No Response From Joy Bonnet
by talofaholbrook on Thu Oct 28, 2021 12:39 am
I bought the Joy Bonnet Pack without Soldering - Includes Pi Zero WH PID: 4085 and got RetroPie running. When RetroPie boots up it prompts that there's no controller plugged in. The Joy Bonnet is clearly plugged in and connected. No amount of button pressing of the Joy Bonnet results in a response like a controller is plugged in. Anything to try? I just barely purchased it. Thanks
talofaholbrook
Re: No Response From Joy Bonnet
by adafruit_support_carter on Thu Oct 28, 2021 12:20 pm
Did you go through this installation process?
https://learn.adafruit.com/adafruit-joy ... ll-and-use
by talofaholbrook on Thu Oct 28, 2021 4:51 pm
No i did not... Will do that now. thanks.
talofaholbrook
by talofaholbrook on Fri Oct 29, 2021 6:05 pm
Okay, I ran through the guide and got it all updated and installed. (see picture) and I'm still not seeing any controller detected when emulation station boots up.
talofaholbrook
by adafruit_support_carter on Sat Oct 30, 2021 12:04 pm
Say Yes to reboot. After reboot, go into RetroPie MENU to configure:
by talofaholbrook on Sun Oct 31, 2021 11:02 pm
Okay, I went through the steps and I'm still not able to detect a gamepad (See Picture attached ...5656.jpg). No matter how many buttons I hold on the joy bonnet it doesn't move on to the configure button step where i can configure AB XY Up Down Left Right etc.
When just the joy bonnet is plugged in I see the welcome screen with no gamepads detected. (See picture attached ...5703.jpg)
Thanks for your help!
talofaholbrook
by adafruit2 on Mon Nov 01, 2021 11:49 am
just for kicks, try installing the software again. let us know if, after reboot, it still isnt detected.
adafruit2
Site Admin
by talofaholbrook on Wed Nov 17, 2021 12:26 pm
First off, thanks so much for your help on this.
I'm still not seeing a controller detected pressing or holding buttons.
Here's what I did just a few minutes ago.
Reloaded RetroPie via the Pi Imager program.
Connected to WiFi
Ran the following in order
cd ~
sudo apt-get install python3-pip
sudo pip3 install --upgrade adafruit-python-shell
wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/joy-bonnet.py
sudo python3 joy-bonnet.py
Rebooted
Went to settings and configure input
Pressed a button on the joy bonnet
held a button on the joy bonnet
No Response from the Joy Bonnet
talofaholbrook
by adafruit2 on Wed Nov 17, 2021 12:54 pm
at the command line - if you press buttons on the joy bonnet do you get any keypresses coming out?
can you also check the output if you run this at the command line:
cd /boot
python3 joyBonnet.py
we will replace the bonnet if its bad, but its hard to tell if its a software thing or a hardware thing!
adafruit2
Site Admin
by talofaholbrook on Wed Nov 17, 2021 3:10 pm
Oh for sure, I totally get it. I'll try these things in a bit and report back.
talofaholbrook
by talofaholbrook on Fri Nov 19, 2021 12:22 pm
getting a
This library requires the RPi.GPIO module
Install with: sudo pip install RPi.GPIO
error when I run
out of the /boot directory
When i try to run
i get a
sudo: pip: command not found
error.
talofaholbrook
by talofaholbrook on Fri Nov 19, 2021 12:24 pm
see attached screenshot
talofaholbrook
by talofaholbrook on Fri Nov 19, 2021 12:36 pm
i got RPi.GPIO installed using apt-get ran python3 joyBonnet.py again and it said it required smbus. Ran sudo apt-get install python3-smbus. After smbus installed I got this error (see attached).
talofaholbrook
by adafruit_support_carter on Fri Nov 19, 2021 3:20 pm
Try running it with sudo. Looks like a permission error trying to access /dev/uinput.
sudo python3 joyBonnet.py
by talofaholbrook on Sat Nov 20, 2021 12:19 am
i do that and it just sits here with a blinking line. Rebooted and controller still doesn't work.
talofaholbrook
