adafruit_support_carter wrote:Where are you seeing that error?
The kernel is printing these messages to stdout/stderr, ie:
https://superuser.com/questions/351387/ ... my-console
What is an example of a task that throws the error?
raspivid, gstreamer with v4l2
Is the problem repeatable?
Yes. Every time I run raspivid the system freezes in less than 5 seconds.
Are your other Pi's also Pi Zero Ws? Or is this your only Zero W?
My test systems are:
* Additional Pi Zero W, works 100% perfectly with any of the four sd cards I've tried.
* Pi 3 B, works 100% perfectly with any of the four sd cards I've tried.
* Pi 4, works 100% perfectly with any of the four sd cards I've tried.
Unfortunately, the problem is the board itself is defective.
