Raspberry Pi Zero WH Issue
by nishabe on Sun Jun 13, 2021 2:04 am
Recently I bought a Raspberry Pi Zero WH (Order#2565044-1683822409) for a project.
I started working on the project today and found out that, immediately after powering it on the chip heats up.
Please note, nothing else is connected to the board other than the power supply.
It happens within 5 seconds of power on and too hot to touch.
Could you please advise on the next steps?
nishabe
Re: Raspberry Pi Zero WH Issue
by franklin97355 on Sun Jun 13, 2021 11:27 am
Do you know what is heating up and do you see any shorts in the components? Can you post a picture of the pi with the heat generating part visible (not powered obviously)?
franklin97355
by nishabe on Sun Jun 13, 2021 5:39 pm
Thanks.
Attached is the image where the heat is generated.
I do not see any visible issues on the board.
nishabe
by franklin97355 on Sun Jun 13, 2021 10:22 pm
OK.I don't see any reason the board is heating, we can try to replace it. Contact support@adafaruit.com with a link to this thread qnd they will get you a replacement.
franklin97355
by nishabe on Mon Jun 14, 2021 12:46 am
Thank you very much.
I will do what you suggested.
nishabe
