CircuitPython libraries not installing on pi 4
ThunderChipmunk
Post by ThunderChipmunk »
I am trying to get a Adafruit PiOLED - 128x32 Monochrome OLED to run on a pi4. According to this, you need the CircuitPython Libraries installed. https://www.mouser.ca/datasheet/2/737/a ... 396538.pdf
Following through this to get the library: https://learn.adafruit.com/circuitpytho ... spberry-pi
However, I get a error when I enter:
sudo python3 raspi-blinka.py
Full error
This script configures your
Raspberry Pi and installs Blinka
RASPBERRY_PI_4B detected.
Blinka WARNING Default System python version is 2.7.16. It will be updated to Version 3.
Continue? [y/n] y
Updating System Packages
Blinka E: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  403  Forbidden [IP: 54.69.109.244 443]
E: The repository 'https://ookla.bintray.com/debian generic InRelease' is no longer signed.
Blinka Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Blinka Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Blinka Err:3 https://ookla.bintray.com/debian generic InRelease
Blinka 403  Forbidden [IP: 54.69.109.244 443]
Blinka Reading package lists...
Blinka Exiting due to error: Apt failed to update indexes!
mikeysklar
Re: CircuitPython libraries not installing on pi 4
Post by mikeysklar »
Is your Pi4 up to date?
sudo apt update
sudo apt full-upgrade
You can also try installing directly through pip.
pip3 install adafruit-blinka
ThunderChipmunk
Your download command worked, but I also realized that I needed to enable I2c in preferences.
Return to “Adafruit Raspberry Pi® accessories”
