Installed both with no real problems on my PI400.
I am just curious if it is possible to use a different resolution on ii than on my 27" monitor.
if I reduce the resolution on the monitor so that I can read the TFT the monitor resolution is so bad it is unreadable.
If not is there a guide to using the fb on it?
My system info:
System: Kernel: 5.10.35-v8+ aarch64 bits: 64 compiler: N/A Desktop: LXDE 0.10.1 info: lxpanel, plank wm: Openbox 3.6.1
vt: 7 dm: LightDM 1.26.0 Distro: Raspberry Pi OS base: Debian GNU/Linux 11 (bullseye)
Machine: Type: ARM Device System: Raspberry Pi 400 Rev 1.0 details: BCM2835 rev: c03130 serial: <filter>
CPU: Info: Quad Core model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8 rev: 3 bogomips: 432
Speed: 2200 MHz max: 2200 MHz Core speeds (MHz): 1: 2200 2: 2200 3: 2200 4: 2200
Features: asimd cpuid crc32 evtstrm fp
Graphics: Device-1: bcm2711-vc5 driver: vc4_drm v: N/A bus-ID: N/A chip-ID: brcm:gpu class-ID: gpu
Device-2: bcm2711-hdmi0 driver: N/A bus-ID: N/A chip-ID: brcm:soc class-ID: hdmi
Device-3: bcm2711-hdmi1 driver: N/A bus-ID: N/A chip-ID: brcm:soc class-ID: hdmi
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting unloaded: fbdev resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: V3D 4.2 v: 2.1 Mesa 20.3.5 direct render: Yes
Audio: Device-1: bcm2835-audio driver: bcm2835_audio bus-ID: N/A chip-ID: brcm:bcm2835_audio class-ID: bcm2835_audio
Sound Server-1: ALSA v: k5.10.35-v8+ running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A chip-ID: brcm:fe300000 class-ID: mmcnr
IF: wlan0 state: up mac: <filter>
Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A chip-ID: brcm:fd580000 class-ID: ethernet
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000 class-ID: serial
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0 lmp-v: 5.0 sub-v: 6606 hci-v: 5.0
rev: 36
Drives: Local Storage: total: 936.93 GiB used: 101.58 GiB (10.8%)
ID-1: /dev/mmcblk0 model: SD256 size: 238.3 GiB rotation: SSD serial: <filter> scheme: MBR
ID-2: /dev/sda type: USB vendor: Samsung model: PSSD T7 size: 465.76 GiB rotation: SSD serial: <filter> scheme: MBR
ID-3: /dev/sdb type: USB vendor: SanDisk model: USB 3.2Gen1 size: 232.88 GiB serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / size: 457.13 GiB used: 45.15 GiB (9.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 252 MiB used: 47.9 MiB (19.0%) fs: vfat dev: /dev/sda1
Swap: ID-1: swap-1 type: file size: 100 MiB used: 0 KiB (0.0%) priority: -2 file: /var/swap
ID-2: swap-2 type: zram size: 3 GiB used: 9.8 MiB (0.3%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 52.6 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 208 Uptime: 1h 18m Memory: 3.78 GiB used: 2.71 GiB (71.6%) gpu: 76 MiB Init: systemd v: 247 runlevel: 5
target: graphical.target Compilers: gcc: 10.2.1 alt: 10 Packages: 2153 apt: 2147 flatpak: 6 Shell: Bash v: 5.1.8
running-in: guake inxi: 3.3.04
https://imgur.com/a/6NBU4rP
