How to run multiple steppers simultaneously?
by taoxu on Mon Jul 26, 2021 11:58 pm
Hi, I have a DC+ stepper Motor Hat on Raspberry Pi. It has two steppers connected. Although I successfully ran them in a sequence, I have no idea of how to run both of them at the same time. Should I install other libraries or how can I code for that purpose? Thanks.
taoxu
Re: How to run multiple steppers simultaneously?
by adafruit_support_bill on Tue Jul 27, 2021 5:30 am
by taoxu on Tue Jul 27, 2021 10:27 pm
Thanks for your reply. You misunderstood my question. I tried adafruit_io_steppers.py but it ran the steppers one by one, not simultaneously. For example, I hope to run one stepper in a forward direction and meanwhile run the second stepper in a backward direction.
BTW, how should I adjust the speed for these steppers?
taoxu
by adafruit_support_bill on Wed Jul 28, 2021 7:24 am
adafruit_io_steppers.py creates a thread for each stepper, so in theory they could execute in parallel. Although it does not appear that the library synchronizes access to the i2c bus, so you would likely run into some communication issues if you tried it.
A more deterministic approach is to interleave the calls to onestep() using time.monotonic() to control the step rates for each motor. This is typically done with a state machine.
There are lots of on-line tutorials on Python state machines. Although I don't know of any that specifically address stepper motors.
https://learn.adafruit.com/circuitpytho ... e-machines
