RPI 4B won't boot
RPI 4B won't boot
by uhqfrrvfqb on Sat Nov 20, 2021 1:14 am
Hello, I just received a Raspberry Pi 4B and I am having trouble getting it to boot. I am fairly confident the issue with with the RPI 4B itself -- I have another RPI 4B that works, but when I use the new RPI 4B with the same power supply and SD card as the old one, this new one doesn't work. I'm happy to try other troubleshooting steps if there's anything else I should try. Thanks!
uhqfrrvfqb
Re: RPI 4B won't boot
by adafruit_support_carter on Mon Nov 22, 2021 12:35 pm
Try this: unplug everything from the Raspberry Pi 4, including the SD card, and then turn the power back on. What does the green LED do?
by uhqfrrvfqb on Mon Nov 22, 2021 2:26 pm
The green LED flashes once, very briefly.
uhqfrrvfqb
by uhqfrrvfqb on Mon Nov 29, 2021 3:21 pm
Hello, is there anything else I should try? If not, then I would like to move forward with the return/exchange process. Thanks.
uhqfrrvfqb
by adafruit_support_carter on Tue Nov 30, 2021 3:48 pm
What are you using for a power supply?
What model (how much RAM) is the other Pi 4 that works?
by uhqfrrvfqb on Tue Nov 30, 2021 4:42 pm
I’m using the official raspberry pi power supply. Both Pi’s (the working and non-working) are the 4GB model.
uhqfrrvfqb
by adafruit_support_carter on Wed Dec 01, 2021 3:29 pm
OK, thanks. That power supply should be fine. Asking as that behavior is what happens if you happen to get a Pi with the known USB C power issue (would be from older stock) coupled with certain power supplies. This is a frustrating Pi 4 only issue.
Let's just replace that Pi. Send another email support@adafruit.com and link to this thread. They can send you a replacement Pi 4.
by uhqfrrvfqb on Wed Dec 01, 2021 3:53 pm
Okay, thanks for your help!
uhqfrrvfqb
