberdeck hat so I can use the screen facing forward, but when I connected it the display backlight turns on but only get intermittent video, only for a few seconds once the desktop comes up, then the display turns black. Most times when booting there's nothing.
I tried a fresh Raspberry OS install, ran sudo apt update and sudo apt upgrade, then re-installed pimoroni's drivers from their git repository and rebooted, but still just get a flash of video showing the desktop for maybe a second then display goes blank again. Power off and pull off the cyberdeck hat and connect direct and it works again.
I am able to connect the hyperpixel directly to another pi4 and it works fine, but when I try the cyberdeck hat on the pi4 with the hyperpixel I get same issue, only the backlight turns on but video stays black, every so often just afterbooting will show a flash of the desktop then back to black.
Display works when connected direclty to 2 different pi's. Display does not work on either pi when connected through the cyberdeck hat.
Is there anything else I can do to test? Is there any firmware to update on the cyberdeck hat or did I just get a dud?
Zelphior
Re: Cyberdeck hat not working with Hyperpixel4
by adafruit2 on Tue Apr 20, 2021 3:42 pm
hmm do you see any solder joints that are iffy? we pass all pins through but maybe one is loose?
adafruit2
Site Admin
by Zelphior on Wed Apr 21, 2021 5:53 pm
Well good news is that when doing some more testing, I was able to get the hat working with the pi4 (had it on upside-down previously), so no issue with the hat. Display works fine with the hat on the pi4 and on a zero, but still can’t get it to work with the pi 400. I pried the case apart and looked at the pins there, and it looks like one of the grounds, pin 39, is a bit loose. Probably when the display is connected directly it’s holding it in place, but with the cyber deck hat it’s getting jostled just a bit loose.
Zelphior
by adafruit2 on Wed Apr 21, 2021 5:56 pm
! wanna try soldering it? not sure thats the issue but worth a shot
adafruit2
Site Admin
