Speaker Bonnet and 2.3 Monochrome OLED
by AZChris on Fri May 14, 2021 12:27 am
I recently got a l2s speaker bonnet and a 2.3 monochrome oled.
I saw that the speaker bonnet's pins cannot be changed so I wired the oled to be on SPI1 using those pins.
in raspberry pi boot config /boot/config.txt i have enabled SPI and spi1.
During install of the speaker bonnet script it adds the line dtoverlay=hifiberry-dac to the config.txt
After a reboot the spi1 is no longer enabled. If i comment out the dtoverlay=hifiberry-dac and reboot the spi1 comes back to being enabled.
The bonnet works fine (raspberry pi zero wh) when hifiberry is enabled, but spi1 will not come online. the moment i comment out #dtoverlay=hifiberry-dac the spi1 is reenabled but then sadly no more working bonnet.
Is there any known issues regarding these working together?
Thanks.
With the line commented out:
aplay -l returns
aplay: device_list:272: no soundcards found...
and ls /dev/spi* returns
/dev/spidev0.0 /dev/spidev0.1 /dev/spidev1.0
With the line NOT commented out:
aplay -l returns
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
and ls /dev/spi* returns:
AZChris
Re: Speaker Bonnet and 2.3 Monochrome OLED
by adafruit_support_mike on Fri May 14, 2021 2:39 am
Try swapping the order of enabling SPI1 and the I2S interface.
I don't know if there's a conflict between the two interfaces off the top of my head, but the I2S might do some housekeeping before allocating its own pins.
by AZChris on Fri May 14, 2021 9:05 am
Seemed like a good suggestion but sadly no change.
I moved the hiberry line before the spi1 enabling and tried it. and then before enabling spi altogether and tried that too, but still with the same results.
AZChris
by adafruit_support_mike on Fri May 14, 2021 9:25 pm
Check with the folks over at the RasPi Foundation forums to see if they have any more information about the two overlays:
https://www.raspberrypi.org/forums/
They know the low-level hardware and code better than we do.
